Question about Toshiba Satellite L675D-S7052 Laptop
Toshiba 17.3" Satellite L675D-S7052 overheating
Hot shuts down after few minutes
4 Suggested Answers
KingDWS
  • 1606 Answers
SOURCE: overheating and shutting down within several
The A-70 and A75 series both suffer from a very tight cooling system. If you are running a P4 its pretty marginal. Basically what you need to do is blow out and or clean the cooling system. On my A70 I had to do it every 4-6 months. Basically as soon as it started getting past warm on the bottom of the laptop it was time to blow it out.
Basically what happens is dust and oils (cooking oils, perfume oils etc) and hair collect on the cooler and reduce how effective it can cool.
So what you do to clean it is get a can of compressed air (keyboard blow off stuff) and two toothpick. Take the battery out and unplug it.Turn the laptop upside down. Insert the toothpick in the cooling fans. This is important as the air can turn the fans faster then they are meant to spin and could damage the fan bearings (new fan annoying and expensive -lots of labour). Take the compressed air and blow in from the exits and then blow in over the fans. What will surprise you is just how little dust will come out. It may just be one good puff of dust and thats it. When you do this a couple of times or don't see any more dust you are done. Take out the toothpicks and put the battery back in and turn it on. It should run much cooler.
Posted on May 17, 2010
Testimonial: "I thought the fan was shot... however, blowing out the fan did make a noticeable difference. I also used a ShopVac and vacuumed the back. I ran the laptop for over an hour and it never shut down. Thanks!! Great Advice!!"
prashant2012
  • 1127 Answers
SOURCE: i want to buy a
Hi
Please click the mention below link to download the CD application Creator
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2760012&rpn=PSK3JU&modelFilter=L675D-S7052&selCategory=2756709&selFamily=1073768663
Posted on May 11, 2011
  • 72 Answers
SOURCE: i could not find my
Hi!
You here is a link for the drivers and softwares for your Toshiba Satellite L675D-S7052. Please click this link Toshiba Satellite L675D-S7052.
Posted on Jul 20, 2011
Why does 2000 s40 volvo turbo runs hot and the fan stays on after shut off
fans are designed to run on after you shut engine down as engine temperature rise after switching off . running hot could be caused by the top hose having gone soft when you rev the engine the water pump sucks the hose flat stopping the coolant flow or the radiator is blocked and need flushing out
Sep 16, 2014 | 2000 Volvo S40
What do I need to connect a laptop toshiba Satellite L675D-S7052 to a high definition tv
Assuming what you are trying to do is make your HDTV a giant monitor, your HDTV will need analog video input capability --either a standard d-type VGA connector or RGB composite RCA plugs. The laptop has a d-type VGA output. You will need a cable that has matching end for your laptop and TV....either VGA-to-VGA (d-type) or VGA-to-composite. This will handle the vcideo. You will also need a min stereo-to-mini-stereo cable to connect the audio from the headphone output of the laptop to the HDTV.
Sep 06, 2014 | Toshiba Computers & Internet
Why does my Harley Davidson 2003 Ultra Classic shuts down when hot?
Thermal safety cutout is shutting down ignition, if you don't feel the engine is that hot replace thermal cutout and relay
Aug 08, 2014 | 2003 Harley Davidson FLHTCUI Electra Glide...
Why does my 2003 Harley shuts down when hot?
check oil and coolant levels its over heating and designed to shut off to save engine
Toshiba L675D
A fan has failed, the unit is clogged with dust or a task is running the CPU/GPU at stressful levels.
If you are not confident opening and cleaning out a laptop yourself have a repair technician do it.
If the fan has failed it needs repair.
Run task manager (taskmanger.exe) to check to see if a hung process in a loop is causing the CPU/GPU to run at 100% all the time.
Jul 02, 2014 | Toshiba Satellite L675D-S7052 Laptop
My toshiba sata l675d freezes durring virus spyware scan
It seems that your computer is infected.
Step Followed:-
1. Click on start and type Run.
2. In Run box type Temp.
3. Select all and delete all files.
4. Follow 1st step and type %temp% and then follow 3rd step.
5. Follow 1st step and type prefetch and then follow 3rd step.
6. Follow 1st step and type appwiz.cpl (add and remove programs)
7. Remove unwanted software and all antivirus .
8. Restart the computer.
9. Download Malwarebytes from "http://www.filehippo.com/download_malwarebytes_anti_malware/download/d7670bee6c8cd1bb9341d9a1ffbe832f/ "
10.Scan your computer and remove the infection.
Thanks
Apr 05, 2014 | Toshiba Satellite L675D-S7052 Laptop
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
My aniviruses wont update even after i format the computer and install new antivires
Since the problem is showing up with the antivirus software, please tell us what brand and version of antivirus software that you are using. Try a different brand for troubleshooting purposes. Microsoft Security Essentials is actually quite good, and it is free. If it works, you can just leave it.
Mar 02, 2012 | Toshiba Satellite L675D-S7052 Laptop
Toshiba Satellite L675D-S7052 Laptop Logo
119 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
