Question about Balboa Instruments Duplex Digital Panel 2 Pump
Master spa legacy hot tub pumps stopped working after refilling it?
My legacy inspire hot tub was fine before i drained it, then after refilling it pump 1 sounded like it was trying to work and never turned on, pump 2 was working, so i reset the power and let it go through prime mode and still pump 1 was still not working but make the same noise and pump 2 still worked, i then left it on overnight and in the morning pump 1 and 2 stopped working completely, made no moter noise at all, so i reset the power and still nothing, the balboa vs series controller box makes a click sound but wont let pumps work at all, now i get 5 different codes dr, sns, hfl, dry and ice, so we bleed all the unions to remove any airlock, then reset power and still the same click sound, then we emty the tub and started over again and refilled it with hot water and cracked all the unions and its still the same click, so we found an article about reseting the memory on the balboa controller and turned off power used the j46 jumper turned power on then off again then took off jumper then powered on again the the lcd panel said a bunch of reset numbers and worked but still the pumps dont work? i think the balboa controller is not letting the pumps to even try priming or to even try to work it just clicks in the balboa? is there a reset for the sensors memory?? ive replaced the heater and sensors last year so its not broken i just dont understand pump 2 was working then stopped and both completly stopped working overnight?? can someone help!!!!!
Morgan hot tub
if no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
Jun 30, 2014 | Pool & Spa
We have a brand new Oasis Mohave spa and we wanted to run through a full cycle so we ran the tub for a week, no problems. then we drained and refilled the tub. Now we get dr or dy as error codes on the...
The dr error code is for "dry". Meaning that the control system is not sensing that water is flowing through the heating element.
With a new spa, and you just having drained it , it is probably an air locked pump.
What this means is that you have a small constant circulation pump with not much power, that got ait trapped in it when you drained. When you went to start back up, this "air lock" prevented the pump from fully priming.
Power down the spa at the breaker. Remove the filter element.Stick a garden hose with lots of pressure into the skimmer hole and open the hose valve to let water inject into the skimmer.
Restore power to the spa and check operation.
If after attempting this a few times you still get the code, there is an issue with your flowswitch, or with your circulation pump.
With a brand new spa, id like to hope that you just have an air lock.
Good luck
Mar 16, 2011 | Qca Spas Dream Series Dream Master Hot Tub...
Self priming hot tub pump won't prime
If you have had the tub empty and refilled this could be an air lock and all you may need to do is open the drain valve till you get water out of it. Good luck
Aug 31, 2010 | Qca Spas Paradise Hot Tub
QCA Dream Series, Mystic SPA. Drained, cleaned and re-filled. Following power restore (and 5 min or so prime cycle), the the pump runs continuously at low speed - it NEVER stops. Everything else works fine...
After refiling a spa, typicall the water is below 50 degrees F. Spas have a freeze protection in their programming so that when the water is that cold, the pumps run constantly to keep it from freezing. It will correct itself
Aug 09, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Hot tub pump flo-master hp suddenly wont start. it' one year old and was working perfectly. air side started to make a squealing noise the night before. draining hot tub to check volute to make sure motor...
The fault is most likely to be the condensor. They can and do fail at an early age.
You don't need to dismantle the pump, on the rear of the pump you'll find a slot on the motor shaft which can be turned with a screwdriver.
If you've only just reffiled the hot tub it could also be an airlock.
Regards,
Ian.
http://hottub.synthasite.com
Apr 18, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Water temp. reading isn't the the same as the actual water temp. hot tub says heater dry
If you have drained the spa latly and refilled you could have an air lock keeping the heater dry. Simpley find the drain valve under the spa and open it till it run's water. This should help the problem by letting the pressure even in the pipeing and flooding. Good luck.
Mar 10, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
1993 QCA Dream Master spa. Worked fine when drained last fall. Winterized with RV antifreeze. Just filled it and nothing happens. Heater light on solid for 30 seconds then starts flashing. Any ideas?
You probally have an air lock. All you need to do is find the drain valve and open it long enough to get water running full. This will flood the pipes and the spa should start. Good luck.
GFCI alarm stays on
Open your drain valve under the unit to break any air lock that will have gotten there when you drained the tub.
Sep 30, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Hot tub maintenance
there will be the same amount of basic maintenance on either spa. The difference will be in water chemistry. you definitely want an ozone generator on either spa. Both are awesome Mfg of spas. they both have been around since the 1980's
Ozone will keep the water cleaner, fresher smelling and reduce the total amount of traditional chemicals used in any hot tub.
There are many other solutions for taking care of water chemistry out there without using the traditional types.
some are all natural.
Jan 02, 2009 | Waterway Spa Pump & Hot Tub Pump 1.5"...
Balboa Instruments Duplex Digital Panel 2 Pump Logo
226 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Craig Butler
Craig Butler
Delage guy
Delage guy
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
