Question about Tacsew Sewing Machines
Tacsew ddl 8500 needle won't go up and down - Tacsew Sewing Machines
SOURCE: Tacsew T500 : Needle continually comes unthreaded
No this machine does not use a bobbin. I just purchased one too and called the supplier to help me keep mine threaded. He said they do not take much tension at all. So check your tension and then when threading it, make sure your thread goes under the bar in the center of the tension disk, not on top of.
Good luck, once you get it going it does a beautiful job!!!! Love it, Love it!
Posted on Jan 28, 2008
dupina
  • 110 Answers
SOURCE: Juki DDL-8500
The DDL 8500. is a high quality, single needle, straight stitch, industrial machine. If it is still in a good condition and the present owner is prepared to guarantee it for at least 3 months, it is a good buy. Retail for app. $790.00 new.
Good luck
Posted on Jan 17, 2009
ftw1952
  • 10319 Answers
SOURCE: i need find manual for my juki ddl 8500
Go to the website freemanuals.com They may have yours
Posted on Mar 31, 2010
SOURCE: I am having a problem with the automatic thread
HI THERE
FIRST OF ALL IS THERE ANY ERROR APEAR ON CONTROL? I THINK E007 HAPPEND.
1- TRY TO CHECK STOP POSITION FOR MACHINE IS IT CORRECT OR NO.
2- CHECK CAM FOR THREAD TRIMMER IS IT CORRECT OR NO.
3- CHECK THE PART NAMED THREAD GUIDE FOR KNIF MAYBE BROKEN OR MISSING.
BEFORE YOU CHECK THIS TWO REASONE TRY TO CLEAN ALL EARIA ARROUND FIXED KNIF AND MOVABL KNIF.
Adjusting the timing of the thread trimmer cam
How to adjust the timing
The timing of the thread trimmer cam for cot ton and synt hetic threads can be obulned simply by aligning the marker dot on the machine ann and the marker dot on the handwheel.
Till the machine head. manually tum the handwheel un til the thread take-up lever almost reaches its highest
position . and press th read take-up picket to the right by finger. This causes the earn toller 10 fit
in the groove of the thread trimmer cam. With this condition maintained, tum the handwheel in the direction
opposite to the nonnal rot ational direction . and you will find a position in which the handwheel no longer
turns. Then, adjust the cam timing so that marker dot on the machine ann is aligned with
marker do t on handwheel This provides the proper cam liming for ca tion
and synthetic threads.
Posted on Dec 29, 2010
  • 233 Answers
SOURCE: I've just bought a Pfaff
Do you have a bunch of material and thread stuck in the feed dog? Sounds like. This will sometimes happen. I'm afraid the only thing you can do is carefully work with a seam ripper or small scissors to get it all out. Be careful working. You will damage this part of your fabric, but you can take the seam allowance in a small bit. You will probably have to remove fabric & thread from underneath, through the bobbin area, too.
Once you have all of this cleared, the needle and wheel will turn. I suggest you try and take the needle out of the shaft and try pulling it out of the fabric before you start your work, too. That way, you won't risk breaking it and have a piece fly off at you.
It's frustrating and will probably make you curse at the machine-it's happened to everyone who sews at one time or another, and will happen again, I'm afraid.
Posted on May 11, 2011
Automatic thread cutter is not working. Juki cp-160
I am confused as to why one place on this says Juki cp-160 and one says DDL-8500-7
If it is the DDL, my most common problem with my knives that cut the threads have become jammed after I either broke a needle or had a thread 'nest' underneath from something I did wrong, like not getting my bobbin case in good before I started to sew.
1. Remove your throat plate (the silver or black plate that covers your feed dog teeth, may sometimes have lines on it to allow you to measure your seam allowance as you sew) that is held on with two screws.
2. Use a bright light to look into your machine under the plate and see if you see broken needle parts or a thread nest. If so, remove them with tweezers or a small pair of needle nose pliers. If you solved the problem, you will hear a small click as the blades return to their proper places.
...Then you can simply reinstall your cover plate and begin sewing.
If the above didn't work:
Your cutting system is made up of two pieces. A moving knife that looks like a tiny silver bird the size of a dime and a stationary knife that looks like the letter L backwards. If either is broken, you should have a repairman fix it. If you have had your machine and sewed alot you may also just have dull knives but I would imagine that they are either jammed or broken.
Good Luck.
Feb 09, 2018 | Juki Sewing Machines
I have juki ddl 8500 and the needle will not pick up the bobbin thread.
Is this a new machine or have you had the problem before
Aug 13, 2013 | Juki DDL-8300
Juki DDL-8500 skips stitch
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Jan 02, 2013 | Sewing Machines
When to change oil in my ddl 8500
you can change the oil for your machine after 6 or 8 month maximum.
Feb 25, 2012 | Juki DDL-8300
I have a tacsew 1718 where can i order n needles
contact sewvacdoctor.com & ask them
Aug 09, 2011 | Tacsew T500
My juki machine ddl-8500-7 is locked how can I unlock it
hi there
can u check one by one
1 - loose screw for needle bar clamp and turn the wheel by hand.
2 - from down remove the finger for hook and turn machine pully maybe some thread insaid the finger.
3- loose the four screws for upper main shaft and turn the machine pully by hand.
best regards
ashraf abozid
aaozid@hotmail.com
Aug 13, 2010 | Juki DDL-8700
I bought a used juki DDL-8500 and i am having difficulties to adjust the stiches which are being made by it. i will b grateful if u can attach a manual for the sewing together with your reply.
hi there
you can go to www.juki .com
under industerial sewing machine youy can download DDL 8700 instruction manual it's same DDL8300 model.
now you can do next steps
1- change needle with new one.
2- you can find tow mark on needle bar the upper mark for adjusting the hight of needle bar bring the needle bar at lower position and check if the upper mark aqual with the lower bushing or no.
3- when the lower mark aqual with the lower bushing at this time the blad point of hook must be at the center of groove for the needle if no lose tow screw for the hook and readjust the timming between the blad point for the hook and grove for needle bar
best regards
ashraf abozid
aabozid@hotmail.com
Aug 05, 2010 | Juki DDL-8300
I need find manual for my juki ddl 8500
Mar 30, 2010 | Juki DDL-8300
How to fix timing on a juki ddl-555 sewing machine
Hi, if your ddl-555 sewing machine the needle doesn't grab the string from the top and bottom; and it can't sew the fabric. Do you know what to do/
Sep 14, 2009 | Juki DDL-8300
Juki DDL-8500
Good luck
Jan 17, 2009 | Juki DDL-8300
Sewing Machines Logo
50 people viewed this question
Top Tacsew Sewing Machines Experts
Rommel Balcita
DavidinClt
Level 1 Expert
Ruth summersides
Are you a Tacsew Sewing Machine Expert? Answer questions, earn points and help others
