Question about Sunpak Cl-5 Nicad Battery Cluster F/ Cv-300 Light
Replacement battery for Sunpak CV-300 light
Can I replacement the internal batteries in my Sunpak CV-300 video light battery pack?
2 Suggested Answers
  • 473 Answers
SOURCE: I'm using a sunpak battery
Check.. Make shure your battery is good ....and check our power supply if is charging also the pin on the connection itself ....
Posted on Sep 29, 2010
I did not receive the battery
Contact your supplier , did they sent what you ordered, whos error
Mar 11, 2015 | YONGNUO YN-300 II LED Video Light &...
How long does it take charge the sunpack 510 batt using the qbc-5
Sunpak uses different power sources on their high-power handle mount (a.k.a. hammerhead) flash guns. The most common is the battery basket that holds 4 or 6 AA or C batteries depending on the type of the unit. One can insert Nickel-Cadmium or Nickel-Metal-Hydride rechargeable batteries instead of the primary cells, this way reducing the "consumables" costs at the expense of the smaller number of flashes per battery set. (Actually, NiCd or NiMH cells would probably give smaller number of flashes compared with the alkaline cells, but the recycle time between the flashes can be shorter. The reason is that at charging the flash capacitor inside the flash current counts more than voltage. Sunpak sells Ni-Cd battery packs named CL-2 for their flashes that utilize 6 AA-cells, and CL-3 for their 622 series (4 C-cells). The charger for these is the QBC-5. It recharges the exhausted batteries in 3 hours. As a solution assuring the shortest duration between flashes Sunpak offered the Powerpak, a shoulder holster that held a dry (non-rechargeable) battery of 510V, it charged the flash capacitor directly, omitting the transistor inverter in the flash body. As such battery became obsolete, the Poverpak has been superseded with the NC510 and later the TR-II PAK, which utilizes 10 Ni-Cd rechargeable batteries as a power source, and a powerful (more capable than the one in the flash) transistor inverter. NC510 and TR-II PAK use the same connection to the flash and the same outlook as the original Powerpak but, being rechargeable, are more economical. QBC-5 also serves a charger for the NC510 and TR-II PAK. You may ask, how the same charger can be used for 4, 6 and 10 cell NiCd packs. Well, the charger is specially designed for that, although charging time differs at the different battery packs. The NC510 and the TR-II PAK needs 10 hours to be recharged, when exhausted. The best way to avoid damages (overcharging degrades NiCd and NiMH cells) is to check temperature of the batteries. Charging must be cut off if the battery becomes hotter than 45 ?C (115 ?F). If after 10 hours of charge the NC510 does not power (the otherwise working) flash, then it must be serviced. Replacing the batteries is an easy job that can be done at home, with some soldering skills; NiMH cells with solder tabs are available at many web-based supplyers. Don't solder the cells directly, heat damages them. Avoid touching parts inside, when the pack is turned on: electrocuting is fully possible. Better find a professional, if you are not familiar with the electronics.
Dec 27, 2014 | Sunpak Cameras
How long do i charge a sunpak nc 510 rechargeable using a QBC-5 CHARGER
Jan 08, 2014 | Sunpak Cameras
I'm trying to find a battery for SUNPAK CV-300 video light
I HAVE 2 OF THEM E MAIL ME AT PIMPLIFE420@GMAIL.COM AND MAKE ME AN OFFER
Feb 05, 2013 | Cameras
How does the Sunpak Auto 555 Thyristor Flash Unit work concrning a battery? Does it always need the ourside battery pack unit also?
When internal cells are fully charged it do not need external ones
http://www.photographyreview.com/mfr/sunpak/flashes/PRD_84012_3121crx.aspx
Aug 07, 2010 | Sunpak Auto 555 TTL Flash
On the 622 pro Sunpak
Sunpak TR-Pak II a NiCad flash battery pack with charger and Quantam battery both has cords for 622.
Personally I have taken out wire pair from removable battery pack of 622 and connected to 4 cells of Nicd type D battery pack made at home.(I placed that in my belt bag).
want more details ,feel free to email at bforbay@gmail.com
Mar 29, 2010 | Sunpak 622 Super Pro TTL Flash
Sunpak 622 Recycle Time w/ Batteries vs AD-26
I had the same problem - 10-11 secs on 240VAC. My solution was to get the Quantum Turbo SC for $450. It yields ~3sec recycle times. This pack for $150 should play nicely as well: http://www.adorama.com/JTMBPN.html?searchinfo=jtl+lancer+battery+pck It was out of stock at the time. The Sunpak TR2000 is $250, but it's Ni-Cd while the others are NiMH. There are other HV packs capable of powering the 622 w/ the fitting cable like Lumedyne IIRC. The AD-26 is still useful for non-action photography. The fastest time I saw posted is 1.5 secs, but it's a DIY job (search 'sunpak 622' on flickr). HTH,
Szilard
May 15, 2009 | Sunpak 622 Super Pro TTL Flash
Canon UC1 8mm video camcorder
No solution..... but eager to know where one can get the battery packs and charger fir this camcorder (UC1) A 8 mm videotape is stuck within the camera housing and can not be ejected...No battery and charger available..
Where are those battery packs available f.i." SUNPAK RB-E77MF 6V 1700 mA ??
I would highly appreciate your advice
Thanks in advance
J.van Bochove
e-mail: jvbochove@onenet.an
Jan 05, 2008 | RCA 8MM VIDEO HEAD CLEANER (WET) 8mm Tape
Sunpak Cl-5 Nicad Battery Cluster F/ Cv-300 Light Logo
251 people viewed this question
Top Sunpak Cameras Experts
Doberman
teddyboy
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
