Question about Smeg Refrigerators
Pierced hole in Tundra refrigerator/freezer evaporator. Is it fixable?
Part #753500096. T-EVAP18/13. EVAPORATOR T18/13S
4 Suggested Answers
freetek
  • 5568 Answers
SOURCE: hole in freezer of haier refrigerator
The refrigerant used since ~ 10 years is no more dangerous than the one previously used and it is even doubtful that the newer stuff is any better for the ozone layer.
The original coolant could be inhaled without injury as long as one didnt suffocate from a lack of oxygen.
The repair may not be cheap since it will entail the removal and replacement of the damaged coil.
This will require some specialized welding to install.
Using a normal table-top or floor-standing fan to circulate ambient air through the refrigerator with the door(s) open is a safe and fast method for defrosting units that do not automatically defrost.
Just make sure you have some absorbant material in the bottom to avoid water running out of the unit.
Poking the coils with sharp objects can result in the problem you now have or fracture hidden joints that will allow the gas to escape.
Posted on Jul 19, 2008
SOURCE: Pierced hole in smeg freezer is it fixable
The only repair for this is to replace the evaporator, this requires serious technical skill in
refrigeration,
Usually this type of repair costs more than you will want to spend, it is not
covered by any warranty I know of.
Most techs will not want to attempt a repair of this nature due to the near impossibility
of getting all the moisture out of the system, and the very real likelihood of a service call back.
In future Only use hot water to assist in defrosting, or let defrost naturally before putting back into service. Never use any device to pry or poke at the ice.
Posted on Jan 03, 2009
  • 306 Answers
SOURCE: trying to find hole below evaporator in freezer
The aluminum is the collection tray that the water drains down and goes down the tube to pan under fridge.
With all the ice you are talking about it will be hard to see. You might need to get a towel and mop up excess water as you go.
Get a shop vac if you have one and put the hose in the end that blows instead of vacuum's the warm air will aid in defrosting the ice out of coils. Other wise use a hair dryer. The drain is in center right below the coils. When you get to where you are closer to the as you say aluminum you will notice a small diameter hole say just smaller then a penny in size. Now get some table salt and put approx. 2 tea spoons on the top of hole. this will melt the ice much faster and clear out the drain tube in minutes. Then just clear out with some water and you can monitor the pan under the fridge to see how much water comes out. Hope this helps ken
Posted on Jan 18, 2009
Location of bullet piercing valve on sanyo sr4433s compact refrigerator
Does the unit have a manufactures process stub on the compressor casing. That is where I put piercing valves to add refrigerant. Remember that EPA does not allow piercing valves to remain on system and the hole it forms has to be brazed shut. So if it does have a process stub place the peircing valve close enough to the end so you have enough stub to pinch off to braze thehole shut.
If there is no process stub, then install piercing valve in a convenient location in the suction piping and pierce the line. Remove the refrigerant and install a "tee". On one leg of the "tee" install a schreader valve pressure tap and rebraze the joints. Perform and pressure and vacuum test to check for leaks and weigh in the correct amount of refrigerant. Once your proficient at this procedure, it should take about 60 to 90 minutes depending on obstructions around compressor.
Just a comment, low air flow on evaporator give that same indications as a low charge. Make sure the evaporator fan is working and you have good air flow through evaporator section.
Hope this helps
Dec 09, 2014 | Sanyo Refrigerators
How can i fix my freezer because iv pierced a hole in the wall?
You can't fix it if the hole in the wall has pierced the refrigeration tubing inside
Apr 26, 2014 | Refrigerators
Moisture in the refrigerator
What in blazes is a " wet wall evaporator " ?
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
May 21, 2010 | Kenmore 64802 Top Freezer Refrigerator
Hole burning through floor of Freezer
Your refrigerator is likely a frost free model. There is a heating element that runs around the freezer compartment. It is probably the heating element that is causing the original damage to progress.
Most fridges have a way to turn off the frost free part, usually via the timer or or easy as pulling the fuse for the circuit. Pull the fridge out, climb behind it, unplug fridge, and remove access cover, if equipped. Look for a wiring diagram. It will tell you where you need to disable the frost free at.
If you can't disable the frost free, then replace fridge now. the acrid smoke you smell is toxic, and is detrimental to food, as well as to human life. Stop using the fridge, or disable frost free.
Nov 02, 2009 | Magic Chef CTB1922 Top Freezer...
I've punctured a hole in the lining of the freezer compartment of our fridge freezer. There's now a small hole which has been slowly leaking a fluid which smells a bit like antifreeze. The freezer has been...
It sounds like you have punctured the evaporator coil and it is leaking refridgerant.
That would certainly cause the unit to be low on refridgerant which would cause it to start warming up, and becoming louder. It would also explain the smell.
If the unit is fairly new it *may be worth repairing, You will likely need a new coil.
Expect costs in the 300 to 500 range.
I reccomend getting a secondary place to store the food, and unplugging the unit emediatly if you want to have it repaired.
The reason for that is because the compressor is likely undamaged at this point. but if it runs on empty it will soon fail and then you can double the repair price or more.
Aug 26, 2009 | Haier ESR042PWW 4.2 Cubic Foot...
Fridge autodefrosting but condensation not draining away and evaporating causing a build up of water in bottom of fridge section
The problem you are experiencing is normally a blocked evaporator drain line. Whether you have a side by side model or a top mount freezer the solution is relatively the same. Most top mount freezer models have a rear evaporator panel covering the aluminum evaporator coils. There are some instances where the evaporator coils are on the floor. These instructions are for top mount freezers where the rear freezer panel covers the evaporator coils. First of all, if there is an ice maker in your unit, this will have to be removed. Normally there are two screws which can be loosened and the body of the ice maker can be lifted off the screws leaving only a plug in harness to disconnect. Remove the harness either from the plug at the left wall or rear of the freezer and set it to the side. Next, remove all the screws securing the rear panel. Remove the rear panel exposing the aluminum evaporator coils. Be careful not to damage these coils as they contain the freon that cools your refrigerator. If you look closely underneath these coils, there will be ice from frozen defrosted water. Using a hair dryer and not a heat gun, melt all the ice and sop up the water with a towel. Now you will see a drain hole which is normally still blocked with ice. Pour hot water in this hole and sop it up. Keep doing this until you pour water down the hole and it drains into the evaporator drain pan either under or behind your refrigerator. Once you have unblocked this drain line, reassemble and plug the refrigerator back in. Set all controls to the middle settings and within 24 hours, your unit will be functioning correctly once again. If you need further assistance, we are here. Eric Campion
Feb 27, 2009 | Miele KFN8762SDED Bottom Freezer...
refrigeration,
Jan 03, 2009 | Smeg Refrigerators
Hissing freezer
Hi criago
I am very sorry to say that you have pierced the coolant tubing, the hiss you here is the coolant gas escaping. Your Fridge Freezer may be unrepairable because it is very hard to get into the area concerned.
Sorry to break the news to you.
Jun 15, 2008 | GE Profile Arctica Stainless Steel Top...
Sanyo SR-4433S
not fixable,you put a hole in evaporator coil,next time if you need to go fast use a hair dryer,thanks-mike
May 28, 2008 | Sanyo 4.4 cu. ft Counter-High...
Refrigerators Logo
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
