Question about GE Washing Machines
MY WASHER NEED TO BE RESET
WPTG9350C0WW
    Top Expert:
  • GE Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Dec 10, 2012
How to reset frigidaire affinity top load washer
Good Morning friend, thank you for your post!
From the information you have provided you need to reset your Frigidaire washer. The best way to do so is to disconnect power from your washer for roughly ten minutes. If you need further assistance please feel free to reconnect. -Matt
Mar 06, 2015 | Frigidaire Washing Machines
Need a reset code
Search Google for "Amana washer code"
Dec 15, 2013 | Amana NFW7300WW Washer
E-27 blinking
The E27 code isn't often listed in Bosch manuals but relates to the washer door lock.
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
You may need to replace the door lock assembly on the washer.
Jul 20, 2011 | Bosch WFVC6450UC Front Load Stacked Washer...
My K5.20M power washer won't start. Am looking
Make sure your extension cord is able to provide 13 amps or greater of current. The longer the extension cord the more current it requires to supply the 13 amps to your power washer. If your unit has a long extension cord it could pull more than the typical 15 amps used for a household circuit breaker. If you do not have an adequate circuit breaker it will continue to trip. Now that you have the correct power supply you will notice the GFI Test and Reset buttons by the power washer plug. Plug the power washer into the power receptacle which has live power. Make sure the power washer is off and then push the reset button located on the power washer plug until you hear a click. The GFI should be reset and you can now turn on your power washer.
Jul 26, 2010 | Karcher Garden
Washer tripped breaker on elec. panel, reset, washer won't turn o
This sounds like something has shorted causing the breaker to trip. You definitely need a qualified LG repairman to check it out.
Jan 11, 2010 | LG WM1814CW Front Load Washer
Front door is locked and can't get it open.
First, try unplugging the washer for at least 30 minutes in order to reset the Central Control Unit (CCU). Sometimes this is all that is required to reset minor glitches with the unit. If the washer is still locked following a CCU reset, then you will need to use the manual release. The following link explains:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If you still need assistance, please let me know. If the problem reoccurs, take note of any error codes that may appear and also let me know. I hope this helps you.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need to reset whirlpool duet front load washer
How do I reset a front loader Whirlpool washing machine. The time keeps flashing. I drained the washer and now I need to reset it.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Keep needing to reset washer dryer
Check the vent lines to be sure the path is clear
Mar 13, 2009 | GE WSXH208A Front Load Washer
LGWM2277H LE light came on does the motor have a reset button i need to push
Hello momof3611
Welcome,
You said, Your LGWM2277H washer LE light flashes. Troubleshooting guide says overload in motor. Is there a reset on the motor that needs reset or does something else need done. washer was working fine until we put a big load of jeans in to wash. when we checked wash soapy water was in washer and I can't get it to rinse. drum is not turning.
If you overload, with to much clothes the weight will trigger this error your having in most washer.
Take some clothes out.
Then try this:
Unplug the washer for 5 minutes, or if you can't reach the plug, turn the breaker off for 5 minutes and then the system should reset itself!
Let me know.I'm looking right now for any reset code in the repair manual too!
Huuum
Please remember to leave a rating.
Oct 07, 2008 | LG WM2277H Front Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
