Question about Hitachi 51S500 51" Rear Projection HDTV-Ready Television
Magic focus not working colors not aligning
The magic focus button is not working right is there a way to auto focus it as the greens and reds are not aligned on the left third of the TV
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
If Magic focus will not correct it (it is the limited auto convergence for this set) both the convergence chips which should be stk392-110 or 150 will have to be replaced, convergence is done with the original remote with set in the Decam ( tech convergence mode).
The parts are not that expensive and TVrpairparts.com sells kits with instructions for these sets by model number.
Posted on Dec 10, 2012
SD Tech
  • 14553 Answers
SOURCE: Colors are not aligned Magic focus ?
The magic focus will stop if there is a bad sensor and or a problem in the convergence circuit.
This set uses two STK-392-110 convergence chips--both along with any of the resistors that protect them need to be replaced and the set adjusted--I have repaired hundreds of these sets----
Confirm model number----and if you go into the customer menu and either red or blue will not move in any or some direction--the chips have to be replaced---LET ME KNOW WHAT YOU FIND AND I CAN GIVE YOU FAIRLY DETAILED INSTRUCTIONS ON WHERE TO GET THE PARTS AND WHAT IS INVOLVED IN THIS REPAIR.
I am here to help people--
REGARDS, SD TECH
Posted on Oct 02, 2009
Testimonial: "This is just what I was looking for. "
SOURCE: Color Alignment
get a shop manual,it tells how to do the whole convergence process and how to store it to the rom memory to save it.
Posted on Oct 19, 2007
SOURCE: MAGIC FOCUS
I had the same problem. Had to have the amplifier replaced. Cost about $100.
Posted on Jun 18, 2008
greg_margo
  • 1959 Answers
SOURCE: magic Focus error green 5.
Here's a link to perform a DCAM convergence on your television and reset your magic focus. Instructions for the S series are halfway down but be sure to read the whole page. Best of luck.
Greg
http://www.hdtvoice.com/voice/showthread.php?t=3736
Posted on Jun 11, 2009
techman007
  • 1112 Answers
SOURCE: Hitachi 43fwx20b magic focus the 3 colors are not adjust.
First have the convergence IC's replaced these are the two large black IC's mounted on an metal heat sink.
Posted on Oct 24, 2009
I think that it is the green because i did what you said and it is still there. there is a feature on my tv called magic focus it brings up the colors and the blue and the red are very focused but the...
This tv is a DLP projection tv right?Magic focus button push don't solved the focus picture problems,have colors shadows or 3D pictures problems?The tv have a problems known as a convergence problems,it dead.The tv convergence board.Must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved the tv picture convergence problems.The shop,will cost u $300-$350 for parts and labors.
Oct 02, 2010 | Televison & Video
Goes through magic focus than in the middle stops and displays #5
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 19, 2010 | Hitachi 46F500 46" Rear Projection...
Magic focus problem
in the menu first check if focus is set to auto or manual, need to be auto, if it is then pop off the front cover and acess panel with TV on cafefully press small button on signal pcb front edge, this is service mode, press pip mode,then pip channel after intialize turn TV off then on, function should be restored.
Aug 09, 2009 | Televison & Video
I have 46ux13k hitachi tv and i need to know if there is atrick to adjusting the convergence.
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACHI REMOTE. NONE ELSE WILL DO
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
ONE COLOR WILL NOT MOVE. YOU WILL NEED TO MOVE OTHER COLORS TO ALIGN TO IT.
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Mar 21, 2009 | Hitachi 43FDX01B TV
Will not show red color in picture, magic focus shows red though
You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
Feb 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Yellow and blue color ruins total picture on 50" tv,can't get rid
lupe0112,
I'm no expert, but I think that you have a problem with the convergence of the 3 color guns. I've been working on a similar problem. As a first step, have you tried "Magic Focus?" The Magic Focus button for the Hitachi 53UDX10B is at the left of the small front panel controls that also include your RCA composite and SVideo connectors. Let the set warm up for about 20 minutes (as recommended by the user guide), and then press the Magic Focus button. When you press the Magic focus button, the set will auto align the 3 color guns. If this doesn't fix your problem, unplug the TV for at least 4 hours and try again.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
MAGIC FOCUS
May 19, 2008 | Hitachi 43FDX20B 43" Rear Projection...
Model 53fdx20bv2f012705
I have the exact same problem.......you just explained it a hell of a lot better than me. In the magic focus was red broken up, blurred and flashing as well as only 3 bars???
If you solved your problem could you please get back to me.
Thank you
Randy
gardner7768@msn.com
Apr 16, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Magic focus
This might also be called digital array. You might have to do the manual adjustment with the cross hairs on the screen. These, one red, one blue, one green, should all align on top of each other in a white color. If this does not work, you should call 1-800-448-2244 for assistance in finding a local service center.
Jan 21, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 61SDX picture got dim shows Code 3
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 17, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 51S500 51" Rear Projection HDTV-Ready Television Logo
113 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
