Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have no spark on my husqvarna 240 chainsaw i have tried disconecting the kill switch and fiting a new spark plug but still no spark
Could it be the coil pack and lead or magnets in the fly wheel , where is the best place for cheap parts and how to test a coil pack ,
  • Husqvarna Master
  • 1,807 Answers
Sounds like an ignition module/coil problem.
Posted on Feb 05, 2013
dontbother10
  • 2220 Answers
SOURCE: Husqvarna 235 not an e model, Will not start, no spark to plug.
Hello David; We are prohibited from contacting you directly. It sounds as though the ignition module is defective but it could also be a defective switch or interconnecting wire, try this please, it tests the entire system.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
In the USA a duplicate receipt can usually be obtained from the merchant, there too? If not what about your credit card receipt?
I would try my local Husky dealer once the problem is isolated.
Dealer Locater.
http://www.husqvarna.com/uk/homeowner/dealers/dealer-locator/
An IPL (Illustrated parts listing) can be found here:
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 25, 2010
Testimonial: "Thank you for your help."
  • 3 Answers
SOURCE: Chainsaw Service manual for Husqvarna in New Zealand
I USED GOOGLE SEARCH THEN JUST DOWNLOADED IT. I GOT THE ONE FOR MODEL 50, 50 SPECIAL AND 51. GOOD LUCK!!!
Posted on Jan 25, 2009
  • 97 Answers
SOURCE: no spark
Remove cover & unplug shutoff wir from coil and replace cover & check for spark,if you have spark repair shorted wire or switch.If no spark remove coil and have checked.
Posted on Mar 14, 2009
SOURCE: Husqvarna ranger 55 chainsaw starts but quits
I too have a rancher 55 and had what sounds like the same problem this week. It would start fine but run for only a few seconds at a time. I took it all apart today and found the problem - a cracked fuel line. In the places where I could see the hose it looked fine, but it wasn't until I removed the fuel tank that I found the crack...right where it exits the tank and then goes thru the housing above it. You don't need to remove the tank to replace the hose but it is easier that way. You do have to push it thru a grommet at the top of the tank. I read some other posts about checking the tank vent to see that it's not plugged up. Mine was ok so I knew it had to be something else. The vent is in a hole about the size of a pencil and is recessed about an inch into the tank on the upper right side. Its partially covered by a plastic cap that's part of the vibration damper, which can be removed to gain access to the vent. The vent tube can then be pushed out from inside the tank with the use of long needle nose pliers, but be gentle. I just loosened it then pushed it out with a finger. I put it all back together with a new hose and its running like new again!
Posted on May 31, 2009
dontbother10
  • 2220 Answers
SOURCE: 353 husqvarna chainsaw, floods during start process
Husqvarna says the initial carburetor needle valve settings are from lightly seated 1 turn CCW for both H & L.
Your Operator's Manual can be downloaded here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140204-95.pdf
Once flooded Huskys are very hard to start. This works well on my 359.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close - sets fast idle) pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually the next pull)
Warm:
  3. Pull (close - sets fast idle) choke, - Don’t pull with choke closed.
  4. Push (open - fast idle maintained) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Posted on Oct 03, 2009
How to test coil on husqvarna 288
take spark plug out hold it a millimeter away from head and it should spark or if you like getting shocked then hold the spark plug between your fingers i would not do that because it can kill you
Aug 16, 2014 | Husqvarna Garden
Husqvarna 235 chainsaw wont run
Check fuel supply, proper plug (resistor) compression 120 to 145 lbs. If saw will not run have the ignition tested with a 3-point spark tester.
Apr 30, 2014 | Husqvarna 232 235 240 Cylinder Pn...
How do you check the spark on a Husqvarna 240 chainsaw?
Buy yourself a spark tester from the local chainsaw dealer, these will clip to the cylinder to create an earth, the plug cap fits to the end, it will have a large gap to load the ignition unit, if there is a spark when the engine is cranked the unit is ok.
Aug 08, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My husqvarna 240 e has no spark i disconected the shutoff switch no difference
If there is still no spark after removing the switch wire then it will be a new ignition unit required, part no. 545199901, check the web a supplier. Set the air gap between the module and the flywheel magnets at 0.3mm
Jan 11, 2013 | Garden
Brand new husqvarna 235 chainsaw will not start
is the kill switch on?check the spark plug it could have had the wire fall off in shipping
May 24, 2012 | Husqvarna Forest & Garden #952802239 235E...
Husqvarna 240 want start at all
Sounds like the ignition module or spark plug. The ignition module is what controls the spark plug that gives your saw the firing capabilities. Before you purchase one of those, replace the spark plug and see if that works. The 240 is a newer husqvarna; so I am skeptical to say it is the ignition module. However, any new product can have a bad part on it.
Your saw may have gotten flooded and won't start. Make sure your gas mixture is 50/50 gas to mixing oil. Always use fresh gas. If you make up gas and don't use a whole gallon at a time, put some fuel stabilizer in the mixture; so it will still be fresh the next time you use it.
Oct 28, 2010 | Husqvarna Chain Saw 18" 450 Model...
Husqvarna chainsaw no spark
Ignition systems on newer saws are a solid state all-in-one package. Disconnect the kill switch wire from the ignition pack to make sure that the switch isn't broken. Use a fresh spark plug to check spark with. An old one that is black inside is likely shorted. If still no spark, replace the ignition module. Use a piece of card stock to set the flywheel magnets to module gap, then tighten screws
Sep 11, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 359 EPA - no spark. I replaced the spark plug. is there a reset button? What do I check?
check the kill switch button wire see if it broke off that happened to mine an dcaused a no start and if the air filter is not clen it won't run eaither.
Jun 27, 2009 | Husqvarna Chain Saw 20" Bar
No spark
Mar 14, 2009 | Husqvarna Garden
455 Husqvarna chainsaw will not run
Remove exhaust , check piston make shore you have a chance,
check ex screen isn't blocked.
check choke isn't stuck on,and half throttle is working. get back to me from there.cheers
Dec 22, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
1,361 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
