Question about Dryers
No heat from dryer
This was bought back in 06, a couple days ago this problem started, it spins fine, timer works, not clogged. It will just spin with no heat generation.
  • andy Dec 11, 2012
    its electric, drum does not get hot
    Top Expert:
  • Dryers Master
  • 14,553 Answers
If a Gas dryer look first to see if igniter is coming on or if drum where clothes are gets hot or not.
Posted on Dec 10, 2012
  • andy Dec 11, 2012
Illeagle
  • 525 Answers
SOURCE: LG Front loader Electric Dryer want heat but will run and spin
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
This link will show teardown illustrations: Parts and more help available on other pages of the website.
http://www.repairclinic.com/0100_16.asp
Hope this helps.
Illeagle
Posted on Aug 27, 2008
TheMobilian
  • 8220 Answers
SOURCE: Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Posted on Jan 20, 2009
  • 24 Answers
SOURCE: The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
Posted on May 19, 2009
protek480
  • 1714 Answers
SOURCE: tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
Posted on Jul 07, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool Dryer, Heats up, but will not spin.
Thermal fuse , is the small white plastic piece on the blower box . That , keeps the dryer from running . Thermal cut-off , is the small thermostat on the burner (element) box , which would keep the dryer from heating .
Posted on Aug 01, 2009
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
Whorlpool dryer timer
I worked ona wp electric dryer not long ago with a heat problem.
Take a look:
DRYER NO HEAT
Jul 08, 2012 | Whirlpool Dryers
Bought my dryer bout 3 years ago it spins fine , goes on spins, just wont heat at all.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 02, 2011 | Dryers
GE dryer is not working. a few weeks ago the spinning slowed and it sounded like the drum(?) was too heavy and grinding and then it just stopped spinning -my husband said that the three bath mats were...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 17, 2011 | GE DCVH515EFWW Electric Dryer
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Fridgidaire Dryer runs constantly when plugged in
It has to do with the onboard timer or timer board
Feb 13, 2009 | Frigidaire FGQ1442ES Gas Dryer
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Dryer not heating, Interimittent Problem -------------------------------------------------------------------------------- Having an intermittent problem. The dryer turns on, drum spins, but you have no...
Have you tried to bypass the hi limit switch or the thermal switch. It will work. If it works for a few times, then you will know the switch is bad. I did this on a friend's one time and it solved it. Only cost about 15 bucks. Godd luck and let me know how it turns out.
Jan 13, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
75 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
