Question about 1995-1997 Chevy Tahoe Ignition Starter Alarm Switch
2005 Chevy Tahoe back door won't stay open...slams shut
The lifegate/back door will not stay open...slams shut...just started a day ago. This an expensive problem?
  • rand383333 Mar 29, 2009
    Will not hold up back door, just quit working
  • Bill House May 13, 2009
    Rear liftgate will not stay open on my 2002 Tahoe, especialy in cold weather. Price for new struts at the dealer, $49.50 each. Is there a better place to buy these and should they be replaced in pairs?
  • 95 Answers
No you probably have to change the lift gate struts/supports that are on the liftgate itself. very easy to do and they sell them at the autoparts store i would say for around 30-60 bucks
Posted on Feb 16, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Dash lights
That is just like a 2005 buick century, and it is normal. When you open the driver's door, the radio turns off. Does yours turn off too?
Aug 31, 2014 | 2005 Chevrolet Tahoe
2002 chevy tahoe gas cap door wont stay closed
Hello Matthew, Check the hinge on the door and the retainer latch button inside of the filler neck area. Sometimes they stick and won't pop out back out to keep the fuel door latched properly. You can lube the hinge & latch with WD40 to free it up. I have seen this happen a few times on a Blazer. Hopefully, this is all you need. I hope this information is helpful.
Oct 12, 2011 | 2002 Chevrolet Tahoe
When I start my 2005 Chevy Tahoe LT there is a grinding sound and it won't start, so I turn the key back and stop, wait and then the next time I turn the key it starts just fine. It has done this 3...
Sounds like you are having a problem with the starting motor. When activated, it throws out a gear to engage with the flywheel on the end of the engine. If there is not enough energy to fully engage the gear, or the gear does not engage properly due to misalignment, you may hear a grinding noise. Have the starting motor serviced or replaced.
Jan 24, 2018 | 2005 Chevrolet Tahoe
My 2005 chevy Equinox rear hatch will not open.
I took my 2005 equinox to a dealership yesterday because my back hatch quit opening, it cost me $80.00 for them to tell me it will cost $500.00 to fix it. $200. For the actuator and $300. For labor
May 07, 2011 | 2005 Chevrolet Equinox
Fridge quit working a month ago, unplugged it and when i plugged it back in, it started working again. now it quits working all the time, but when i shut door firmly it starts up again and stays cold for a...
You don't say how old the frig is ... you cant have a frig run like this. On one day ... off the next ... slam the door and it works ... Either get a new frig of get this one repaired professionally. Probably best to get a new frig. I would guess minimum service call charge will be $250.00
Apr 05, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
Rear access open on 2005 Chevy Tahoe
I don't know if this will work, but at least it is worth a try. Spray some WD40 liberally over and into both tailgate latches. Try to get up inside using the straw extension. Open and close multiple times to work it in. I suspect there is an internal latch switch, which controls the display, that might be dirty, corroded, or just not working. Of course other causes are possible. I hope it works.
May 10, 2009 | 2005 Chevrolet Tahoe
Hatch-back door will not open
I can say I have had the same problem, only the back doors and the rear hatch/glass won't open using keyless remote from them freezing this Winter.  The front two driver/passenger doors will unlock with keyless remote but none of the rear doors, hatch or glass.  Since I had to replace the stoplight bulbs in the rear with one not working and I don't need a ticket on Memorial Day weekend (need to replace 2 at the same time is wise according to any good mechanic), I had to get the rear hatch open to get to the lamp assembly and replace the bulbs.  My thinking was that since my two front locks were opening but no others and my keyless remotes are working, it has to be a fuse or relay that is not working!  So, I talked with a NAPA rep and he said the "Day running lights" relay can be a temporary fix to get the rear locks open to replace the bulbs.  I looked up in the owners manual where both relay's are located and removed the "Locked" relay and "Day running lights" relay and put the "Day running lights" into the same slot where the "Locked" relay was not operating and it worked!  I got the doors unlocked and replaced my stoplight bubs replaced.  Now, I have a new problem, my Tahoe won't start!!  I'm assuming the relay wasn't supposed to stay in the wrong slot when operating the vehicle because I started the truck, and it started and died-started and died-same and again.  I think the wrong fuse can be used to fix another problem like a fuse.  But, a fuse you can leave in and deal with one operation in the vehicle not working until you can replace the fuse later when you purchase it.  But, not a relay!  Now, I think the confused electronics cause another component (possibly the fuel pump relay) to burn out with the wrong relay in place of another when the vehicle operates.  I should have known but I was so glad to get the doors open after two months and it being Memorial Day weekend.  Now I have to find out what else is wrong so don't make that mistake to avoid the same predicament.  Better to get the relay ordered and replaced than to have this happen to you.
Apr 09, 2009 | 2005 Chevrolet Tahoe
Start button doesnt start the dryer
Sure sounds like a door switch to me. Is anyone slamming the dryer door? Was there a rubber bumper on the door that is now gone?
Mar 27, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
1995-1997 Chevy Tahoe Ignition Starter Alarm Switch Logo
1,176 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
