Question about KitchenAid KESC300 Electric Kitchen Range
Burner isn't working
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
Check the burner for continuity with a multi-meter. Post back the results.
Posted on Dec 10, 2012
BURNER WILL NOT TURN OFF POWER LIGHT TO BURNER STAYS ON
Probably a defective burner switch/control. Power light and burner on condition are normal. What isn't normal is that the burner can't be turned off
Sep 08, 2012 | Kenmore Kitchen Ranges
Oven problem, it tries to ignite, but won't
It sounds like the igniter isn't lighting the flame, or the flame isn't sensing once lit. Check the burner to see if anything has fallen onto the burner or electrodes to prevent it from working. Also check the holes on the burner to see if they are blocked. If it is all clear it may be a control box issue.
Jul 22, 2012 | Kitchen Ranges
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
How do I lift the stove top to turn off pilot model # FGF366DCB?
there isn't a pilot in it,it has an electronic spark module in it.what problem are you having?when you turn it to lite it you'll hear a clicking sound,that's the sparking that lites the gas just like you're gas grill.if you want to remove the top you have to remove the two phillips screws out of each burner head,sometimes they don't come out and you have to drill them out,if the burner isn't shutting off the gas valve could be broke or the knob could be broke,if it's clicking just unplug it and you can lite the top burners with a match or bbq clicker to lite them until you get it fixed depending on what problem you are having.if the gas won't shut off by turning the knob you'll have to shut down the gas at the valve that feeds the stove.but like i said if you want to lift the top you have to remove all the screws in the burner heads.hope this helps you out.http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Range-Parts/Model-FGF366DCB/1428/0124002?pathTaken=&prst=0&shdMod=FGF366DCB go to this site and you can look up your machine.
Sep 03, 2011 | Frigidaire Ovens
Own a KitchenAid gas range superba, how do i clean the burner, one of my front burners the gas flow is very low, the stove has the glass/ceramic top with no wells & no way to get to the burners...only...
You'll need certified stove technician to service you kitchen Aid range. You have low gas flow on one of the burner. The manual gas control valve behind the knob needs to removed and cleaned. If you have one cleaned then have technician clear all four of these manual gas valves. While he cleaning the valve have do a complete check up of you Kitchen Aid range. Dangerous for the home owners to do this procedure because flowing natural gas or propane. In a lot the states you'll need to be certified by the state to work with natural gas, gas stove, ovens, gas home heating units, etc. It differentially a no,no here.
It is not the burners, it is gas flow valves for the burners. Most of the burner are made of aluminum and I wouldn't use any harsh cleaners of them. Check with Kitchen Aid and ask them what is recommend for cleaning the burners. Also the top of the range isn't ceramic but porcelain, it glass that has been melt to the top hood of the range. Don't use scratch pads, steel wool or any thing that will mare the Periclean surface of your stove.
If you can get the aluminum burner out to clean them then do so. GB you Allison and I wish you many year cooking on your Kitchen Aid range. stewbison
walk softly up on this earth and she will good to you...
Aug 21, 2011 | KitchenAid Kitchen Ranges
My lite-on dvdrw shw-1635s can't read or write any kind of cd's or dvd's. When i look at the drive letter of the burner it looks like it has a cd or dvd but there isn't one. I can open the...
if you physically unplug your cd/dvd restart your computer then reconnect it this should activate the found new hardware wizard or it might have a dirty lens you could use a liquid type lens cleaner read the instructions before applying put 2 or 3 drops on a cd/dvd then run the cd/dvd player
hope this helps
Aug 01, 2011 | Lite On (SHW-1635S) DVD RW Dual Layer...
My dvd writer\drive isn't reading any disc can any 1 try to tell me what should i do?????
Make sure you have an updated driver then restart your computer. If that doesn't work, comment back.
Jul 17, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Dryer everything works, but no heat.
You didn't mention whether it was a gas or electric dryer, but either way it probably just isn't producing heat. If it's electric, it's most likely a defective heating element. If it's gas, the burner probably isn't igniting. On both there is usually some sort of thermal shut off switch that can also go bad and shut off the heat element or the burner.
Jul 15, 2011 | Dryers
Phillips cd-r arent working.. dont know if its the cd-r brand or if the burner isnt working
try to buy another cd-r w/ other brand its much cheaper than buying another cd burner. If there is still a problem buy again a cd-r but w/ other brand again if still isn't working the problem is in your cd/dvd burner..
Jul 02, 2011 | LG Computers & Internet
Gas burner cycles on & off
It is supposed to cycle on and off as the water enters and then heated and then released from the unit. To see if it is working properly, you need to measure the input water temperature and then the output water temperature. It should be about 10+ degrees difference.
If it isn't then give us some more symptoms to work with.
Jun 01, 2011 | Teledyne Laars Laars Lite2 Heater 400000...
KitchenAid KESC300 Electric Kitchen Range Logo
62 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
