Question about Philips 50PF7321D 50 in. Plasma HDTV
My Philips 50PF7321D/37 TV picture turns blue after about 30 secs of being on and I cant seem to get it to stop. Also when I turn the TV on it has a black screen with sound for about 15 secs before it
We got it in 07 new. problem seems to be getting worse since sept. if I turn the reciever off then back on it seems to reset the tv picture but shortly fades back to a blue tint.
    Top Expert:
  • Philips Master
  • 14,553 Answers
Unplug both the set and a box or receiver if used with the set, remove from power for several minutes and replug all to see if a reboot will help or not.
Posted on Dec 10, 2012
jdbouncer
  • 72 Answers
SOURCE: Half the screen has gone black
Ok first lets start with the half screen and no lit screen . Samsung plasma panels (S42AX-YD01) HD V4. are really bad about the Y-board (upper,lower) buffers are really bad about getting hot and burining up. If u remove the back cover of TV u will see on the left side the Y-board (it will be marked in small letters) if u look and the rows of IC's with heatsinks on the buffers will be a dark yellow. Majority of the time if u remove the buffers. and look underneath them u will see the solder has melted from the board. U can replace the Y-board and buffers and the TV will work fine.
Next part if u have vertical lines in the panel. There is not much u can do as a repair. Only thing u can do is get panel replaced. because there is and IC that is burned up on the panel, and trust me there isn't anything u can do to fix it. If u want to see for yourself. After removing the back cover, remove SSB, and brackets holding PDP in place. at the bottom of TV there is a row of buffers marked E,F,G, ( i think) there is a long heat sink covering the IC's at the bottom connected to the bottom of PDP. As u can see without a $70k machine to change this there is not much u can do with it. Hope this helps.
Posted on Apr 14, 2008
SOURCE: Hi, I have a Philips model 37PF7321d/37, 37 inch
The power board numbers you need to search for on eBay is 310432847531 or 310432838621 - they are compatible according to Philips.
Posted on Nov 05, 2009
  • 34 Answers
SOURCE: philips 50pf7321d/37. turn on with power green
Sounds like either a power supply or SSB board failure.
Posted on Nov 07, 2009
freetek
  • 5568 Answers
SOURCE: Philips lcd tv 42pfl5432d/37 no picture
If you feel you have isolated the problem board, you might check here for a replacement:
Jimmy's Parts
Posted on Nov 22, 2009
  • 10 Answers
SOURCE: No picture on Philips LCD TV
One very common problem encountered on many Philips models, old and new, In some cases, the SSB board has to be replaced as the resistor on the PCB on the back of the CRT had to be fixed. In other cases the Y Sustain board had to be replaced. If the problem is not due to these two issues, then the capacitors will need to be replaced as they only have a fixed guaranteed life. Thus, it would be wise to take out an extended warranty on Philips due to this common repair issue which often occurs after the limited warranty has ended. Or you could just call your local repairman. There are lots of websites on how to fix it yourself on google. There could be many reasons. Hope this helps!
Posted on Apr 14, 2010
I have a philips 50pfp5332b/37 i turned it off now when i turn it on a blue light comes on but the tv never turns on.
power supply, check out http://www.shopjimmy.com/ , they have the best prices and tech support
Sep 05, 2012 | Philips Televison & Video
No picture on Philips Model # 50PF7321D/37
The LED normally blinks--indicates the digital/main board is powered up.
Look for other fuses----Boards for these are rather expensive, maybe too expensive.
Google the model number with the word boards or parts after it to research it.
Mar 14, 2012 | Philips Televison & Video
I have a 50pf7321d 50"
Oh. It's Great. Never show it to anybody!!!!!
Jun 29, 2017 | Philips 50PF7321D 50 in. Plasma HDTV
I have a 50" plasma Philips tv 50pfp5332d/37 it
Most Common problem is Bad Capacitors on the power supply board, they will be vented or swollen on Top. 1000uf 16v 2200uf 10v 3300uf 10v
Jun 25, 2011 | Philips 50PF7321D 50 in. Plasma HDTV
I need a replacement power cord for my 50" Philips
It will have a standard figure 8 power lead connector at rear.
You should try local electronics store for spare lead.
Feb 05, 2011 | Philips 50PFP5332D 50 in. Plasma...
Half of my screen plasma TV 50" is black. What I have to do to fix it? plhilips plasma tv model 50PF7321D/37
Your Television problem on vertical section.
Solve: If you repair itself replace vertical IC or thoroughly resolder dry any components.
Jan 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
Philips 50PF7321D 50 in. Plasma HDTV Logo
149 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
