Question about Garden
I have a murray 14.5 hp riding mower it ran just fine untill i put a new belt and blades on now it wont even start or crank over
I put a new belt and blades on now it wont start or crank over
  • 2,239 Answers
It sounds like you may have diss lodged a micro switch or the wires to a micro switch, re trace your steps, there will be a micro switch activated by the brake clutch pedal, this can be close to the belt and easily knocked
Posted on Dec 11, 2012
mickey813
  • 472 Answers
SOURCE: the deck belt on my ride on mower - murray
21a49d6.pngHOPE THIS HELPS YOU LET ME KNOW
Posted on Nov 19, 2009
Testimonial: "Thanks for the info. Really clear diagram and easy to follow which was great."
thabrain
  • 76 Answers
SOURCE: murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Posted on Oct 28, 2008
  • 24 Answers
SOURCE: murray riding lawnmower motion belt routing
I need your model # took look it up , I am a Murray dealer.
The thing to rember there are two kinds of idler pulleys flat idlers that ride on the back side of belts and v pulleys that ride inside the belt . wont be back to the shop until the feb 10.
good luck
Posted on Feb 08, 2009
  • 9 Answers
SOURCE: i have a bolens 38 inch riding mower. it cranked
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Posted on Feb 21, 2010
Testimonial: "thanks. at least i can crank it and get it to a trailer instead of pushing it. i really appreciate it.......cb"
agent91
  • 2100 Answers
SOURCE: i have a briggs and stratton 14 hp ohv engine on
It sounds like you are putting it into choke mode. The choke is usually all the way up on tractors. And it will make it backfire and flood out. Just rev it high enough to work and don't go into the choke mode. hope this helps.
Posted on Apr 21, 2010
I have a 91Murray 42inch riding mower need proper size belt to run blade,a blade belt
Contact a local auto parts store, a full service one, bring in the old belt and they can match it.
Jun 23, 2016 | Murray Garden
Spring mount location for belt tensioner for murray 45256x92a
Try this site to get your manual and see if the exploded parts diagrams help
Mar 30, 2015 | Murray Garden
What would cause a heavy vibration on my craftman riding mower, not caused from the deck, but by the v-drive belt for the tractor. i replaced it and without even putting the mower deck back on the vi
You did not finish the statement about without the blades but if your saying what I thing you are...Ah Oh Sounds like you may have a bent crank..Did you hit something with the blades...take the belt off and start the motor..and Check for wobble of the V drive there should be NONE if it does it could be bent itself or the crank...good luck
Jun 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I struck an object while mowing my yard and the tractor wont start or even crank what could the problem be?
start by disengaging the blade and putting the deck to it's highest position, prior to attempting to start the mower inspect under the mower deck making sure there is no Debee wedged interfering with the blade rotation, check your spindle's for play and inspect your mower and drive belts. once complete than give it a try. if by chance it does start but turns over you more than likely sheered the flywheel key.
Oct 10, 2013 | Poulan Pro 46Inch 22 HP Yard Tractor with...
42 murray mower deck TROUBLESHOOTINGmanual
It sound like pto or safety switch may be shorted. Hope this helps.
Jul 31, 2013 | Garden
Craftsman zero turn model# 107.27774
If you are jumping the solenoid and it cranks but wont start leave the key in the on position and give it a try. Try replacing the solenoid and the wires conecting it to the battery.
Apr 24, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Murray riding lawn mower
I have a 12 HP Murray riding mower about 6yrs old model 30577X8A. I am having trouble shifting it in and out of gears, ever thing runs just fine can you help?
Jul 04, 2008 | Computers & Internet
Garden Logo
293 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
