My samsung projection tv has blue wavy lines on top of screen, I adjusted convergence, the blue will not line up horizontally, is there a inexpensive solution?
Blue wavy line on screen , picture is good still,
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
It means one of the chips has a bad section inside it, both chips and maybe a resistor near them will have to be replaced, involves soldering as each has about 18 pins soldered in
Check with TVrepairparts.com who sells some kits for this by brand and model number
Posted on Dec 10, 2012
  • 3 Answers
SOURCE: Wavy lines
This TV uses small voltage regulators. On each side of the regulators is the input voltage and the regulated output voltage on the other side. There are capacitors used for stabilization on the input and output. Change these capacitors.
Posted on Nov 27, 2006
ctf1800
  • 4402 Answers
SOURCE: Hitachi Projection Color Lines
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
Slinteriors
  • 8617 Answers
SOURCE: toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Posted on Feb 10, 2008
  • 1030 Answers
SOURCE: Mitsubishi 55" Projection TV / Horizontal Wavy Lines at Start Up
this is very common with these sets. the fix is to replace 11 very very smal capacitor on what is known as the hypermodule. The ideal sitation is to replace the hypermodule. if you can find it. I can do this repair. I have done about 10 at the shop. if you need to i would suggest finding someone who is very experence in surface mounted repair
Posted on Jan 15, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on Jun 20, 2009
It has a wavy line through middle of screen with like white light shining through it in three places. I do not think it is the convergence, when I go to convergence screen the red and blue will move but...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Apr 30, 2011 | Mitsubishi VS-55609 55" Rear Projection...
Yellow wavy line in top corner of screen
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Has wavey lines and horizontal shadows and will not complete auto focus. It happens after the tv is on 10sec. Have adjusted and cleaned the picture tubes did help clarity but still has the problems
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 17, 2011 | Samsung HCN653W 65" Rear Projection...
Blue streak across the top of the television and colors are reflecting making it look 3d
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jun 26, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Green Background with red wavy lines
*Screen Looks 3-D
*Colors wont align
Jan 11, 2009 | JVC AV-56WP74 56" Rear Projection...
PICTURE HAS DISTORTED HORIZONTAL LINE IN CENTER OF SCREEN.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 03, 2009 | Toshiba 55H70 55" Rear Projection...
Rear screen projection tv
*Screen Looks 3-D
*Colors wont align
Jun 30, 2008 | Samsung HCL4715W 47" Rear Projection...
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
RCA HD52W59 Wavy lines
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
  • Screen looks 3D
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
