Question about Singer 4423 Sewing Machine
Is there a blanket stitch on the 4423 singer sewing machine?
  • Singer Master
  • 7,365 Answers
Here is a free manual,, so you can check and see if it has the stitch
http://www.singerco.com/uploads/download/1248_4423_heavy-duty_esf.pdf
Posted on Dec 10, 2012
  • 140 Answers
SOURCE: threading problem on Singer Sewing machine Inspiration 4206
This can be caused by incorrect bobbin tension or the bobbin is in backwards. Take out the bobbin and put it in according to the instructions for your Singer. If you still have the same problem try tightening the bobbin tension. Please ask if you have any questions.
Posted on Dec 30, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
bunnydawg
  • 5158 Answers
SOURCE: how to do all the stitches on my Singer fm-22-c
i'm uncertain if you have the manual so here it is
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/7442-_M
http://www.scribd.com/doc/3713782/Singer-7442-Sewing-Machine-Manual
it isn't simple to download the manuals but you shouldn't have too much trouble getting them either... be that as it may if you cannot download them from at least one of the pages i sent let me know
Robert
Please take a moment to rate this solution thanks
Posted on May 24, 2009
bargainbox
  • 1388 Answers
SOURCE: singer 237 stitches loose on bottom of fabric
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Sep 02, 2009
Singer 4423 how to sew a bar tack on denim?
Just set the stitch width selector to the width you want the bar tack and set the stitch length to zero. It will stitch in place until you stop or change the stitch settings.
Oct 24, 2017 | Singer Sewing Machines
Singer 4423- brand new. Followed youtube tutorial, lowered feed dogs (buttonhole setting) with no problem; now unable to raise them. Followed suggestions to another user with the same problem- no luck
go google and type in --user manual for singer sewing machine model 4423---and download the pdf version
you could always talk to the singer shop for advice or join a sewing club to get expert tips to get the best out of your machine
Mar 22, 2017 | Singer Sewing Machines
I just got a new singer 4423. it stitches just fine for a while, then the top thread becomes a loopy knot underneath, snags, then returns to regular stitch. my old 4423 did the same but not as bad.
A couple of things you might want to check. Did you know that when you thread ANY sewing machine, your MUST be raised? That is the only time the upper tension disks are spread to accept the thread when you thread the machine. If you don't do that, there's no tension on the upper thread, and that's the kind of thing that happens.
There are are other causes for that. Run you finger over the needle plate to see if there are any rough spots that can catch the thread, and do the same thing on the bobbin case. If there are, use an Emory board to file them smooth.
Mar 04, 2017 | Singer 4423 Sewing Machine
Hi I'm new to sewing! Does my singer have a blanket stitch
Your machine is a beginner model with only 8 stitches. Looking at the photo of the machine, it does not appear to have a blanket stitch.
Singer 1507 Sewing Machine
Usually, only more advanced (and expensive) machines with more stitches will have the blanket stitch.
Nov 08, 2015 | Singer 1507
Zigzag stitch not working
Paul, please give some more info on lubricating needle bar frame and linkage. Because I do have this problem
Jun 30, 2014 | Singer 4423 Sewing Machine
Can singer 4423 use twin needle
did you get a manual with it, it will tell.
singer has a free pdf download here's the link
Aug 12, 2012 | Singer 4423 Sewing Machine
How can I fix the needle postions on my singer 4423
Sounds like a part is broken... but you can test this by grasping the needle bar and pulling to the right as you set it to Center with the dial. If it doesn't move that means the mechanism that does this for you is broken. Take it in for service.
Aug 04, 2012 | Singer 4423 Sewing Machine
FIND MANUAL FOR SINGER MODEL 1748
Go to the singer website--free pdf download
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 1748) & click search
Jul 27, 2012 | Singer Sewing Machines
Model 4423 singer stuck in reverse
Solution: Turn off machine. Turn stitch dial until you hear click on each stitch shown on dial. Set to straight stitch then and set stitch width to 6. try machine again being careful to put light force on the foot pedal so your not going full throttle. This is how I "de-confused" my Singer Heavy Duty 4423 when it got stuck on reverse. Hope this helps!
Jimmy
Mar 20, 2012 | Singer Sewing Machines
Brand new machine. Heavy Duty Singer 4423 I sew ripstop tarps including a double layer of grosgrain edging. After one tarp the machine has begun to squeak horribly with each stitch. Why? What can I do as...
I would suggest that the words "heavy duty" applied to a machine sold for less than $150 is probably taking a little bit of artistic licence.
Grosgrain edging is very stiff so you will probably need at least a 100 size needle for this and they may well go blunt pretty quickly. This could be the squeaking noise, needles will "pop" and squeak if they are blunt. Change the needle and see if it stops.
I would suggest that if you are doing straight stitching in large volumes for commercial purposes, this is not the right machine, you need something like a Singer 20U industrial machine, a good workhorse which will do straight and zig zag stitches.
I have one of these with a 3/4 hp motor in a table and it is so strong, great for sewing tents, horse blankets etc. We used it for attaching vinyl to 1/2" foam for ride-on tractor seats, something it did really well. Different needle system to domestic machines and can sew heavier gauge thread too.
Sorry, this probably isn't what you wanted to hear about your new machine. Try changing the needle and see if it stops the squeaks. But you may need to reconsider your choice of machine.
Aug 30, 2011 | Singer 4423 Sewing Machine
Singer 4423 Sewing Machine Logo
150 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
