I have a 46" Samsung LCD tv that won't turn on. When I press the power button you can hear the chime sound it usually makes and you can hear the relay click and the screen flashes quickly then goes bl
  • 933 Answers
Sounds like you have a back light problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flash light on the screen. If you see the faint picture on the screen, you have a back light problem. You could either have a shorted inverter that is pulling down the 24vdc line, a blown CCFL back lamp, a high voltage short (arcing) from one of the inverter outputs, or a faulty 24vdc power supply
Posted on Dec 10, 2012
SOURCE: th-42pz700u
Same problem. Have to wait until they open back up tomorrow to make the call.
Posted on Dec 11, 2007
  • 53 Answers
SOURCE: Samsung LCD tv wont turn on
what the full model number of your tv?
the clicking sound is the result of a faulty power supply, some capacitors(blown heads) on the power supply for the output voltage rail of the mains board need to be replaced.
pls rate me!
Posted on Mar 20, 2009
  • 7 Answers
SOURCE: Samsung LN-5265F LCD TV is very slow to come on.
its the elecrolytic capaitors on the power supply.
goto www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound
it shows how to fix it yourself for only 'peanuts'
Posted on Aug 05, 2009
  • 7 Answers
SOURCE: 46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
lightnbaby
  • 36 Answers
SOURCE: hi my samsung lcd tv model le40s8, it won't switch on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Posted on Nov 12, 2009
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
Samsung LN-S4695D LCD WON'T TURN ON BUT POWER LIGHT IS ON ?
I would recommend you get a professional diagnosis. There is high voltage present in the set that can harm you. Being that you never messed with a TV, you could possibly cause more damage to your set. These flat panel TV contain sensitive circuitry. What you are describing sound like a fault with either the power supply or main board.
Dec 01, 2012 | Samsung LN-S4695D 46 in. LCD HDTV
LED light blinking 6 times and TV won't turn on
When you turn on the power button listen to the back of the TV, you should hear a motor with a high pitch spin up (the color wheel) and then the lamp should attempt to fire. The lamp should make a sparking sound and if it does your lamp is most likely defective. The part number for the lamp is on a sticker on the sode that will say "Lamp Code" on it and will be something like BP96-****
Aug 01, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
TV will not turn on. It just clicks.
RELAY is clicking noise you hear.FUSE IS GOOD!!
Power supply problem.
May 19, 2010 | Samsung LN-T4665F 46 in. LCD Television
46" Samsung LCD, no sound output whatsoever
First try hooking up a different source such as a DVD player or Cable box and see if you have audio. If you do then check the audio output from the computer. If you do not have audio then make sure the tv audio is up half way and turn off the set. When you do this you should hear the down chime provided you have the chime turned "on". If you do not hear the down or up chime then the sudio circuits on the Main bd are bad and the Main bd will have to be replaced. A quick way to check to see if the audio circuits are working is to listen for the up or down chime when turning on of off the set coming from the tv speakers speakers.
Jul 14, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
Samsung tv model no LE40R74BDXIXEU TV IS USUALLY
First the main bd controls the "Turn on" sequences". When you press the Power on button the Main bd sends a "Turn on" signal to the Power supply. The clicking you hear is the Power on relay ativating. If the tv does not turn on and the relay keeps clicking then you might have a bad Main bd or there is s shorted board somewhere else in the set. The Power supply can also be bad. Have a trained Samsung tech troubleshoot the set.
Jul 12, 2009 | Samsung Televison & Video
Won't turn on!
You need a repair....
Please don't forget to rate me "FIXYA"...thank you!
Mar 06, 2009 | Samsung LN-R460D 46 in. LCD Television
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
Electro Med Services...
