Question about Whirlpool duet Washing Machines
Can my washer door be opened manually - duet Whirlpool Washing Machines
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 10, 2012
GFWH1200DWW GE front load washer won't unlock red lock showing
From an article I found online:
See if manually opening the door will reset everything. Unplug the washer and remove the lower front panel like you're going to clean out the drain catch. Once you remove this panel you can reach up behind the upper front panel and pull down on the small plastic pull tab attached to the bottom of the door lock assembly. This will manually unlock the door so you can open the door.
Now once you have the door open, plug the washer back in and see if you can start another cycle.
Mar 06, 2016 | GE Washing Machines
I can't open the door on my front loader
If you take to top off and look down where the door lock is there will be a circular plunger on the bottom. pull it down and you can manually unlock the door.
Feb 14, 2015 | Samsung WF337AA Front Load Washer
Whirlpool duet washer door will not unlock or complete the cycle
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
  • Oct 13, 2011 | Whirlpool Washing Machines
    Door locked.... tried to unplug and cancel button - still not open??
    Try holding end cycle button for 30 seconds if no. Then try reset process Press "Pause/Cancel" two times to cancel the cycle. Press "Drain/Spin" if there is water in the tub. Unplug the or disconnect power for two minutes, then plug the washer back in or reconnect power.If no then here is the manual open process. Unplug the power cord of the washer from the outlet. Locate the toe panel. This is the section of metal at the bottom of the front of the washer, directly below the door. Remove the three screws on the bottom flange of the toe panel, which connect it to the washer. Lift the panel slightly and pull it forward to remove. Manually unlock door Reach up inside the front panel and locate the door latch assembly on the right side of door.Feel for a tear-drop shaped tab on the bottom of the door latch assembly. This tab will manually unlock the door.Gently pull down on tab about 1/4 inch or until you hear a click. The door should open.
    Dec 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    We have a Miele W701. We just finished a load of laundry and the door won't click open. The electricity is on and I cannot see any other problem with the machine.
    The most common cause for this problem, is the Electro Magnetic Door lock, itself. The part may cost about $170, new. However, you can open the door manually, from the bottom side of the washer. Other causes may be a defective "push button switch," or drainage problem. In a drainage problem, water sitting inside washer, won't allow the user to open washer door, until the water is manually drained out. Good Luck.
    Nov 17, 2010 | Miele Novotronic Premier 500 Front Load...
    Kenmore elite he washer lock light. cannot open
    You can manually Unlock the door Lock System
    1. Unplug washer or disconnect power.
    2. Remove the lower kick panel.
    3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
    4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
    5. Gently pull the tab down about a ¼" or until a click is heard.
    6. The door may be opened.
    Thank you !!
    May 31, 2010 | Kenmore Elite 45986 Front Load Washer
    Washer locked. door lock light blinking. start button light on. won't do anything.
    IT IS POSSIBLE YOU HAVE A DEFECTIVE DOOR LOCK OR CONTROL BOARD. CHECK YOU OWNERS MANUAL TOO SEE IF YOUR WASHER HAS A MANUAL RELEASE SO YOU CAN OPEN YOUR DOOR. USUALLY YOU CAN ACCESS A MANUAL RELEASE BY REMOVING THE FRONT BOTTOM PANEL AND REACHING UP UNDER THE DOOR LOCK AND FINDING A PLASTIC PULL PIECE WHICH YOU CALL PULL AND UNLOCK THE DOOR. MAKE SURE YOU UNPLUG THE WASHER FIRST. CHECK THE DOOR LOCK MECHANISMS TO SEE IF ANYTHING IS BROKEN AFTER YOU GET THE DOOR OPEN.
    Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Washing machine door on a front load washer will not open
    If you are experiencing a door jam the following link explains how to access the manual release:
    http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
    If you continue to have problems, please post back and let me know. I hope this helps you.
    Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Is door reversible on duet model GHW9100LW1
    The technician informed that we cannot reverse the door on the washer.
    Apr 09, 2009 | Whirlpool Washing Machines
    My kenmore elite smartwash/he4t (error code)
    Try shutting off the machine. Switch off Usually the door opens in 2 minutes or so. Do not force open the door. There may be instructions in your book to open the door manually. It could mean unscrewing somewhere.
    Apr 04, 2007 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    12 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
