Question about Kitchen Ranges
I have a maytag performa electric range rs-1. The clock flashes and does not stop.
O/w sees to be working. Any ideas?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 10, 2012
SOURCE: Clock on a GE electric range is buzzing - how to disconnect it
Turn off power to range first!!!
You'll have to remove the back of the panel in which the clock is installed to access the back of the clock. There will be two wires attached to the clock. Just pulling one of these wires off will stop the clock.
I would suggest, however, that you pull both wires off, put electrical tape on the ends of the connectors, and tuck them out of the way somewhere around the clock.
Posted on May 03, 2009
SOURCE: Frigidaire Electric flat top Range
My range will not hold the heat for either the convection or regular heat. the model number is CGLEF385AS2
Posted on Dec 24, 2008
SOURCE: No heat Maytag smoothtop range MERH752BAB
It would have to be under warranty if this happened after only 1 week. I would contact the manufacturer.
Posted on Oct 06, 2007
dmftrucker
  • 1922 Answers
SOURCE: Maytag Performa Electric Range (PER1510) tripped circuit breaker.
first, un-plug unit and remove rear access cover,it could be a wire with bad insulation that has shorted to the body of the unit,could be an oven/broiler element,could be one of your feed lines to the unit shorted to ground,does it trip brkr w/o anything turned on???you can also isolate the problem that way.good luck
Posted on Aug 23, 2009
jsrock516
  • 5911 Answers
SOURCE: How do I set the clock on a Maytag gas range, I
If your range is the same model as you posted this question under, the time is set by pressing the "CLOCK" button. The word "TIME" will begin to flash on the display. Using the keypad, press the corresponding numbers of the current time.
NOTE: If the oven has been programmed, or is in use, you cannot change the time. Cancel all other functions before attempting to set the clock.
If the model number is not correct, please post back with your correct information so that I may be able to provide you with better assistance.
Posted on Nov 01, 2009
My Maytag Performa glass top stove does not work. The oven doesn't heat up but the stove top works fine. I checked my fuse box downstairs and it is fine. I checked the stove to see if there were any...
Dear Gina,
It should be one of 3 things.
1) The element has burned out, or
2) The socket the element plugs into has failed, or
3) the wires hooked to the socket have toasted.
Someone must take the stove apart to see.
God bless your efforts.
Oct 26, 2017 | Maytag PER5710 Performa Electric Kitchen...
Lost our power now on our range we have clock working timer working and burners working. Try to put oven on & the lock button lights up. Try to put broiler on & lock button lights up. Nothing goes...
Ive had the same problem after losing power. I heard to unplug and plug back in the oven and it should work- didnt work for me. Then Ive heard to replace the control board. I found it for $141 on appliancepartspros.com I havent purchased it yet, still searching to see if this is really the problem
Feb 20, 2011 | Maytag PER5710 Performa Electric Kitchen...
F9 error
door latch check door lock circuit or replace clock assembly
Oct 03, 2010 | Maytag PER5705 Performa Electric Kitchen...
Elements and light in stove work but clock and stove do
The issue would have to be in the clock or the power wire going to the clock.
The clock controls the power to the oven elements and there are no fuses or other devices to control the elements.
May 20, 2010 | Maytag PER5710 Performa Electric Kitchen...
Maytag performa model per4311acw
The oven's element may be defective. Take a look at the heating element and look to see if there are any unusual 'marks' on the element.
It is a simple fix.
Unplug the stove, unscrew the screws holding the element to the back of the stove, gently pull the element a few inches towards you, pop off the connectors, take the element out and take with you to the store. It is a good idea to take the model nukber with yoy when you go to the store.
To replace, just reverse the steps above.
Sep 07, 2009 | Maytag PER5710 Performa Electric Kitchen...
Maytag Performa Electric Range (PER1510) tripped circuit breaker when immediately following turning the oven on. There was a mild electric burn smell from behind the range. I have left the circuit...
Aug 20, 2009 | Maytag PER5710 Performa Electric Kitchen...
Maytag MER5770AAW Oven
f1 is a bad range control/ touchpad, here the part number for a white clock for model number MER5770aww 74008106 approx 150 bucks
Apr 08, 2008 | Maytag MER5770 Electric Kitchen Range
Kitchen Ranges Logo
64 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
