Question about RCA L32WD12 32 in. LCD HDTV
TH BUTTONS ON MY RCA 32 INCH TV WON'T WORK
    Top Expert:
  • RCA Master
  • 14,553 Answers
If all do not respond the set likely has a keyboard lock feature---look to the owner manual and read it carefully.
Posted on Dec 10, 2012
whatler
  • 22 Answers
SOURCE: I'm having double images with
You could try to go into the settings and use the "Image Cleaner" option. That's what we do with our tv. But i'm not sure if it will work with yours... (:
Posted on Dec 21, 2010
budmrtn
  • 11361 Answers
SOURCE: 32 INCH RCA TV sound no picture
Check power supply to see if it is putting out the 24vdc needed by the backlight inverter board, you may have failed power supply or shorted out backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Aug 19, 2010
jdvillanueva
  • 2098 Answers
SOURCE: I have a RCA 32" Flat Screen TV that shut off and
The sound was came from the clicking of the relay. This kind of symptoms is an indication of out-of-regulation condition on the power supply section. This is caused by faulty electrolytic capacitor. It will dropped the supply voltage and will trigger that kind of symptoms.
Faulty electrolytic capacitor mostly has a physical indication of fault like bulged/dome at the top and can be easily identified. See sample picture of faulty electrolytic capacitor below.
capacitor with bulged/dome at the top.
Check these parts on the power supply section. Once found, replaced it with same capacitance and working voltage which is printed on its body itself. Click this LINK for more info regarding electrolytic capacitor.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified TV Technician to isolate the faulty parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Aug 05, 2011
SD Tech
  • 14553 Answers
SOURCE: What's your problem?I have a 32 inch rca flat panel dvd player combo , turns on , but no sound and flashes a screen once saying please wait then goes black????
A complete model number would help with giving advice or an answer.
Posted on May 01, 2012
SOURCE: RCA LCD TV INVERTER BOARD
The problem is not in the inverter board it is in the power supply R976 is fried. I need to fined the value of that resistor.
Posted on Jul 20, 2012
How to unlock RCA 32F531T 32 '' tv. I tried the manual solution but didn't work.
You might have to enter its service mode option to unlock it. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 580 posts to different brand TVs.
Aug 13, 2012 | RCA 32F531T 32" TV
Fpa lock on
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET
Jul 08, 2012 | RCA 32V420T 32" TV
Dvd won't eject from RCA tv/Dvd combo
While hitting the eject button use a small flat screwdriver or butter knife to ease door open, probably the rubberband like belt broke or the gears jammed up!
Jun 17, 2012 | RCA 22LA45RQD 22-Inches 720p LCD TV -Black
I cut the tv off with a universal remote and now it won't come back on??
Its a 32 Inch Panasonic ( indicated here) a lot of these were Famous for the 6.3 amp glass line fuse inside blowing for no reason.
Make sure if the fuse is bad get a good one and not a generic from Radio Shack--------Let me know if you have questions.
Mar 15, 2012 | Panasonic CT-32HXC14 32" TV
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Mar 11, 2012 | RCA TruFlat 27F520T 27" TV
My RCA tv won't work without a remote, and I can't seem to reset since I don't have a menu button
Hello
If your TV has no menu button on its front panel, there is no other way than buying a universal or original remote control to this set.
Mar 04, 2012 | RCA Televison & Video
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
I am able to get in with the 5898 code to unlock the tv, it won't let me put in a new code and I still can't watch r rated movies? and when I get in to the dvd side of things it only want's 3...
Hello
Just unlock it following any one of the methods described below. Then reset it as your desire. One amoung the following methods will surely unlock your RCA and give you option to do others.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
May 17, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
Plzzz help me!!!!!
Your defective has defective parts on horizontal section. You need to bring the tv to expert technician,
Jul 26, 2009 | RCA 32F531T 32" TV
RCA L32WD12 32 in. LCD HDTV Logo
187 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
