Question about Video Game Consoles & Games
My d-pad on my madcatz ps2 controller is sticking and cleaning it didn't work, how do i take it apart to clean the gunk out without destroying it?
My d- pad on my controller just started sticking all of a sudden, it worked perfectly before that but now i have to press really hard to gt the buttons to respond especially the up button, i tried cleaning it with rubbing alcohol one a tissue, but it didn't work, the up button even seems to be stuck worse than it was before. I want to try taking it apart to clean it but I'm really not sure how to do that without damaging it, and all the other controls work fine, can anybody help?
    New Friend:
    Problem Solver:
  • 5 Answers
It\'s a mad katz controller i had about 15 of these growing up for my game systems; not only did they break easy but 2 of them came non working themself. buy a cheap 360 controller online and scrap mad katz :)
Posted on Dec 10, 2012
  • alysha_nuern
    alysha_nuern Dec 10, 2012
    an xbox controller will work for PS2?
  • alysha_nuern
    Never mind I fixed my own problem, I bought a new controller and am going to sell the old one to a store that can actually fix it.
  • 1019 Answers
SOURCE: Super Nintendo Start/Select Button not working all the sudden
your problem will be with the mating surfaces of the switch contacts themselves.
i,ve cleaned several console hand-pads. to find that sweat and food debris mixed together, get under the contact pads.
this is the small piece of carbon ( mounted under the silicone rubber pad ) inside the controller.
these should be wiped with a cotton bud, swabbed in a small amount of lighter fluid ( or methylated spirits ) and wiped clean.
re-assemble controller.
check the cable for signs of wear, also the controller port mating surfaces should be shiny copper connections. if these are not mating with the controller, then no signal is being transmitted between the pad and input ports.
look carefully, if any pins are lower than others, take a fine electrical screwdriver or needle, and gently bend the pin upwards, so that they all align at the same height.
Failing this, you have faults on you controller port input sockets.
these can be replaced, as they,re ribbon cabled to the mainboard. this is a job if your electrically competant.
Hope this helps.
Mike @ Compurepair.
p.s if it was simple, everyone would be doing it :)
Posted on Feb 23, 2008
SOURCE: Nintendo NES Controller Problem
try going to an old school game store and see if they have and nes controller then try
Posted on Apr 12, 2008
SOURCE: My xbox 360 wont synch with my controller even if i tried pressing the buttons
It could either be one of 2 things , your controller is knackered or the wireless board where the power switch is mounted could be faulty, try a mates controller and see if it does the same.
jonno
Posted on Sep 05, 2008
Kazong
  • 152 Answers
SOURCE: My PS2 controller port stopped working!
Sounds as if it has been dropped .....or an impact to the controller port while one was plugged in. in some cases the in side of the port can become full of dust and dirt causing light rusting creating a loss of connection ...but an impact can break a small chip on the back of the controller port inside the machine , try cleaning out the controller port and check to make sure the metal tabs are clean and un bent.
Posted on Nov 19, 2008
SOURCE: xbox 360 controller wont sync after taking it apart
man u might have to replace it..
Posted on Mar 02, 2009
Drivers side front door lock on 2010 ford transit connect Xlt makes loud noise but still locks and unlocks
have the same problem with mine ,sounds like a solenoid is sticking took it all part &cleaned what i could ,didn't help can't get the lock module in the door apart to clean it , did you have to replace it?
May 29, 2012 | Cars & Trucks
My volume up on the Harmony 880 won't work. I've heard that one person did take it apart to clean the contacts, but that didn't solve the issue. Any suggestions? I don't even care if I...
If the buttons used to work then yeah it sounds like a hardware issue. You can go ahead and take the remote apart, but I don't think you will be able to fix it, unless you are good at soldering. Cleaning the contacts alone won't help. This same thing happened to the most used buttons on my Harmony One, and I just assigned the commands to the screen, so I could continue using the remote without those buttons.
If you want to try assigning the buttons to the screen, the steps in this article by Logitech will help:
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/9766/kw/buttons
I hope this helps.
Aug 14, 2011 | Logitech Harmony 880 LCD Remote Control
Hi ,i have a vw scirocco 1987 8valves,all the brakes are new,even the lines ,master cylinder,galepper,pads,rotors,drums.when the car is hot the pads stick on the front disk,everithing is new?what is the...
Hi
Well, I really think you may find the problem only between two things: Caliper, pads or brake shoes, Beacuse I guess If you bought new drums you bought new shoes too didn't you? But if you're sure it is in front disk, then, you just have to check, you got the right caliper and pads and check the caliper is well adjusted and installed I hope this helps good luck!
Aug 05, 2011 | 1987 Volkswagen Scirocco
My right analog stick isn't doing what it is supposed to do... i can be playing ncaa and it will do the opposite of what i need it to do
Have you spilled anything on the controller or has it had any damages to it recently? It might need a cleaning or realigning of the axis inside the controller if you are up for it. If that does not repair it, then you will have to take it as a loss and purchase another one.
Mar 29, 2010 | Mad Catz Madcatz Cincinnati Reds PS2...
The receiver is turning itself off - i.e back to standby.
If you don't use the remote control is it okay? If so, tear apart your remote control, use a Q-tip to clean all the lines in the circuit board where the rubber contacts touch. Then make sure that the rubber buttons don't have any 'gunk' on them that are making them stick. Clean the rubber pad with a qtip with dishsoap. Dry well, put back together and see if she works. Report back on your success. Good luck.
Dec 29, 2009 | Marantz SR-7200 Receiver
Madcatz MC2 Racing Wheel Gas(RIGHT) Pedal Problem.
na take it to a proffesion al unless you arnt one it might have had a power surge and and a circuit is blown unless its wireless and needs new battery
Aug 01, 2009 | Mad Catz Madcatz Cincinnati Reds PS2...
Replaced battery in remote control but it sill doesn't work. Any suggestions
you may have gunk built up in the remote if it is old. i pulled my remote apart, and cleaned under the rubber number pad. i used alcohol to clean the contacts on the pad and on the circuit board. it worked after that. the only other thing i can think of is that one of your batteries is not making contact.
Jun 29, 2009 | Philips DCD778 8.5 in. Portable TV
Ps2 dual shock2 controller not working
Yes! your right, it's inside of the controller .what you can do is open the controller clean the board by using cotton buds with alcohol or cleaner you will notice accumulated dust preventing the buttons from touching the board you need to remove those.
Jan 25, 2009 | Sony PlayStation 2 (PS2) Console
Mad cats mc2 with pedals
The easiest way to do this is to go online and order a PS2 controller to PC adapter on amazon.com or some other site. I have a Madcatz MC2 and a Ps2 controller to PC adapter (a cheap one -_-") and it works okay (I'm having a lot of trouble with the pedals though).
May 28, 2008 | Mad Catz MC2 Universal (6320) Wheel And...
Video Game Consoles & Games Logo
46 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
