Question about Samson Audio Players & Recorders
Every light in my ct20 tuner is llighting up so i cant use it
I replaced the battery with a renata CR2032 battery when the old one died. now every light in the tuner lights up whenever the battery is in it and they do not stop lighting up until i take the battery out again. i have tried many different batteries since and they all have the same result. Everywhere says im using the right type of battery and i have tried many so i am starting to doubt that the battery is the problem help?
  • 77964 Answers
SOURCE: Battery light on dash
The battery light is an indication of some kind of problem with the alternator, most likely a diode problem in the rectifier bridge, this changes AC current to DC current to supply power to the car and charge the battery.
The cruise problem is most likely the cruise control module is failing.
If you have more questions please contact me on this same thread.
Posted on Oct 19, 2008
  • 77964 Answers
SOURCE: truck dies when i stop or slow down
Here is the most common cause of surges and stalls and low idle rough idle, it is the idle speed control air-bypass valve and throttle valve (IAC for short), they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Posted on Feb 17, 2009
  • 66 Answers
SOURCE: 02 saturn l200 starts then dies immediately
try your spare key it sounds like the transponder in the key is going bad
Posted on Jun 29, 2009
  • 645 Answers
SOURCE: 2003 Cavalier. Battery warning light came on
check the wire from the battery to the starter to see if it has good connection. otherwise check your ground to block.
Posted on Mar 20, 2010
SOURCE: My 2003 Jaguar X Type Problem
my jaguar 2.5 xtype wont reverse
Posted on Oct 16, 2012
Sabine zoid z-1000 blinks
More than likely you need a new battery those can be cheaply had if you buy 12 piece tea lights with LEDs they have CR2032 in them that's a lithium battery
Apr 02, 2014 | Sabine Z-3000M Zoid Tuner Metronome
My truck turns off when i get to a stop light
The battery light comes on because the engine is stalling. Fix the engine problem and the battery light will stay off. Vacuum leaks are common problems on very old vehicles like this. Check for vacuum hoses for cracks and splits and replace the damaged ones.
Dec 30, 2013 | 1985 Nissan Pickup
Name and battery number for tissot t touch watch
Renata CR1632
To replace battery you need to have very small screwdriver and some knife to open back cover.
Jul 21, 2010 | Tissot T-Touch T33759851
I have a Starrett 749 micrometer that will not power up I replaced the battery but still nothing
I have a Sterrett 733XFL-1 (O-1" Digital Mic). It turns out that these will only use the Renata Batteries. (Radio Shack Batteries are Renata and some Battery Stores Carry Them). The Renata CR2450 has a smaller diameter negative terminal (smaller diamter back half of battery). If you use an engergizer or other, the battery cover will short against the positive battery terminal and the tool will not work (and the battery will quickly drain being shorted to case)
Dec 16, 2009 | Starrett Measuring Tools & Sensors
Watch still not working with a new Renata CR1225 Lithium Battey
while battery on its place touch the 1 End with battery and secound with AC small Gold dot
AmFix Jewelry & Watch Repair
203 N. LaSalle St
Chicago, IL 60601
Ph: 312 641 7000
Sep 13, 2009 | Casio W94HF-3AV Wrist Watch
Need replacement battery for the above
I had the same problem. My jeweler came up with a solution. He "dibbled" the rear of the case just enough that the next smaller Renata battery would fit. You can't tell that he did anything but it worked. Hope this helps.
Apr 21, 2009 | Watches
Breville classique toaster
Just fixed my Breville CT20. Cleaned the contacts, there were no impeding crumbs so I tested again and still wouldn't stay locked. I finally replaced the 470uf 16v capacitor on the control board just below the electromagnet and wow, works like a brand new toaster! I got lucky, saving bits and pieces of old circuits sometimes pays off.
May 12, 2008 | Breville CT20 Retro Classic 2-Slice...
35 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
