Question about JVC HD-61Z585 61" Rear Projection HDTV-Ready Television
Replace ballast in hd 61Z585 - JVC HD-61Z585 61" Rear Projection HDTV-Ready Television
2 Suggested Answers
  • 111 Answers
SOURCE: I just replaced my JVC HD-61z585 lamp but the blue
check the cover you removed to be shure its back on correctly sounds like you have a safty switch open this is usely the case good luck
Posted on Feb 04, 2010
Change ballast
The ballast is directly connected to the wires that go to the lamp socket. Disconnect all the wires form the board and then remove the screws that secure it . You might check www.shopjimmy.com for the correct replacement.
Oct 03, 2013 | NEC Np1150 Lcd Digital Video Projector Hd...
Replaced lamp in my HD 61Z575, but when I turn on my TV, nothing happens (no fan noise). After ~10 seconds, the Light LED starts blinking rapidly. Could it possibly be the brand new lamp? Ballast?
The old lamp was in there before the fan work?U replaced the lamp u put the door back on did u make sure the safety latch is off and tightly closed with the the lamp door.The continue blinking LED light does it make alot of clicking noises too.Yes,then the Ballast board it is dead too.The Ballast board only job are to help the projection lamp to ignite to work.
Aug 27, 2011 | JVC HD-61Z575 61" Rear Projection...
Lost remote and cannot shut off CC on my HD-61Z585.
Try website like Remotes.com to buy the original or very close to the original remote.
Apr 16, 2011 | Televison & Video
Have replaced the bulb in my jvc 61z585 hd-ila rear projection tv. It worked find for two hours. We turned it off for several hours and when we turned it back on we got a picture for ten seconds, then...
Probally the Ballast board have problems,if the safety switch problems,u should not have a picture at all in the first place.Now,the tv turn on?U hearing alot of clicking?Yes,the Ballast board is dead,it not igniting the projection lamp anymore.
Oct 11, 2010 | JVC HD-61Z585 61" Rear Projection...
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
I just replaced my JVC HD-61z585 lamp but the blue power light and red lamp light just contine to flash on and off. The bulb is definately good.
Feb 04, 2010 | JVC HD-61Z585 61" Rear Projection...
JVC HD61Z585 loud pop picture went blank and will not even turn on
sounds as if your lamp cracked, order a new one onlie-fairly inexpensive and install according to the lamp instuctions, check to see if anything was on or in contact with the lamp. sometimes they just pop other times something came into contact with it
Jan 17, 2010 | JVC HD-61Z585 61" Rear Projection...
You can hear the sound but you cant see picture
This sounds like the Flyback Power Coinverter has gone out! ( a 70.00 Part! but this fix must be done by a pro! This is a common problem with these Tvs
Please rate my responce to your question.
Thank you!
Jan 07, 2009 | JVC HD-61Z585 61" Rear Projection...
JVC HD-61Z585 61" Rear Projection HDTV-Ready Television Logo
23 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
