Question about Chevrolet 1972 Blue & White Chevy Pickup Truck Diecast Model Truck
Need wiring schematic showing fuel tank to gauge in 1972 chev trk
I need a wiring diagram to detail where the brown wire from the gas tank sender behind the seat goes on my 1972 Chevy 4x4. I also need to know what wire feeds the gauge.
  • 3 Answers
There should be a wire that connects to the gas tank sending unit and maybe another wire connected to a spade terminal that could be screwed down to the in-tank sending unit. The brown wire from your gas tank sending unit goes to the back of the dash guage. All the gas tank sending unit does is give a "ground" signal to the dash guage. Whatever you do, do not connect the brown wire to a positive 12 volt wire as sending 12 volts through the gas tank sender will explode the gas tank! Take a look at this website and it will all clear up for you.
http://auto.howstuffworks.com/fuel-gauge1.htm
You did not say if your dash guage is wires with a plug-in or single wires connecting it. If what i've given you here is not enough to fix the whole problem then respond back with how does the wires connect to the back of the guage. Good Luck!
Posted on Jan 15, 2009
Do I need to take out and and then reinsert the fuel pump fuse to reset the fuel gauge
That won't affect the fuel gauge. Different circuits, entirely. Any issue with the fuel gauge is between the gauge on the dash, a little wiring to the gas tank, and the sender unit inside the tank. In most cases, the problem turns out to be the sending unit inside the tank.
To check the gauge itself for working, you can ground the fuel gauge wire at the gas tank connector, and watch for movement on the gauge, with the key in ON. You take the connector off at the gas tank, find the wire for the fuel level sender (or gauge), and touch it to a good ground- a metal piece on the car frame. If gauge is good, the needle will move either to full or to empty, but you can see the needle move to a new point, when you (temporarily, only temporarily) ground the fuel gauge wire. The key in the switch must be in on. If this causes the needle to move, then the dash gauge is good, and the problem is the sender unit in the tank. This unit has a variable resistor, not too expensive. The fun is getting to it.
Nov 30, 2016 | Cars & Trucks
Proton satria neo 007,fuel guage problem,it will show gas level and then suddelnly the guage will go down and stay there showing no gas and the petrol light dont even work
You need to determine if the sender is bad or the gauge is. If you can get to the signal wire at the fuel tank for the gauge (this goes inside tank to sender that provides a variable ground circuit) ground that wire briefly to see if dash gauge rises. If so, part inside tank is bad. If not, gauge or some part of its wiring circuit is bad.
Oct 18, 2016 | Proton Cars & Trucks
Gas gauge won't work and it has a full tank of gas. Is there a fuse I can change.
There might be but it is unlikely a fuel gauge is fused alone; usually if it is a fuse other things will stop working too but I suggest you are guided in this matter by your car handbook.
Problem is probably wiring and in particular the grounding of the fuel tank sender unit. It could be a faulty sender but they are usually quite reliable.
Test by disconnecting the wire from the sender unit at the fuel tank and short to a good ground and the gauge should read full. If the gauge wire is in a block with other wires it will be necessary to positively identify the gauge wire before testing.
If the gauge reads refit the wire and duplicate the ground wire to a known good ground. If the gauge still reads the fault is a bad ground to the tank sender unit and if it doesn't the sender unit itself is probably faulty.
If grounding the gauge wire does not produce a reading the fault is the wiring to the tank, the supply to the gauge or a problem with the gauge itself.
Feb 06, 2015 | Cars & Trucks
My gas gauge and my oil gauge to my 1990 ramchargerdoes not work?
replace the oil pressure sender first its cheep to buy
the fuel gauge can be hard to fix you need to get a diagram and ground the gauge wire if the fuel lvl gos to full then its the sender in the tank and thats a tank down repair sugjest replacing fuel pump whial in there
Mar 12, 2014 | 1990 Dodge Ramcharger
On a 1972 Chevy K5 Blazer, the tan wire from the gas sending goes to the back of the fuel gauge I understand. Where on the back of the fuel guage exactly does it go? Does any wire go to fuse block? W
Power should goto the gauge, second wire from the gauge goes to the sender unit on the tank. If there's any other terminals on the gauge or the tank they will be grounds
Apr 23, 2017 | Cars & Trucks
1982 chey van , none of the dash gauges work , have changed out gas tank sending unit , brown wire looks good , fus looks good
If none of the gauges work, there is a power problem.
The gas tank sender grounds the fuel gauge and the temp sender on the engine block grounds the temp gauge.
Could be a wiring harness issue or a problem with the printed circuit board too.
Jun 30, 2012 | Cars & Trucks
Fuel gauge alwaya read full
The wire between the dash and the fuel tank is connected to ground somewhere. there is a control that fails too but if the control failed the temperture gauge also won't work. The wire can get in troble inside the tank too as if someone tried to steal the gas with a hose. if you can disconnect the connector ( wireing ) at the fuel tank and turn the key on and the gauge goes to empty you know the troble is inside the tank and the pump sender unit will need to be removed from the tank to correct the problem or even the gauge unit replaced.70198425.jpg
Feb 28, 2011 | 1995 Ford Explorer
My gas gauge is always reading full why 1999 cavalier
Hi
The most likely cause is that the fuel sender in the tank is faulty or that the wiring to the sender is bad.
Less common causes are a faulty fuel guage or circuit in the instrument panel.
Test the sender as it is the most likely cause and easiest to eliminate.
First inspect all connections that are readily visible to insure that they are secure & free from dirt or corrosion.
Disconnect the fuel tank sender wire at the tank. The guage should continue to show full (ignition on). Ground the wire from the sending unit at the fuel tank to any good grounding point on the car. The gauge should go to "Empty". If it does this is a strong indicator that the sending unit is at fault.
Hope this helps. Please do rate my answer. Thanks
Sep 02, 2009 | 1999 Chevrolet Cavalier
Fuel gauge shows quarter tank then the low fuel light comes on showing eighth of tank
Most likely it's one or BOTH fuel level sender units in the fuel tank (there are two float units, one with the fuel pump). Located under the rear pass seats on the driver's side and another on passenger side (seats need to be moved out of the way to get to them - four 14mm bolts with each seat).
You'll see the 8mm screws holding the units in place.
Wiring Diagram:
8047594.jpg In this diagram, the sender units are wired in series (one or both may be causing your problem). The sender units are simple potentiometers (rheostats) & their combined resistance tell the microcomputer in the instrument cluster what the fuel level is, then It tells the fuel gauge where to put the needle. Inspect your wiring connectors to these sender units first. These sender units can be ordered/purchased at a Hyudai Parts Department. I don't believe there are any after-market units available - they are a dealer item.
Jun 09, 2009 | 2004 Hyundai Santa Fe
Chevrolet 1972 Blue & White Chevy Pickup Truck Diecast Model Truck Logo
2,804 people viewed this question
Top Chevrolet Toys Experts
Electric Dime
Electric Dime
Maxumized
jogp98
Are you a Chevrolet Toy Expert? Answer questions, earn points and help others
