How to rest a touch screenphone - Computers & Internet
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 42 Answers
Step 1:
What kind of phone? iPhones can be reset through the following steps.
Step 2:
Open Settings App
Step 3:
Click into General
Step 4:
Scroll down to Reset, and click it.
Step 5:
Click the appropriate reset button, repeat as needed.
Posted on Dec 10, 2012
INTERNAL TEMPERATURE FOR BEEF
it all depend how you want your Beef
Rare:
• 120-130 °F (50-55 °C) Internal appearance very red; very moist with warm juices. Approximate cooking and resting time: 20-25 min./lb. plus 8-10 min. resting
Medium-rare:
• 130-140 °F (55-60 °C) Internal appearance lighter red; very moist with warm juices. Approximate cooking and resting time: 25-30 min./lb.. plus 8-10 min. resting
Medium (with a touch of pink):
• 140-150 °F (60-65 °C) Internal appearance pink red color; moist with clear pink juice. Approximate cooking and resting time: 30-35 min./lb. plus 8-10 min. resting
Well-done:
• 150-165 °F (65-75 °C) Internal appearance no pink or red, slightly moist with clear juices
taken from
Cooking Temperatures for Beef
Oct 30, 2016 | Cars & Trucks
How to reset ipod touch
If you want to reset your ipod back to factory setting then this if what you do:
1. plug your ipod into the computer and open itunes.
2. click on your ipod and click back-up to backup your data on ur ipod.
3. If you have any photos that you want make sure you have a backup of them or transfer them.
4.After that you can just press the rest button in itunes.
-Or-
if you dont care about what on the ipod then you can go to settings, then general, then rest and chose which rest you would like.
Hope this response helps you!
Jul 17, 2014 | Apple iPod touch
My touch pad not working probably .
Adel Heider,
You may want to first download the driver and install it into the system from the link below.
Inspiron 1545 Drivers Download Page
http://dell.to/14IpAJU
Erratic Pointer Movement
Here are some easy steps to take to determine the problem with a touch pad demonstrating erratic pointer movement:
  1. Get the latest driver from support.dell.com - Most problems can be corrected with a simple driver download. This should always be one of the first steps when diagnosing any touch pad problem.
  2. Check for hand and finger placement - The most common cause of random pointer movement is that the touch pad senses a finger or part of the hand near the surface of the device.
    • Have the customer attempt to use the touch pad normally but to pay attention to the location of his or her hands and fingers. Are any straying too close to the touch pad?
    • Adjust the Touch Sensitivity and TouchCheck settings in the Touch Pad Settings section of the Dell Touchpad Properties.
  3. Try an external mouse - Does this problem happen with an external mouse attached?
    • The Device Select section of the Dell Touchpad Properties has options to enable or disable the touch pad or external mouse. Try several combinations of these settings.
    • If the problems only occur when the touch pad is enabled and do not occur any time a mouse or other external device is used, then the issue is related to the touch pad.
  4. Check for mechanical problems - If the problem cannot be corrected by adjusting the settings mentioned above and only occurs with the touch pad enabled, then this could indicate a mechanical problem.
    • Press down on the palm rest on first the left side of the touch pad and then the right. See if the cursor starts moving on its own.
    • Run Dell 32-bit Diagnostics and try to recreate the problems there. If either of these situations occur, then replace the palm rest.
No Pointer Movement
No pointer movement from the touch pad (or track stick, if available) usually is the result of one of two things: The touch pad has been disabled in the driver interface, or the touch pad cable is damaged or disconnected. Follow the steps below to determine the problem.
  1. Connect an external mouse - In either situation, an external mouse should still function. If it does not, try booting into Safe Mode and testing both devices again.
  2. Enable the touch pad in the driver settings - Using the external mouse (or key strokes if no mouse is available), go into the Dell Touchpad Properties. Go to the Device Select section and enable the touch pad. If already enabled, get the latest driver from support.dell.com.
  3. Test the device in Dell 32-bit Diagnostics - To eliminate a potential software problem, run the Dell 32-bit Diagnostics and test the device here.
  4. Check for mechanical problems - As a last resort, press down on the palm rest where the touch pad connector is located on the system board. If the pointer reacts in some way, then the cable may just need to be reseated. Otherwise, replace the palm rest.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Sep 07, 2013 | Dell Inspiron 1545 Notebook
Why is a spoon rest necessary?
Spoon rests are very useful for keeping any food from staining the counter while cooking and at the same time protecting the spoon from touching any contamination that might be on the counter
Jul 16, 2013 | Home
Touch Screen does not Working. The case is ok
Touch panel is faulty if u are stuck in the first alignment screen try getting it replaced under warranty
Feb 01, 2009 | HTC Touch Cruise Smartphone
Touch screen is not working
not working touch screen
May 22, 2008 | i-mate JAM Pocket PC
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
