Question about Viking VGSC306-4B Gas Kitchen Range
Oven and broiler won't come on
All burners ignite properly but no oven or broiler
  • eduffett Jan 25, 2009
    Oven and broiler don't come on, replaced the igniter but it is doesn't work.
It's most likely the igniters in the oven. They cost about 40$ apiece and our oven has two. They are fairly easy to replace.
1) Turn off the electricity to the stove, either with a switch or your circuit breaker.
2) Remove grills, side support grills and oven base. They all just slide out.
3) Remove door to avoid breaking it. It slides off.
4) Remove old igniters, they are attached with two screws. Remove 2 wires from plugs. It might be necessary to lower the front base panel to get to the plugs - the panel is attached by two screws on the side of the panel.
5) Install new igniters, put the door and grills on and you're good to go.
The first time, it might take an hour to get used to your stove, but its really about 15 minutes of work.
Posted on Mar 08, 2009
SOURCE: Replacing Oven Igniter
PULL OUT THE DRAWER AND THAT WILL ALLOW YOU ACCESS TO THE 1/4" SCREWS IN THE LOWER REAR THAT HOLDS THE BURNER IN PLACE ALONG WITH THE FRONT SINGLE 1/4" SCREW. NEED A FLASHLIGHT FOR THIS. THIS FREES UP THE BURNER SO YOU CAN ACCESS THE IGNITER MOUNT SCREWS.
Posted on Feb 28, 2007
catriver
  • 878 Answers
SOURCE: burners don't receive gas though oven/broiler does
tommi, this model has a cooktop lock-out solenoid feature. Try pressing and holding the top light keypad for 5 seconds and see if the top comes back to life. If not, check your owners manual, it may be a different key. The lock-out solenoid is in the back behind the outer panel. The cooktop lockout valve has been redesigned from a AC to DC voltage because of complaints of chattering. The new part number is 8184768. Lets hope you don't need it and just have the top locked out.
Posted on Apr 10, 2007
SOURCE: Oven burner doesn't light
If memory serves me,there are a couple of screws on oven floor.Remove panel.Sounds like ignitor is the culprit.It feeds back to control.It may glow and light but unless it is sending full signal,gas valve will not open fully and oven will take forever to heat.
Posted on Dec 28, 2007
bestdarngood
  • 3037 Answers
SOURCE: Oven does not heat but broiler does
The most common cause of this symptom is a defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately (see the link below).
In that case, replacing the oven ignitor is the usual solution.
http://www.appliance411.com/links/jump.cgi?ID=823
Posted on Mar 22, 2008
bozcro
  • 867 Answers
SOURCE: xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Posted on Jul 30, 2009
Whirlpool WFG361LVS2 oven. Broiler and burners ignite but oven will not. I can hear gas and the igniter sparks but will never light the oven.
get someone to hold a long gas match near the main burner when you try the oven . If it lights then I would suspect the igniter. even tho you can hear it snapping .
Jan 10, 2015 | Whirlpool Kitchen Ranges
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Glow plug gets red but oven will not ignite. Broiler ignites but has seperate glow plug.
Check to see if you are getting gas to the oven burner. If it will light with a match then look into adjustment of the flow plug, but if it won't light, then look at the gas valve or switch.
Jun 07, 2011 | Ovens
My oven suddenly quit working - broiler works and burners, but the oven will not heat and there is the smell of gas whenever I turn the oven controls on. Can light the bottom burner of the oven with a...
More than likely, you have a bad igniter. As the igniters age from repeated use, they can become weak and longer function properly. Just because they glow, does not mean they are good. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. If a single igniter is still working (i.e., the broiler still works), its more than likely NOT a control board issue, either.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. If the model number is correct, the part number for a replacement igniter is WB2X9154.
NOTE: It is common for the BAKE igniter to require replacement more often than the broiler, due to the frequency of use.
If you have any questions please post back and let me know. I hope this helps you.
Oct 05, 2010 | GE JGBP24 Gas Kitchen Range
OVEN WONT LIGHT BUT BURNERS AND BROILER DO. TAPPAN 30-3860-23/03
More than likely, you have a bad igniter on the bake manifold in the oven. As the igniters age from repeated use, they can become weak and longer function properly. Just because they glow, does not mean they are good. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. Since the broiler still works, its more than likely not a control board issue, either.
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. The part number for a replacement igniter for the model you have listed is 5303935066. The price is about $23. NOTE: It is common for the BAKE igniter to require replacement more often than the broiler, due to the frequency of use.
Aug 12, 2010 | Tappan TGFS_63 Gas Kitchen Range
Neither the oven nor the broiler burners will light. In both cases, the igniter glows, but no gas to the burner.
UNLESS DOUBLE OVEN THE BROILER BURNER HEATS THE OVEN. AND THERE WOULD ONLY BE ONE IGNITER. WHICH IS PROBABLY DEFECTIVE AS THAT IS A COMMON PROBLEM WHEN USING IGNITER.
Mar 10, 2010 | Maytag MGR5750 Gas Kitchen Range
Oven won't light. Broiler will ignite and
I don't know how new or what brand your oven is, but chances are you have a bad igniter the bottom burner. It is a small element attached to the burner that should glow red hot when you turn your oven on to ignite the gas. This is the most commment setup and problem. You will have to remove the bottom tray (there are usully 2 finger screws holding it in) to see it. It should look something like this:
http://www.theignitorstore.com/product/306602/range_oven_igniters
If you turn the oven on and nothing happens, turn it back off. You can disconnect the igniter, connect a multimeter set to volts AC, turn back on and check for voltage (120 AC) Don't let any bare wire ends touch the oven or you. If you have power there, its the igniter.
Just get the model number off your oven to look up the proper replacement. Replaces with 2 screws. Make sure it mounts close to the burner. It should only take a couple seconds after you hear the gas turn on to ignite. Hope this helps.
Jan 02, 2010 | Ovens
Amana broiler problem
Each burner manifold in the oven has its own igniter. If the igniter is defective, the burner assembly will not light. The igniter has to be functioning properly in order for the gas safety valve to open. This is a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. This reduces the risk of explosions.
There should be a flame spreader metal plate covering the access over the broiler. You will need to access the broiler so you can view the broiler manifold and igniter. Turn the oven setting to broil and make sure the igniter begins to glow. If the igniter fails to glow, replace it. If the igniter does glow, but you still do not have ignition after 90 seconds, the igniter may be weak and still require replacement. The following link explains oven igniter types, their current potential, and how to replace them:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 29, 2009 | Amana RanARG7302 Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
Viking VGSC306-4B Gas Kitchen Range Logo
262 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
