Question about Garden
Whats the best way to break in chainsaw boots
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Wear them at home for several days before a long term run outdoors.
Posted on Dec 11, 2012
What oil please
Best to use proper chainsaw oil to lubricate the chain cutting in the wood, but at a pinch you can use multigrade car engine oil. Don't use secondhand oil as the added acids,pollutants, etc., from the engine will break down the oil making it less efficient....and leave staining on the wood.
Chainsaw oil can be readily bought from good garden centres.
Hope this helps.
Jul 14, 2014 | Ryobi 18-inch Electric Chainsaw Chain Saws
Parts
this pole breaks because the gear inside is made of puter and when it gets warm enough it melts or breaks the teeth the only solution is to take it out and find some place that makes them to replace it
Apr 22, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
METHOD STATEMENT FOR CHAINSAW
Basic chainsaw user equipment for just cross cutting fire wood,helmet with ear defenders and visor, chainsaw gloves, class 1 chainsaw trousers or chaps ( class 1 20 metres per second chain speed ) sturdy boots, as regards use, have a days instruction from a qualified instructor.
Jun 14, 2013 | Garden
What is the spark plug gap setting on a husquavarna chainsaw
Have you looked in the gas tank for a broken gas line? They become brittle and break. Very common.
Mar 09, 2013 | Husqvarna Garden
I have a rear tine craftsman tiller and it keeps breaking the shear pins on the right outer tine. I have replace the pins several times. Same results. What could be causing the problem?
The hole is worn out so the pin has room to move around inside the hole which causes excess wear on the pin...this causes the pin to break after a period of use...
The best fix would be to have the hole welded up and then redrilled to the proper size again..
heatman101
Jun 25, 2011 | Garden
What is the best way to break in brutini demi or zippered boot
The best way to break it in is simply by walking around in it! Just wear them around the house for a while if you don't feel they're perfectly comfortable just yet.
Apr 10, 2011 | Giorgio Brutini Genuine Snakeskin Boots...
What is the breakin period for a poulan 1950
I would say a full tank of fuel, but there really is not any " break in" time stated in maual.
Feb 06, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the proper fuel mixture for a husqvarna chain saw ?
The Correct Fuel Mixture Ratio
All two stroke engine will use a 50 to 1 ratio using today's two stroke oils. I once used an old chainsaw probably from the 1960s, that had a sticker on it that said to use a 25 to 1 fuel/oil ratio, but that would have been using two stroke oils of the time period the chainsaw was manufactured. In that chainsaw I used 50 to 1 ratio with no problems. Today's two stroke oils compared to yesteryears are more efficient at lubricating. It is like comparing today's synthetic motor oil to motor oils of decades ago. All the equipment I use in landscaping, anything from a weed eater, leaf blower, chainsaw, hedge trimmer, use 50 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 liter fuel can and use it in all of the equipment for my customers and for my landscaping. To calculate the ratio is simple. For instance , if you have 1 gallon of fuel it is best to break it down into smaller units, like ounces. One gallon = 128 oz. You then divide this amount by the ratio of the mixture which is 50 to 1 (50 parts fuel, 1 part oil). So therefore 128 oz of divided by 50 = 2.56 oz (you would just measure out 2.5 oz ) of two stroke oil. If using metric, say a 5L gas can, you would break this down to smaller units, which would be milliliters. 5L = 5000 ml. 5000 ml of fuel divided by 50 = 100 ml of two stoke oil.
Jul 25, 2009 | Garden
Replace anti vibration mounts in Husq 55 Rancher chainsaw.
the mounts push in and then have a plastic plug that slides into the rubber.the best way to get the old ones out is to just break them and pull them out in pieces
Mar 02, 2009 | Husqvarna Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
