Question about Bemis Whisper Close Elongated Closed Front Toilet Seat in Surf Green
Bemus whisper toliet seat does not close by itself anymore
The toliet seat has to be forced close. The bottom seat makes a loud squealing noise when lifted or lowered. the top lid also has to be forced closed but it does not squeal when lifted or lowered.
2 Suggested Answers
stevenpack
  • 1395 Answers
SOURCE: Can I make an adjustment to the Bemis toilet seat to get the slow whisper quiet close back again?
Slow Close Toilet Seat Hinges
Posted on Apr 30, 2018
Just installed new Chamberlain motor but makes loud snap when door opens and closes about 3 inches from ground?
Do you have a security system in your home? Sometimes the door shut sensors get out of alignment and the door strikes the sensor. This is the exact same problem I had with my door.
Nov 05, 2017 | Chamberlain 1/2-HP Whisper Drive Belt...
GE pdw9980lss dishwasher makes a horrible squealing noise when not in use.
The dishwasher control panel must be defective, nothing else would cause this.
Apr 04, 2017 | GE 24 in. PDW9980LSS Stainless Steel...
Hi there we have a caroma slimline toliet 2000+ that hisses constantly after you've flushed and the system fills up with water.even when its full it still hisses we have replaced the ballcock and the...
this is usually caused by slightly higher than normal water pressure in your area or foreign matter lodged in the fill valve body. the quickest/cheapest solution is to flush the toilet and turn down the pressure to the toilet by slowly turning the shut off valve toward the off position till it stops making noise. otherwise you could replace the fill valve w/a "whisper" valve by fluidmaster, from home depot,lowes,etc, which is much less noisy in general but even a whisper will make noise if the water pressure is to high. hope this helps but if you need anything else just ask:)
Jul 31, 2011 | Home
Toliet seat lid doesnt drop slowly anymore ( 4 yrs. old )
Either live with it or replace it. The hinge is not serviceable and the soft close action does not last forever. They rarely last more than five years, maximum.
Jun 19, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
I have a chamberlain whisper drive garage door opener. When I open the door and it reaches the top it starts making a loud noise. It's like the motor is still trying to pull the door up but it can't...
SOUNDS LIKE THE UP LIMIT IS EITHER OUT OF ADJUSTMENT OR NOT WORKING.
TURN IT ABOUT THREE TURNS COUNTER CLOCKWISE. THIS SHOULD BE ENOUGH TO MAKE IT NOT OPEN ALL THE WAY. THEN ADJUST IT 1/2 TURN AT A TIME THE OTHER WAY UNTIL IT GETS CLOSE THEN SMALLER ADJUSTMENTS TILL YOU ARE HAPPY WITH WHERE IT STOPS.
HOPE THIS HELPS
Nov 04, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Kohler lowboy toilet seat does not have bolts underneath
I have the same low boy where the bolts are inside the hollow body of the toilet. I called Kohler customer service and was told to use brute force to yank the toilet seat out. My husband suggested using a saw to cut the bolt but he hasn't done it yet. He wants to replace all our Kohler low boys which constantly leak becos of poor design of handle and flapper. The handle pulls the flapper slightly to the side when you flush. And the flapper lip being a tiny bit too small, if it doesn't sit just right, the toilet leaks. We've replaced one already with a Toto and love it. Too bad that Kohler isn't trying to fix the problem as I see many many online posts with the same problem and recommendation to replace the Kohler with Toto or somethng else.
Jul 29, 2009 | Kohler - Toilet Seat - Moondance -...
Kitchenaid Whisper Quiet + dishwasher making loud humming noise
Very likely pump motor shaft seal leaks water into bearing casing buildup of rust and consequently noise. I just replaced $112 worth of pump assy and it's back to normal. I would also buy repair manual for $10 on-line to be sure how to disassemble the sump to get to the pump.
Jul 14, 2009 | KitchenAid Dishwashers
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
Bemis Whisper Close Elongated Closed Front Toilet Seat in Surf Green Logo
231 people viewed this question
Top Bemis Home Experts
jdthefixer
john h
Are you a Bemis Home Expert? Answer questions, earn points and help others
