I have a 22" inch LCD sylvania! When I plugg it
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Have the set inspected, sounds (no joke) like a power supply problem in the set.
Posted on Dec 10, 2012
nicknovikov
  • 100 Answers
SOURCE: vertical green line on my emerson 22 inch lcd flat
looks like LCD drive board is bad.or panel itself...
Posted on Jul 13, 2009
SOURCE: Toshiba Regza bought 1/28/08 makes squealing noise
It's in the repair shop. I'll write back what the problem was and how much it cost to ship.
Posted on Oct 08, 2009
  • 541 Answers
SOURCE: when i turn my 42 inch plasma sylvania on, it
You have a short on one of the drive boards making the power supply squeal. You will have to unplug each board until the squeal is no longer there. Which ever board it is will have to be replaced. Thanks for using fixya.
Posted on Nov 26, 2009
  • 139 Answers
SOURCE: vertical lines in my sylvania lcd tv
They go away after 10 minutes of what? **** She Wrote? Dancing with the Stars? Or simply being powered On? You have some cold solder joints on one of the PCB boards. Once they heat up they work perfectly. The only way to fix this is to have them reflowed by a tech with a soldering tool or have the board replaced. Good luck! Cheers
Posted on Dec 29, 2009
SOURCE: Samsung 40" tv won't turn on
i had the same problem, you'll have to call the samsung service center. You TV's part which looks after the voltage connectivity has failed. This majorly happens due to voltage fluctuations. The part will cost around Rs. 2800 and service charges will be applied by the company.
Posted on Jan 04, 2010
Why does my sylvania electric fireplace Model S211 squeal
I had the same problem. If you remove the top row of screws on the backside of the unit, you'll see that the flame effect is created by a series of reflectors attached to a rod. Turning on the unit activates a motor that turns the rod. You'll see that the other end of the rod is just a loose end that is allowed to turn inside a plastic holder. Unfortunately, the rod rubbing against the plastic as it turns causes the annoying squealing sound. I solved the problem by wrapping a small amount of paper towel around the rod, pushing the PT into place inside that plastic rod-holder, and spraying it with a little bit of WD-40. I had to remove the entire back panel to get proper access. No more squealing noise (for now)! Time will tell if I need to reapply the WD-40.
Dec 11, 2012 | Sylvania Electric Stove Heater, Black...
Need code for generic remote control for SRT2223 Sylvania TV 22-23 inch
Universal remote codes for Sylvania are: 0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
Nov 01, 2012 | Televison & Video
I HAVE 22 INCH FLAT SCREEN THAT FELL AND THE SCREEN WAS HIT SO NOW IT HAS DIFFERENT COLOR LINE AND IT LOOKS AS IF THE SCREEN IS CRACKED BUT IT NOT. WHAT COULD BE WRONG
Flat screen sets (LCD and Plasma) are extremely fragile and if damaged in any way the cost of replacement exceeds the price of a new set.
A 22 inch is likely not to even have the display panel available---considering cost of replacement set--I would just buy a new set.
May 22, 2012 | Sylvania Televison & Video
I recently got a used Sylvania 22" TFT-LCD
you posted sylvania to HP , whY?
The did not post a question, is this show and tell.
or the CELL phone battery died.? LOL
Aug 10, 2017 | HP 22" Widescreen Flat Panel TFT LCD HD...
New purchase. VGA connection. First use, all was fine. Turned off, then back on, and image will not "center." Neither VGA Automatic nor the individual controls will adjust the horizontal enough...
Make sure you have your resolution set to 1680 x 1050 as this is the native supported screen size for this LCD. Also check your graphic card's overscan or manual adjustment settings. They might be manually set to offset the screen picture.
Hope this helps,
Chris
Jun 29, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
The words "Digital Noise Filter
The words "Digital Noise Filter Off" and "digital Noise Filter On" appear on the top left and right and side of the screen and the words " Auto Visulisation" appear on the bottom of the screen all the time when watching normal T.V.(series 5 lcd) and if we make changes regarding in setting in picture option in mode.then after 20-30 min againg it displays same message
Feb 01, 2011 | Samsung LE40R74BDX 40 in. LCD Television
When i turn my 42 inch plasma sylvania on, it makes a sharp high pitched squeal, then shuts off. it does this repeatedly, whats the problem, and how do i fix it?
Nov 26, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
I have a 46 inch polaroid lcd tv that when you turn it on everything is fine but after about a minute it starts making a loud squealing noise,even if you mute it, but it will stop after about 15-20...
my 46'' inch tv polaroid lcd has been working fine for 3 years. today my wife and I noticed the tv is shutting off the screen will go black and the power light does switch to red. you can here something inside the t.v clicking but you can turn it on and it will start back fine for 20 minutes then shut off again? Does anybody know whats going out on the tv? let me know
Nov 16, 2009 | Polaroid Televison & Video
Oct 07, 2009 | Toshiba REGZA 47HL167 TV
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
