Question about KitchenAid KSSS36QK Side by Side Refrigerator
I have a KitchenAid KSSS36DWX02 SIDE BY SIDE FREEZER/REFRIGERATOR. THE FREEZER TEMP LOWERED TO REFRIGERATOR TEMPERATURE. I REMOVED THE COMPRESSOR PANEL AT THE TOP AND FOUND A GREAT DEAL OF LINT/DUST ON THE COILS. I VACUUMED A GOOD DEAL OF IT OFF, BUT, NOT TOTALLY. DO I NEED A SERVICE CALL FROM A TECHNICIAN?
  • Walid Bannoura Jan 13, 2009
    My refregirator temperature is lowered now I do not know why. The freezer seems ok but not great.
    President:
  • KitchenAid Master
  • 2,651 Answers
You dont need a atch to vaccumm the coils for you, you can purchase what they call a refrigeration coil brush, this will allow you to get into all the little nooks of the condensor coil, available at home stores
Posted on Jan 16, 2009
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
Does that unit have a low temperature monitor built in? Maybe that is what is making the noise when your temps dip to -10 degrees. Actually, that is great because the lower the temps the longer you can keep food in the freezer so I would not be overly concerned about that aspect. BTW, have you tried to isolate the source of the humming noise?
Sep 19, 2017 | KitchenAid Refrigerators
My freezer is too cold
There should be a freezer and a fridge side temperature setting , look for both is fridge side
Oct 05, 2014 | KitchenAid Kitchen Aid - KSC23C8EYY...
Kitchenaid superba refrigerator side at lowest temp setting is not cold enough. Freezer temp is fine.
Check the setting of your vents between sides and open them, sometimes you have to pull out the produce drawer to find the lower one
Jun 23, 2011 | KitchenAid Superba Architect KSCS25INSS...
FixYa: We understand that your problem is: I have a 2007 side by side Kitchen Aid Refrigerator. It seem that the motor runs non stop. The coils are clean. The house temperatures are constant and the...
Hi there
Maybe nothing
1. The fan in the freezer compartment runs full time, this could be the motor noise you hear
If the temperatures are OK then it can not be the compressor that is running all the time or the freezer would go really low in temperature.
You need to pull out the unit and confirm that it is the compressor that is in fact running all the time, they normally run around 12 to 16 hours each day
2. The other unlikely possibility is if the compressor is running full time then there may be a fault with the compressor, busted suction valve or the system could be low on gas.
Regards
Gordon
Apr 21, 2011 | KitchenAid Refrigerators
Side by side kitchenaid freezer temperature indicator.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 30, 2009 | KitchenAid KBLP36FMS Bottom Freezer...
Freezer always about same temp as the upper refrig section
Check those coils underneith. They are making the machine work harder IF they are dirty. They may be full of lint and cobwebs. All that needs to be removed.
Mar 31, 2009 | Kenmore 21.0 cu. ft. Bottom Freezer...
KitchenAid Side by Side Refrigerator
hi thanks for the question is the compressor running . pull away from the wall remove back cover and check the compressor if its hot and running with no cooling you have a failed compressor thanks the appliance doc
Sep 26, 2008 | KitchenAid (KSRD22FKST) Side by Side...
GE Profile PFSF5 NJWA BB
There is a timer that determines the defrost of the cooling coil inside the back wall of the freezer. defrost timer may be located in the area of the controls for temperature. Look for a hole in that area and recessed in that hole you may find a clutch head screw. Turn this screw clockwise very SLOWLY until you hear one click. The freezer coil will be in the defrost mode for 18-22 minutes and then the refrigerator should return to the cooling mode. Make sure the condenser is clean and free of dust and dirt. Condenser is where the heat is removed from the refrigeration system and on most models it is located in back behind a removable panel. Reinstall the panel after cleaning the condenser.
Jun 01, 2008 | GE Profile PSW26P Stainless Steel Side by...
Kitchenaid superba ice freezes in the bin
The temperature of your freezer is probably set to low allowing the ice to melt a bit, then refreeze. Try setting your freezer temp a bit lower. That should fix it.
May 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSSS36QK Side by Side Refrigerator Logo
87 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
