Question about Health & Beauty
Where can i find a ze-700-30 circuit breaker for my power chair
Breaker will not reset
MicrowaveSvc
  • 9085 Answers
SOURCE: ALL POWER LOST
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The parts I would suspect most are the internal fuse, the magnetron TCO (thermal cutout) or the oven cavity TCO.
To check or replace the latter, you'll need to remove the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 03, 2009
tborn6
  • 700 Answers
SOURCE: 3-pole 60 Amp Circuit Breaker is tripped and won't reset.
check ot see if its on a shunt trip system. what it means is that in order to reset the breaker you have to see what made it trip. Look for a 115 volt breaker that is tripped in the panel that serves tha line. good luck.
Posted on Jan 25, 2009
  • 334 Answers
SOURCE: Circuit breaker on power cord does not reset
why did it trip? If you push test and it does not trip, check your circuit breaker in your panel
Posted on Jun 20, 2009
Treefrog15
  • 127 Answers
SOURCE: How do you reset the microwave power? Is there an
There is an internal cartridge fuse, as well as thermal fuses. It is not recommended that you attempt any internal repairs on a microwave due to the presence of very high voltages and the danger of microwave radiation if not reassembled correctly. Residential microwaves, if not under warrranty, are generally considered disposable. Parts and service are very expensive.
Posted on Feb 25, 2010
Testimonial: "Thanks, that was very helpful."
  • 692 Answers
SOURCE: Plugged the chair into 220v electricity supply. i
WOW!! Big OOPS huh? You probably blew the charger with that jolt. Does your joystick come on at all? Since the charger is connected to the controller or Power Module I hope you didn't blow that up. If you have a digital voltmeter you can set it to 200 volts dc and plug the leads into the 2 outter holes of the charger port located under the front of the joystick. You should read the battery voltage ot 24 - 30 volts. If you don't get anything at the joystick then you will have to remove the seat to get access to the batteries and check the fuses located on the positive posts of each battery. If those are not blown and you still don't have power to the joystick then I'm afraid you blew the controller cause there's no fuse for it. Sorry but if Medicare paid for your chair then you can call a repair service like Roadrunner Mobility @ 1-800-467-2668 or Repair Xpress @ 1-877-581-3733 to have them fix it for you. I might not mention that you plugged into 220 volts tho. Hope this helps
Posted on Nov 07, 2010
Does the reset button need to be hooked up?
Yes of course if it was made with the unit its was important then as
well as it should be now contact manufacture. Reset buttons reset micro processor functions as well as reset the unit memory capability.. Hope this helps God bless
Oct 15, 2014 | Jet 3 Ultra Power Chair
Chair will not turn on
Check connections, reset Main Circuit Breaker and charge battery fully.
Apr 11, 2013 | Pride Jazzy 1113 Power Chair
We're is the fuse on the Jet 3
I hope this helps:
The main circuit breaker is located on the front of the battery tray.
Main Circuit Breaker: The main circuit breaker is a safety feature built into your power chair. When the batteries and the motors are heavily strained (e.g., from excessive loads), the main circuit breaker trips to prevent damage to the motors and the electronics. If the circuit trips, allow your power chair to "rest" for approximately one minute. Next, push in the circuit breaker button, turn on the controller, and continue normal operation. If the main circuit breaker continues to trip repeat- edly, contact your authorized Pride Provider.
Here is a link to the owners manual too:
http://www.spinlife.com/files/pride_jet_3_ultra_om.pdf
Jan 31, 2013 | Health & Beauty
I was going down a level street. The chair "slammed" to a stop and powered off, and I cannot get it restarted. I freewheeled it into a cab and into my apartment. When I plugged it in, the...
hi check the battery connection and check for circuit breaker reset them.The main circuit breaker is located on the front of the battery tray.here is a link to download your owners manual.good luck and let me hear if you have further question.
Apr 30, 2011 | Jet 3 Ultra Power Chair
I have a Jazzy 1103 Ultra and the lights are all on like it should be but the chair will not move. I am in Mississippi visiting my daughter and would love someone to help me. Thanks!
It could be a few things.
It might be on freewheel. To solve this: 1. Turn the chair off. 2. Locate the freewheel lever just behind the drive wheel, and on top of the motor. 3. Push the lever inward to engage the motors. 4. Repeat steps 1 and 2 for the other side. 5. Turn the chair on and see if it works .
If not, it the circuit breaker might need to be reset because of heavy strain on the motors and batteries. To solve this: 1. Turn the chair off. 2. Find the circuit breaker on the front of the case, off to the right side (you will see a hole in the case) 3. Press the circuit breaker button. 4. Turn the chair on and see if it works.
if not, the battery may need to be disconnected and reconnected To do this 1. Turn the chair off 2. Release the friction lock lever under the seat. 3. Remove the seat. 4. Release the rear shroud fastener and the yellow fastener under the front shroud. 5. Remove the shroud. 6. Disconnect and reconnect the battery connector (the big plug) 7. Replace the shroud and seat. 8. Turn the chair on and see if it works.
If not, contact your provider.
Feb 23, 2011 | Pride Jazzy 1103 Ultra Indoor Power...
I have changed out the batteries and hand control on my Jazzy 1103 Ultra.but now the circuit breaker keeps tripping. Dee
Donna sounds like the wiring could be the problem. Did you change the batteries? Does the joystick light up when you turn the chair on? Or does the breaker pop when you try to turn the chair on? Give me as much info as you can as to what you are doing when the breaker pops thanks
Jan 31, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Wife's Jet 3 Ultra ; The Owners Manual Mentions a Reset Button, but does not indicate where it is located; they have it it Well Hid. We get more information when getting a new cell phone, as far as...
liv If you look under the front of the chair below the footrest and can see the lower front of the battery tray there is a 50amp circuit breaker on the front right side of the tray. The circuit breaker is mounted in the tray and I don't know if you have access to it without removing the seat and lower shroud. I have seen very few problems with this tripping unless there are battery issues or old motors drawing too much current. Just don't put the chair in a bind like up against an object and trying to make it go forward in full speed. You shouldn't have problems with a new chair with this tripping. Hope this helps you
Nov 19, 2010 | Jet 3 Ultra Power Chair
My chair just stopped working
You'll need to describe what you were doing when it quit, what kind of chair it is, etc. Right now, try resetting the circuit breaker and see if that helps, also, check to make sure the joystick is tightly plugged in and all other connections are frimly in place.
Jan 01, 2010 | Electric Mobility Invacare Pronto M41...
How do i reset the curcuit breaker on pront m51
The circuit breaker is located on the base of the chair. It is a small button about half the size of a dime, and it often has a flexible cover over it. If it is tripped, you will feel a click when you push it as it resets.
Jul 02, 2009 | Invacare Pronto M51 Power Wheelchair
Health & Beauty Logo
51 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
