Question about Cloud B Twilight Turtle
How do we put batteries in teh Cloud B Twilight Turtle. where is says to push you won't open the door and we can't get the top screw out. We fill like idiots
2 Suggested Answers
SOURCE: I have the twilight turtle
I have a Cloud B Twilight Turtle. The Lights stopped working after my first battery installation. I fixed this (thank you China) by bending the POSITIVE battery contacts so they would make contact with the batteries. I guess the factory batteries had smaller positive contact terminals ( or the spring in the contacts had lost their tension ) than Energizer or Duracell. Hope this helps you. Thanks.
Posted on Aug 22, 2011
Is there a battery that needs to be changed occasionally? If so how do I take mouse apart to change?
I've had really bad luck trying to fix a battery mouse. I had to give up because I always destroyed the mouse.
Mar 06, 2015 | Computers & Internet
Pentax optio w80 waterproof digital camera won't turn on
I had the same problem. I checked the voltage first to ensure it was greater than 3.7V (some batteries were not). I left the door open and pushed the battery down and pressed the button and it powered up. Seems to be a problem with the contacts. I put about 6 layers of duct tape on top of the battery to cause the door to push it down and now it works.
Feb 21, 2013 | Avianne & Co Pentax Optio W80 Waterproof...
How do I fix a window that wont go up in a 1998 ford mustang?
I'm assuming it's not power window's,you will have to remove to window crank and the door opening latch,on the window crank,there's a clip embedded into crank,you can push door panel in at crank and use a flat head screw driver to push clip off,door handle has to come off,arm rest if you have one,,there are clips holding the panel to door,you can also use a flat head to put in between panel and door and pop loose,you may have to replace clips.After you get panel off ,you will see why the glass won't come up,may be off track.
Aug 10, 2012 | Ford Mustang Cars & Trucks
My amana bottom freeze refridgerator door in opening a little when the top door is closed. do i need to adjust the screws or is it something with the seal?
raise the front legs so the machine is tilted back a little,this will help the top door close easier,also most likely you have nothing heavy on the door itself,all a fridge does is move air,the evaporator coil gets cold and the evap. fan blows cold air from the freezer into the fridge side and the air keeps circulating,when you shut the top door it's pushing the air down into the freezer and popping the door open,like i said raise the front legs a little and put stuff on the freezer door so it has some wieght to it and it won't pop open.hope this helps salde
Jul 24, 2012 | Refrigerators
Door and handle problems. Smeg fa311x
sounds like your door is sprung. take door off and lay flat on a table outside of the door down. loosen screws on door liner . screws are hidden under door seal. when all loose not removed make sure door is flat on table. tighten the screws being careful not to move door. reinstall door and it should be ok. this is usually cause be either someone leaning or hanging on the door when it is open. or putting to heavy of items in the door trays.
May 26, 2012 | Smeg FA311X Top Freezer Refrigerator
I have the twilight turtle and it recently stopped working. I have replaced the batteries and still nothing. Is the light replaceable or do i have to just go and buy another turtle. This one only lasted 7...
Aug 02, 2011 | Cloud B Twilight Turtle
We wish to use cloudb turtle as a night light for our grandson. Will it stay on continuously or auto shut off after 45 minutes only?
it is auto shut off, no option, but if he wakes up just press on button will come back on for 45 more.
Jun 29, 2011 | Cloud B Twilight Turtle
Neptune front load will not spin excess water - clothes saturated, will not go to the fast spin that gets majority of water out, if i spin it with my hand manually i can hear what sounds like a significant...
there's a couple of problems that can cause this,take it apart and get to the door latch assy.top center of opening where the door latches.after you remove the front panel leave the door in place,lock the door and put it into spin,check the wax motor to make sure it's pushing all the way over,you can push on it when it stops to see if it didn't move all the way over,when you push on it and if it goes into high spin change the wax motor part number 22002119.next there's a micro switch to the right of the wax motor,if this is bad it won't go into high spin,door lock spin enable switch part number 22002162,you can pull it out,click it in and out and check it with a meter.if it feels funny or not clicking all the time when pushing the plundger in and out replace it.if that feels good theres an inertia switch part number 22003302.you have to remove the right side of the boot to get at this switch.it's on the right side of the tub near the top,it's a little tricky to get at it,the screws that hold it on are 1/4 inch,you can use a nut driver just stick some plumbers putty or permagum in the socket so the screw won't fall out when you remove it and put it back or a magnet head works great.these are the things to check,do them in the order i gave you and hopefully it will be the micro switch,changing out the inertia switch is a little time consuming.remove the screws that hold the door on and remove the other two phillips screws on the other side,pull off the front panel but leave the door in place,once you get into here you'll see how to get to the top door latch parts.here's a video so you can see the parts i'm talking about,you'll see the wax motor and the micro switch,not the switch above the wax motor it's the switch to the right that will cause the washer from going into high spin,if that's good it will be the inertia switch,just remove the right side of the boot to get at it.good luck,just take your time and it will get done.
May 07, 2011 | Maytag Neptune MAH5500B Front Load Washer
Lights not working on Cloud B turtle. Have replaced batteries and switch is on. Depress on button on shell & still no lights. Granddaughter has had for 2 years and loves it. Is it fixable?
Bend the positive battery terminals out with a knife just a tad. They are not reaching the battery and making it so that it wont work. I did this and mine lit right up.
Dec 27, 2010 | Cloud B Twilight Turtle
I need an operating manual for the Cloud B Twilight Ladybug, two of the light colors are no longer working (blue and green) and the red will only stay on for a few minutes. I am trying to determine if I...
We had the same problem, and took the whole thing apart, and emailed the manufacturers. They said there's no way to fix it, but they'll give us a discount on a new one, and then the Canadian distributors (which we got it from) said they'd replace it for free.
Dec 23, 2010 | Cloud B Twilight Ladybug By Cloud B...
Cloud B Twilight Turtle Logo
Top Cloud B Toys Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Cloud B Toy Expert? Answer questions, earn points and help others
