Question about Intermatic ET100C Energy Controls - Electronic Time Switches - 24 Hour Elec
The controller seems to be running continually, regardless of the thermostate setting. I'm thinking it needs to be replaced
It is a 2 zone HWT system. In the summer 1 zone would not shut down. We disconnected the zone valve, thinking this was the issue, but when we replaced this valve, it and the other valve would not open with a call for heat. I reset the timer box and then it acknowledged the zone valve, but as soon as it opened and it tried to start the pump it shut down. Playing with the timer box, I finally got it to run but it seems to be running wild. Does this box seem to be expired?
4 Suggested Answers
protek480
  • 1714 Answers
SOURCE: My intermatic timer won't trip back on
I don't think the timer runs on 240 volts does it? You can switch 240, but the timer uses 120 volts to run. You might check the connections and timer clock rating more closely. Also, the 'off' & 'on' trippers are different, make sure you use the right one.
Posted on Jun 26, 2009
SOURCE: Install a timer to control pool operation
Another option would be to get an electronic timer like the Intermatic P1353 that has 3 circuits on it that you could program to cut on and off at different times. For example, you could have one circuit that controls the pump and turns the pump on, then the second circuit would turn on the booster pump at a set time after the filter pump had come on and then the heater could be set to also run at a preset time after the pump circuit was activated. Since the pump, booster and heater are all 220, it's a straight forward hookup with everything in one timer box.
The lights, as stated before, would be on a separate circuit (110) and have its own timer or photosensitive eye set in line.
Posted on May 11, 2010
Testimonial: "I read the P1353ME manual and it has the capability of exactly what I'd like to do. Thanks. "
MOTORWIZJ
  • 1343 Answers
SOURCE: I have a t101 timer that hasnt been used for 2
TURN BREAKER OFF TO TIMER , LEFT UPPER CORNER OF TIMER IS A TAB, PRESS UP ON IT AND AT THE SAME TIME PULL OUT ON THE YELLOW DIAL NOW YOU HAVE ACCESS TO THE CONTACTS ,POINTS . IF YOU FLIP THE ON OFF SWITCH YOU SHOULD BE ABLE TO SEE THE CONTACTS OPEN AND CLOSE. IF NOT THE TIMER MAY BE BAD . SEE IF YOU CAN.. WAIT NO NO NO THATS A 101. 115V CHECK YOUR WIRING JOB THE BLACK WIRE SHOULD BE HOT WIRE ITS IS SWITCHED THREW THE TIMER
Posted on Jun 10, 2010
Slow sewing regardless of speed setting
I'm thinking that the problem is in the foot control
take the foot control to a sewing machine repair shop and have it checked out
you say it appears aftermarket--probably is to replace a faulty OEM unit
Aug 22, 2016 | Janome Memory Craft 6500P / MC6500P...
Dual-Zone AC Problem
My guess is that one of the hose's has a leak and needs to be replaced. A mechanic can run some tests to check if that's the case. Best of luck.
Jul 11, 2013 | 2009 Toyota Venza
Miele wt945 won't heat when washing
Possible that the heating element is faulty. It is best to confirm using a multimeter to test the continuity of the element. If so then check the voltage on the element at the time of the cycle and if there is no voltage then the controller unit is faulty. check for fault in the connectors , wires or links.
Jun 05, 2012 | Miele Washing Machines
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
Sep 03, 2011 | Denon AVR-1905 Receiver
Curtis and Co. Big Time 3 zone watch w/ temp gauge. What does the stem positioned at aprox 10 O'clock control? It is near the temp guage but does not seem to control anything.
Crown(stem) at 10 O'clock has air inlet for temperature, does not move. Crown at 8 O'clock is for setting 3rd time zone next to it. The two buttons on the right of the case, above and below, set 2nd time zone which is at the 6 O'clock position of the large dial. To set #2 push top button till min. hand moves 1 min., then push bottom button to move 1 min each time or hold for rapid movement. Large crown sets date and large dial. Unscrew it (counterclockwise) then pull out to first click, then set date turning crown clockwise, continue to pull out till 3rd click which is where you set the time on the large dial.
Dec 29, 2010 | Bulova Watch
Denon AVR-4802 multi-zone problem.
I had the same questions and still can't believe there isn't more information on the topic. It's crazy how much marketing Denon devotes to their Multi-Zone features yet offers very little reference materials on the actual set up. I guess most customers don't use the fearture? Here you go:
-The Multi-Zone on the Denon 4802 is analog only. If you are running digital coax or fiber you will have to run a second line that's analog (eg RCA red/white) from the source to the Denon in order for the signal to to make it to the Zone 2 speakers (regardless if it's Pre-Amp out or direct connect to the Zone 2 speakers from the multi/SB speaker outs. Regarding the Harmony question, I had the same problem with my Harmony 880 and wasn't able to find an answer after multiple searches. Luckily I figured it out when I deleted the receiver from the Logitec device list and started over. Connect the remote to your computer, launch the Logitec Harmony Remote Software, click the Devices tab, hit the Add Device, pick the device type & manufacturer from the drop down list, enter "AVR-4802" under Model and finally hit the Next button in the lower right corner of the UI. The next page solves the Harmony Zone 2 control problem. You will see a message "To use your device in additional zones/rooms, click the checkbox...." Make sure Room 2 is checked (mine was not), update the remote and you're done. The Harmony Device menu you will now contain a second receiver icon called "receiver 2." Hit "device" on the Harmony, choose "receiver 2" and you will gain control over Zone 2 including volume.
Steve
Jan 21, 2009 | Audio Players & Recorders
AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Yamaha RX-V657 Zone 2
Suggestion by clarkent22
I called and spoke with Yamaha support staff (Chuck) who was very helpful. I was able to get my issue resolved hopefully this works for you too.
Couple of solutions:
1) Go into the Menu setting (Manual SetUp/Speaker Set) and make sure that you do not have Presence Speakers or Suround Back Speakers
2) Also in the Menu settings (Manual SetUp/Options/Multi Zone Settings) make sure that your Zone 2 Amplifier is set to "Int" (assuming you are not using external amp
3) Zone 2 can only accept an analog signal (not digital)... so there are two steps to this one. First, make sure that you either run only analog, or if you run digital and analog then you need to select "Analog Input" on the front of the unit. If yours was working earlier, my guess is that your input settings got switched to digital (or auto) You need to have analog set up for each specific external source (DVD, Cable/DTS, etc)....
4) This model receiver will only let you control Zone 2 with the remote control. You can power it on the receiver unit. But to select your source you have to press the Amp button, then the ** button. Then you control Zone 2 and you can toggle sources and adjust volume. (Check your owners manual for programing remote for zone 2.. think I pressed the "code" button and then 2999.)
Hope this helps... it worked for me If not call Yamaha they were very helpful.
Oct 13, 2007 | Yamaha RX-V657 Receiver
Intermatic ET100C Energy Controls - Electronic Time Switches - 24 Hour Elec Logo
13 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
