Question about Philips 50P8341 50" Rear Projection Television
Philips 50p8341a - 1) Periodic flashing, 2) Haze over picture
I've had this Tv for 5 or so years and it's always had this haze over it. Not enough to disturb the picture but it gives it this bright, glowing effect. Kind of like when cameramen put a screen over their lense so everything has a glowing angelic feel so as to cover imperfections in the actor's faces. Hard to describe I guess. But it's always had it and it was ok but as time has gone on, I've decided to inquire about it. I know it's not HD but I'd at least like it to have the clarity of my small tvs. Not staticky or anything, it's a clean picture but i guess kind of washed out.
The second issue is that periodically when something bright or explosive happens on a program, the tv flashes. Not off and on but a split second flash of brightness kind of like a camera flash but not as pronounced. In any case, during that extremely brief flash split second all you are seeing is the flash, not the program on tv. My friends didnt really notice it until I pointed it out to them. This too has been there since day one. My wife bought it as an opened gift for Christmas from Walmart.
  • Anonymous Jan 25, 2009
    I also have the same problem since day one. I too purchased it at walmart.
    Problem Solver:
  • 7 Answers
Maybe you need open the tv the upper case and need to clean the mirror and the lens
Posted on Jan 27, 2009
There is like haze spot
LCD Panel White Spot Cleaning Technique - YouTube
? 4:13
https://www.youtube.com/watch?v=0OzjLMKFYk8
Jun 9, 2012 - Uploaded by joegingCA
Simple Technical procedure on how to remove a white spotproblem of an LCD Panel. ... Don't like this video? ... How to remove liquid spots from LCD screen - Duration: 5:16. ... Building a liquid crystal display (LCD) - Duration: 13:49. ... 2:18:17. Samsung/Mitsubishi/Toshiba DLP TV Repair - Black & White ...Missing: 170s4fb ‎haze
LCD TV - Problem with white glow seeping in from edges - MyBroadband
mybroadband.co.za/.../349324-LCD-TV-Problem-with-w...
MyBroadband
Jul 12, 2011 - 15 posts - ‎9 authors
Results 1 to 15 of 17 ... After googling it seems this is quite a common problem withLCD panels, though I .... Earlier this year I read that Philips have sold off their LCD TV... Yeah, something like that, unless demo stock is treated differently? ... bleeding from the edges as well as in the middle of the display.Missing: 170s4fb
How to Fix LCD Monitor Ghost images - MadeByMark.com
Jan 14, 2016 | Philips 170S4FB 17" LCD Monitor
White haze and very unclear picture. Seems the
Search for "coolant change projection tv", there are several good links including where to buy the coolant. I did mine yesterday and it's like having a new TV again, all for about $20 and 3 hours time.
Nov 11, 2009 | Philips 43PP9202 43" Rear Projection...
Black haze covering picture after "pop" noise
That's a very old model to be only 1 year old?
It needs a Z-Sustain PCB anyway.
Thanks.
Sep 08, 2009 | LG DU-50PZ60 50 in. Plasma Television
White haze on projection
If your TV is a philips magnavox its most likely the CRT fluid is cloudy and should be replaced.
Got to www.TvRepairKits.com for a kit + instructions.
Jun 20, 2009 | Televison & Video
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Blue Haze comes out the left side of screen top to bottom about 3 or 4 inches.
What needs to happen is three specific voltages need to be adjusted on the power supply, You need to set the Ve voltage to 100v, the Vset voltage to 188V and the Vs voltage to 190v. Monitor the set for 24 hours, if haze doesn't come back the unit is considered repaired. If haze returns, then the problem is with the panel itself and wouldn't be worth it to replace because it will cost more than the tv cost you originally
May 21, 2008 | Philips 42PF9630A 42 in. Plasma Television
Hitachi 60 in. 60V715 Yellow Haze
I would first check and see if any software updates are out on this set, you can call Hitachi, if not that then it could be the engine assemble having problems.
Jan 02, 2008 | Televison & Video
Yellow Haze
What model of set do you have?
Dec 29, 2007 | Televison & Video
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
129 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
