Question about Sole Fitness F63 Treadmill
I keep getting shocked- even on grounded floor. I now can not use controls on the right side (stop, speed up/down buttons)
    Top Expert:
  • Sole Fitness Master
  • 12,223 Answers
1) You must sure that you ground from the building or your home is o.k call to some electrician and fix it.
2) Maybe you have some ESD.WHEfN YOU walk from some floor, the resistance you get Electrostatic Electricity. you can buy some wristrap device for to download your electriciy to the machine via ground or frame.
God bless you
Posted on Dec 12, 2012
How o fix problem it just keep spinning on the floor
adjust the trim on the controller please watch some beginners videos. In this instance the problem is yaw which is left and right rotation on a helicopter it is affected by the speed of rotation of the tail rotor relative to the speed of main rotor and its gyroscopic effect. the floor cause weird flight effects on helicopters to get the trim precisely set it must be at least 4ft from the ground. but initially just get it to where it is controllable.
Feb 28, 2016 | Protocol Predator SB 3.5-Channel...
How to set the collar of a Petafe in ground fence.
1st you have to hold down the little black button on the collar, when it flashes at you release the button.
-Then press the button again and count the # of flashes.
-Keep pressing the button until you get it set to the desired flashes related to the setting you want to use.
-1 flash- audible correction with no shock.
-2 flashes audible correction with low shock.
-3 flashes audible correction with high shock.
It is always recommended to start with the low shock , if using shock setting, then move to higher setting if needed. Most larger dogs require a high shock setting, I have a yellow lab and use the high setting for him. Hope this helps.
Feb 23, 2015 | PetSafe Pet Safe In-Ground Stubborn Dog...
Hi! Suddenly, the left analog stick of my controller stopped working when i push it down or to the right. Do you think that it's a simple problem that i can solve it alone, by opening the controll
Depending on how old the controller is you may have simply overused it to the point that the connections are worn out. You would need to have some idea of what the soldered connections were supposed to look like inside after you opened it up. But be warned some of these controllers can be quite difficult to put back together. When you open it up make sure its face down (Buttons down) and keep it that way or all the buttons will fall out and it can be a pain to get them all back in where they need to be.
Mar 25, 2013 | Intec PlayStation 3 Turbo Shock III...
The left and right analog sticks on my intec controller r glitching so in a game i keep moveing left and aiming at the ground and it wont stop doing this even if i put the stuck in the oposite directi
needs a new one no doubt ,its damaged where its been dropped or just has a internal microprocessor fault maybe even a gravity balance sensor fault ,best thing here is recycle it and buy a nice healthy bicycle and get out a bit more .Never had this when i was i a kid ,only one channel TV which was on for 6 hrs a day ,Used to go out all day playing after school or during holidays ,go camping on our bikes and of course the regulation chasing girls,swimming in one of the local lakes not forgotting the annual punch up with the neighbouring schools which south east ham secondary held the title of the hardest nutters this side of tower bridge .More things we go up too but i cannot post illegal activities like bunking in the local cinamas
Apr 08, 2012 | Intec PlayStation 3 Turbo Shock III...
On high speeds vehichle shiverring sometimes. and on high speed braking also,and dragging to one side,tyre worning out on the outer side of left tyre.
Sounds like you need a brake job (for shuttering when stopping), new tires because of un-even wear, and possibly an alignment (so the next pair of tires don't wear out. While they are checking, they should check the shock absorbers (struts). This is a fairly old car and will likely need stuts and alignment.
If money is tight, look into some used tires. The brake job is not critical until you hear noise. Keep the speed down if you can't afford the alignment and struts.
-Please rate this answer
Good luck
Nov 20, 2009 | 1994 Hyundai Excel
Death wobble in front end
sounds like broke suspension parts, or maybe even a motor mount
Sep 15, 2009 | 2007 Dodge Ram 3500 Quad Cab Laramie
Directional buttons not working on both PS2 controllers
Try them on another playstation 2. If the same problem occurs, then the controllers probably or broken. Did it get banged around a lot? Is the cord ruptured or something?
Hopes this helps!
Jan 30, 2009 | Sony PS2 Dual Shock 2 Controller...
Directional buttons not working on both PS2 (controllers
the wire must have been.. twisted.. due to the way you keep it.. dont twist the wires around the controller to avoid this problem.. n.n
Sole Fitness F63 Treadmill Logo
120 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Brett Duxbury
Brett Duxbury
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
