Question about Whirlpool Duet GHW9150P Front Load Washer
No display only a ticking noise - Whirlpool Duet GHW9150P Front Load Washer
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
You will need to replace the CCU on the unit. Here is the part to order.
To replace the CCU, just remove the top and you will see it.
Posted on Dec 10, 2012
What is ticking noise from passenger side of motor?
Michael, check your engines oil level right away, low or dirty oil is the main cause. Other things that can cause this issue could be worn or dirty cam lifters or tappets, exhaust leak, loose worn timing chain, possible EGR valve cracked or leaking at base, bad belt or tension er, the list could go on. PRESS THE HELPFUL BUTTON and check links below
What That Ticking From Your Engine
Engine Ticking Clunking Noise Repair
Tick Tick Tick Troubleshooting By Ear
3 4l gm infamous engine ticking noise
Feb 09, 2016 | Cars & Trucks
There is a ticking noise when moving
The ticking noise could be coming from a CV joint. Does the ticking noise go away in reverse? A loose brake pad (Anti rattle clip missing or broken) will move back and forth in it's mounting, a warped rotor will enhance this effect, the ticking noise will come when the pads moves upward into it's mounting causing a metal on metal tick.
Does the ticking noise get louder when you are turning the vehicle? If it does this would indicate a worn CV joint.
Apr 04, 2013 | 2006 Ford F-150
My hyundai elantra keep ticking wat can i do to stop the noise
A "ticking" noise can be caused by several things. First thing to check is the oil level. When an engine is low on oil, there's a lack of lubrication and you will hear the lifters "ticking". Some cars make a "ticking" noise with the AC on. The ticking is the compressor kicking on and off.
Jun 21, 2011 | Hyundai Elantra Cars & Trucks
Player still searching & making ticking noise.
you will need to clean the lens whith alcohol and a soft cloth.
Mar 28, 2010 | Polaroid PDM-1040 Portable DVD Player
Ticking noise underneath the car approximately midway.
The sound you hear is the metal parts of your exhaust system and catalytic converter cooling down.Some cars are louder than others but the sound is perfectly normal.
Mar 01, 2010 | 2006 Toyota Camry
The hardrive makes a constant ticking noise, the screen displays "operating system not found".
Hi
Unfortunatley the ticking noise means the drive is at the end of its life and will need to be replaced
Please leave feedback/vote if this has been useful
Feb 10, 2010 | Acer Computers & Internet
I have a 1998 GMC k1500 and it makes a ticking noise eveytime u step on the gas?
WORN PISTON RINGS MAKE A TICKING NOISE.VALVE LIFTERS MAKE TICKING NOISE.WORN DISTRIBUTOR SHAFT BUSHINGS MAKE A TICKING LIKE NOISE.
Oct 29, 2009 | 1998 Chevrolet K1500
Ticking noise when trying to start car
Hi
Sounds like a flat battery !
Get a jump start, with a good heavy duty set of jump leads.
Then have your battery tested.
Good Luck !
A FixYa rating would be appreciated thanks. !
John.
Feb 07, 2009 | 2005 Mazda RX-8
Won't turn on, ticking noise that continues when unplugged
Bad flyback transformer.....Emerson parts source ..Fox international or the partstore.com ...............T.
Jan 15, 2008 | Emerson EWF2703 27" TV
Whirlpool Duet GHW9150P Front Load Washer Logo
14 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
