Howe do you increase the back wash rate on an MISF30-TNLC softener/filter unit
There are no instructions in the owners manual on how to increase backwash rate
  • 12 Answers
SOURCE: after Ivacum @ backwash turn to filter it pumps back into pool
bypass to waste, not to pump
Posted on Jun 11, 2009
XPoolGuy
  • 34 Answers
SOURCE: No water coming out when I backwash. I cleaned
water level must be about the discharge (eyeball) in the pool to back wash. Check the hose connections to make sure that hoses off the the filer head are going to the right place Look for the words "Pump" , "pool" and "waste" molded into the valve. I've seen it a number of times where "Pump" and "pool" were connected the wrong way.
Posted on Jul 04, 2009
  • 83 Answers
SOURCE: How do I backwash my Pentair Vertical Grid DE filter?
For instructions on backwashing and other trouble shooting, you need an Owner's Manual. You can find one online at the following link:
http://www.pentairpool.com/pdfs/FNSPlusVerticalGridDEFilterOM.pdf
The way you backwash this filter is easy once you get the hang of it!
The first thing you will do is turn off the system, change the valve position to the Backwash position. If you have a Multiport Valve, you will press down on the handle and spin it so that the knotch is pointed to BACKWASH. If you have a Slide Valve, only has two positions, up and down, you turn the handle so that the metal pin is out of the holder and move the handle in the opposite direction. You will need to turn the handle to lock the pin into position.
Once this is done, you will turn on your pump. Pentair recommends that you backwash for 1 minute, then turn off the pump.
If you have the Slide Valve, you will put it back into the FILTER position and then turn the pump back on for 1 minute. If you have the Multiport Valve, you will put it in the RINSE position and then turn the pump back on for 1 minute.
Pentair recommends that you do this cycle a total of three times, backwash/rinse, backwash/rinse, backwash/rinse. AFTER the third time, you will need to open the Air Release Valve at the top of the filter while the pump is OFF and the valve position in back on FILTER. Once this is done, turn on the pump. When you have a steady stream of water coming out of the Air Release Valve, close that up. This way you have no air in the system.
Now, you will mix your DE "Slurry" in a bucket. Depending on your model of filter, you will measure out your DE and mix with water to the consistancy of milk. **IF it is just a backwash, you will only add 80% of the original amount of DE. You only add the total 100% of DE when you completely take the filter apart and clean it out.**
You will slowly pour the slurry into the skimmer that is closest to the pump. This will allow the DE to evenly coat the grids in the filter. Wait about 5 minutes and then check the pressure gauge on the filter. Once the PSI reaches 8 to 10 PSI above this number, it is time to backwash.
Posted on Jul 09, 2009
jharwell668
  • 640 Answers
SOURCE: problems with hayward vari flow valve.
It sounds like you might just need to replace your valve. They are fairly inexpensive. Try contacting this company. They will be able to tell you exactly what you need to do (free advice) and will have the parts necessary if you do need to buy a new pool filter or new parts.
Backyard City Pools 888-751-0101 or www.backyardcity.com
Just let them know that you need to speak with the person in charge of pools. He will be able to help.
Posted on May 24, 2010
award462
  • 395 Answers
SOURCE: lost My owners manual, need instructions to clean
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
How to find a service manual for culligan n softener
Service manuals for Culligan units are not available on line.
Owners manuals are available for many models though.
Here is a link for Culligan units that you find useful.
http://eculligan.com/service-manuals/manuals.php
RJH2O
May 27, 2014 | Culligan 34" Whole House Water Filter...
Where does the fabric softener and washing powder go in the LG WF-F5207PC 5.5KG top loading washing machine?
Put powdered detergent in the box at the back of the opening of the washer (opposite the control panel when the lid is open). If you use a liquid detergent, dilute it 1:1 with water and pour into the bleach dispenser at the front left of the washer. The fabric softener dispenser is near the bleach dispenser but a little closer to the tub and towards the middle of the left side of the unit. As with a liquid detergent, dilute 1:1 (30ml:30ml) with water before pouring into the dispenser.
If the fabric softener dispenser isn't working, add the fabric softener in the final rinse.
The manual for the washing machine is available here: http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-F5207PC-_E . You will need to review the unit or enter a security code.
I hope this helps.
Feb 13, 2011 | LG Washing Machines
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    How do I perform a manual regeneration to test my Culligan water softener (medalist series)? The owner's manual does not explain how to do this. On the digital display for the unit, the word REGEN...
    Hold the REGEN button down for 5 seconds. This initiates a manual regeneration. You can step the unit through the cycles by pressing the UP arrow.
    RJ
    Jun 12, 2010 | Culligan Sediment Water Filter
    Which compartments are for detergent, (and prewash), and which for softener? And why does the manual say 'add softener after laundry is softened?
    Of the three chambers, the only one designed to take liquid is the softener. This will have some sort of syphon in it. The other two are prewash (smaller) and main wash (larger). Regarding the instructions, this unit is made in China and is probably translated incorrectly (I'm not being funny on this one)
    Dec 11, 2009 | Haier HWD1000
    Diepenses fabric softener too early
    You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
    Pull the dispenser drawer completely out.
    There is a tab that needs to be depressed to release the drawer and remove it.
    Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
    Reach down into this opening to see if an item is inside the hose.
    This is the normal issue that will cause water to leak out of the dispenser housing.
    Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Jan 24, 2009 | Washing Machines
    NO OWNER'S MANUAL
    This is the links you asked for.
    Owner guide--> click here for FWX833AS2(in English)
    Good luck and please do rate my answer if accepted.
    Jan 19, 2009 | Washing Machines
    I have no manual
    Here you go. on the right you can download the manual.
    http://safemanuals.com/user-guide-instructions-owner-manual/DANBY/DWM5500W-_E
    Good Luck and Please Rate FixYa!
    Jan 10, 2009 | Danby DWM5500 Front Load Washer
    Dispenser fills with water.
    The reason there is still water in the dispenser, and this in normal by the way, is the unit uses the pre wash and main wash valve to activate the fabric softener. Basically when the two valves come on they force water into the fabric softener compartment. There can be some overflow and it ends up in the blue cup nothing to worry about. Now if you have detergent there, then that is a problem..
    Sgt 48
    Jun 12, 2008 | LG WM-2277HW Front Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
