Question about Samsung RS2630SH Side by Side Refrigerator
My Samsung RS2630SH is leaking water from the bottom on the freezer side and there is ice in the bottom of the freezer.
    Top Expert:
  • Samsung Master
  • 9,472 Answers
You will need to check the drain line in the back of the freezer for blockage.
Posted on Dec 10, 2012
bobotfel
  • 236 Answers
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
Posted on Mar 08, 2008
SOURCE: Samsung RS2630SH Side by Side... Problem:
I don't have one to offer, but I have removed and fixed the fan, so I can offer you these suggestions:
1. Disconnect the power.
2. The fan is located at the back of the unit behind the removable panel. The panel is held on by about 8 Phillips machine screws.
3. Disconnect the fan by unclipping the connector; simply push the tab on the front and pull straight down.
4. The whole fan assembly pulls out by sliding the fan case out towards you. It may take a bit of a pull as there are tabs holding it in. Once it's loose, you will have to turn it sideways to get it past the condenser tubing.
5. Replacement is exactly the opposite operation; the fan assembly will push into place. You'll here a click when the tabs have engaged.
Posted on May 25, 2008
  • 351 Answers
SOURCE: Samsung RS2630SH is hot
i doubt it is really hot but it needs to be warm it avoids condensation around the doors
Posted on Apr 26, 2009
SOURCE: Small amount of water leaks from the front of my Samsung R2630SH.
I found out that there is a plastic panel that cools three draws inside the refrigerator. Behind the plastic panel there is an evaporator (coolant childer) that catches the condensation of repeatedly opening and closing the refrigerator door that turns into thick ice. Because of condensation, ice buildup in such a way that the ice pushes the middle draw out causing the door to open. In turn depending on how long the door stays open, melts the ice and the water leaks under the bottom draw out on either side of the front refrigerator door. Also, there is a drain plug that is also iced closed. To solve that problems, the unplug the refrig, put towel under the refrig, removed the panel (unplugging the wires and removing screws) and took a hair blow dryer to melt the ice. Oh, by the way, I used to blow dryer to melt the ice from the panel before I could remove the panel. That job took all day. I removed all the ice and reassembled the panel and replace the drawers. To my amazing, no more leaks and the water dispenser worked for two days and quit. I believed the water tank (plastic container in front of the panel has frooze again. By the way the ice maker did not work after removing the ice.
Posted on Aug 18, 2009
  • 218 Answers
SOURCE: My samsung rs2630sh is very very hot to the touch
The fan you should replace is called the condenser fan. It's the one that blows air across the outside coils. When it fails, you'll usually notice abnormal heating of the front of the divider between freezer and fridge.
Posted on Oct 27, 2009
I noticed that my ice maker continues to flow water into tray causing a big ice block could it be that i have a water leak in the freezer
Ome cause might be water from the ice maker is over flowing caused by 2 problems: 1 it could be a wrong calculation of water from your ice maker electronic board or 2 water solenoid to your ice maker is leaking .
Jan 30, 2013 | Samsung RS2630SH Side by Side Refrigerator
Water leaking from inside the freezer
if the bottome of the freezer floor is frozen then the most common cause is that the defrost drain is cloged, the back wall will mostlikley need to be removed and defrosted, then i use hot water & a long zip tie to make sure the drain is clear, don't use anything too hard as to punch a hole in a drain hose.
May 24, 2010 | Samsung RS2630SH Side by Side Refrigerator
My samsung rs2630sh, has water pooling at the bottom of the freezer. Water will also leak out of the until onto the floor. the ice buit up so much had to break it up just to get the bottom tray out. Any...
I have the same problem. Water from the defrost coil is not running out the outlet, but freezing in the defrost "catch" pan and outlet tube. Once water freezes, then water from subsequent defrost cycles, runs into the freezer floor and eventually out to the front or side. I don't have a permanent solution, but you can take the inside panel off with the four screws and see the problem. Chip out the ice dam and clear pathway with very hot water. I have read that lowering the freezer temp may prevent. Open to new ideas or permanent solutions. Good luck!
Mar 02, 2010 | Samsung RS2630SH Side by Side Refrigerator
Aug 16, 2009 | Samsung RS2630SH Side by Side Refrigerator
WATER LEAK FROM BOTTOM
the ice maker is a common fault on those appliances expensive to replace but quite easly done with regard to the leak eithr the drainage tray is blocked or one of the water feed hose is disconnected or leaking call an engineer
Nov 10, 2008 | Samsung RS2630SH Side by Side Refrigerator
Replacing ice and water levers
behind freezer panel on the seal strip there is usually plugs or screws to pull inside panel off be gentle cause the plugs are not easy to recover or buy at a store
they you have bottom hold screws 2 to 3
these doors are siliconed in so be careful when pulling freezer panel
front panel plate has 3 hold in screws be gentle here the fron panel pulls out be gentle
Dec 24, 2007 | Samsung RS2630SH Side by Side Refrigerator
SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
Mar 14, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
262 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
