Question about Refrigerators
Freezer not freezing on regrigerator
After hurricane the freezer doesn't seem to be freezing properly.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Do you see any ice buildup on the back wall of the freezer or behind it?
Posted on Dec 10, 2012
  • 13 more comments
  • Daniel Holland Dec 10, 2012
    There is no ice build up. Nothing is freezing. It feels cold inside but not cold enough to freeze. Ice cube trays get a little ice forming but not solid. Seems to have happened after the black out. Thanks
  • Richard Roth
    Richard Roth Dec 10, 2012
    What is the model number of your unit? Is the compressor running and hot?
    model number is: gsl25jfph bs Not sure how to check compressor. Thanks again
  • Richard Roth
    Just pull the unit out and you can feel the compressor to see if it is hot and running. You may need to remove a cover.
  • Richard Roth
    If the compressor is not running, unplug the unit and pull the relay off the compressor and give it a shake, if it rattles it is bad and will need to be replaced.http://bit.ly/XKa9S9 Below is a video to show you how to check it. Post back the results.
    Compressor is warm and vibrating.
  • Richard Roth
    OK, unplug it and do the relay test.
    Relay does not rattle at all.
  • Richard Roth
    OK, I was afraid of that. You will need to replace the control board on the back of the unit. It is located under the small access door. Here is the part to order.http://bit.ly/TpI8Jy
    Would the refrigerator get cool in that case becasue the unit is cooling, just not enough to freeze. I just want to make sure. I mean I would gladly buy the part if that is what it is but i would hate to buy it and still have a problem. Is there anyway of directly checking this board? Thanks
  • Richard Roth
    No, you may be able to see burnt marks on the board though. The part is returnable so you won't need to worry there. The relay is good so the board is the only thing left to keep it from running.
  • Richard Roth
    You can test the compressor but I doubt it is bad. Take a look at this video to show you how to do the test.
    Great then it's worth trying. Also, it wouldn't be something like a freon charge as someone suggested to me would it?
  • Richard Roth
    No, I highly doubt it. I am 99% sure it is the board.
    Okay. Thank you so much. I'm gonna get the money together and try it. Thanks.
  • 532 Answers
SOURCE: GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
Posted on May 09, 2009
SOURCE: top shelf of both regrigerator and freezer not working
i have a side by side refrigerator is all ice bihind the cover evaporator
Posted on Apr 03, 2010
toolkits
  • 1099 Answers
SOURCE: Not cooling properly
First thing- set the controls at the mid range of their settings. Next, check the coils under the fridge to see if they are clogged with dust, etc. Next, using a couple stem thermometers, determine the temps in the freezer and fresh food sections. In the fresh food section, place a tall glass of water on a shelf in the middle, put the thermometer in and let it set for awhile in the fridge. Inside the fresh food section, look for the damper opening at the top of the wall in between the two sections. Wet the back of your fingers- can you feel air blowing through the damper opening? Inside the freezer section, look at the back wall- any frost buildup there.
Hope this help.....
Posted on Jun 28, 2010
  • 1156 Answers
SOURCE: kenmore 253. 9287413 Can't get
You can fix this, just follow the procedure given to enable get back your refrigerator going,
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
I hope this will help in solving the problem......
Posted on May 10, 2011
heatman101
  • 43501 Answers
SOURCE: The Lg Refrigerator doesn't cool.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jul 10, 2011
The refrigerator is not freezing
Hello Teresa, this is JK. I understand that the freezer is not cooling properly. Is the compressor running? Is there air movement through the grille at the rear of the freezer? Is there warm or cold air coming from the louvers? Can you remember any odd functions prior to this issue? If you can think of anything in particular, please feel free to reconnect and maybe it's something I can help troubleshoot. Best regards,
Mar 15, 2014 | Frigidaire Professional Top Mount...
Freezer too warm
First off, how old is the unit? Without knowing, my advice, and what has worked many times, is to unplug the unit, and turn it upside down. Thats right. Upside down. May take a couple or few people, depending on the weight. What this does, is to have the refrigerant begin running back to the top of the unit. Sometimes it settles in the bottom, and has to have extra help to start moving properly again. If, after about 6 to 24 hours it doesn't seem to have helped, it could be that you have lost the fluid, but that doesn't seem very likely. If you had, it would run consistently at the same warm temperature. If it helps, you may want to repeat the procedure to insure that it is completely free flowing. Cheap fix, if it fixes things. Good luck.
Nov 15, 2012 | GE Monogram ZFSB23DRSS 36" Monogram...
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
Refrigerator doesn't get colder than 55 degrees.
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Aug 19, 2011 | Kenmore Refrigerators
My freezer is not cooling good but the refrigerator works find
the coils are probably froze up,, unplug it for 24 hours if possible, when it freezes up solid they can't function properly, and the defrost doesn't allow for proper de icing , make sure the components are free of debris on the underside
Jul 15, 2011 | Refrigerators
The freezer compartment doesn't work properly.Ice is formed on the back and food won't reach freezing point. ????
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Refrigerators
Top shelf of both regrigerator and freezer not working
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Working ff freezer unplugged 1 year now does not freeze
Hi!!! You seem to have a seal system problem..A leak of refrigerant or a restriction in the seal system..Good luck...
Jan 20, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
