Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Samsung freezer bottom digital display not working
Unplugged and waited 30 minutes and plugged back in can hear it kick on when plugged back in but still no digital read out is it in some kind of defrost mode?
  • Samsung Master
  • 4,654 Answers
Digital read outs on freezer door? Are you sure about the model number posted above your post? Look indide for the correct model number.
Check the wire connector under the top left freezer door hinge cover to insure it is plugged firmly. Let me know those answers and I will try to help you solve this problem, Thanks Sea Breeze
Posted on Dec 10, 2012
SOURCE: My Samsung refrigerator will not cool
Call Samsung. I had the same problem when Best Buy delivered mine. The delivery people left the fridge in demo mode. The people at Samsung will talk you through it, it is very simple. The fridge should work fine then.
Posted on Jun 25, 2008
fridgetech
  • 473 Answers
SOURCE: Samsung RS2630AWW freezer works/fridge does not
Chances are the fuse in the evaporator section is bad and won't go into defrost automatically.  Samsung refrigerators are junk!  Good luck getting anyone to service this one.
Posted on Oct 17, 2007
  • 147 Answers
SOURCE: I have a Samsung RS2556BB
Justy a piece of junk. The display has nothing to do with the defrost. Hold your top two buttons for 10 seconds and the displays will reset..good luck.*****
Posted on Sep 23, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Posted on Dec 24, 2008
  • 115 Answers
SOURCE: door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Posted on Dec 28, 2008
Display started flashing and now unit will not do anything
Sounds like the display is waiting for another command or the control board malfunctioned. Try to run a self diagnostic after unplugging it for 10 minutes, plugging it back in and use the procedure as outlined by Kelly, top-notch FixYa contributor at this link: Check out this solution to the GE Profile Stainless Bottom Freezer...
If the display still flashes and will not respond, I suspect a new control board is needed.
Mar 10, 2014 | Samsung RF265AA Bottom Freezer French Door...
Samsung fridge freezer
Sounds like it has a brain cramp. Try unplugging the power cord, wait a few minutes and plug it back in. Also look for resets near where the power cord comes into the unit.
Feb 18, 2014 | Refrigerators
My Samsung RS2630SH fridge and freezer are not staying cold. The condenser fan is running, I blew and vacuumed all dust off of the coils. If I unplug it for a few minutes then plug it back in the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 09, 2011 | Refrigerators
Freezer won't kick on
That is the overload protector on the compressor. Keep the door closed to preserve the cooling you have from the frozen food. Leave it unplugged for about an hour. Bang on the compressor with a rubber or wooden hammer then plug it back in. If it does not start you either need a new start relay or a compressor.
Apr 15, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
Samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Dec 20, 2008 | Samsung RS2534 Side by Side Refrigerator
Kenore elite bottom freezer, top fridge stopped cooling
first check that you can hear a fan in the freezer..if the fan is running you have a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Aug 24, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
REFRIGERATOR
Sounds like a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
TIMER-DEFROST
Aug 10, 2008 | Refrigerators
I have a side by side refrigerator/freezer by samsung and on the digital display the fridge temp (currently set to 2 degrees) is flashing.what does this mean many thanks
If the blinking continues, you may need to “reset” the Refrigerator. Try unplugging the appliance, wait for
around 10 minutes and then plug the power cord back in.
Jul 11, 2008 | Samsung Refrigerators
Will not run
Unplug it for one minute and plug it back in. After a couple clicks it should kick in. If not there are tests you can do at the motherboard
Dec 30, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
93 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
