Question about Conair Irons
Conair foot bath model fb12nrt instruction manual
How to operate conair fabric steamer GS33W
Try Googling (Conair)(GS33W)(manual) without parens to get instructions.
Apr 04, 2018 | Conair Irons
Looking for a Conair CD18 Spiral Barrel Curling Iron 3/4inch manual
Try Googling (Conair)(CD18)(manual) without parens.
Apr 22, 2017 | Conair Irons
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
I have a panasonic unwrinkler garment steamer. how does it work
Friend has exact same model in the box with instructions and help centers repair numbers. Do you still need help? Want a new hardly used 1?
Oct 07, 2009 | Conair Compact Garment Steamer Iron
Re Conair garment steamer ctx12c
I bought this model from Costco and followed the instructions and tried using the picture on the box. You may have trouble, or at least be confused, if you try to attach like the picture on the package because the hose in the box is not exactly as pictured.  The hose you get does not have that extra ribbed part around the end that attaches to the console.  Therefore try the other end and you should be able to attach.  Once you figure that out make sure you "lock" the hose into place.  If not steam will escape from the loose installation and may scald you if you reach down.
Oct 06, 2008 | Conair Compact Garment Steamer Iron
I have lost my operating instructions, I have a Conair G3 compact garment steamer and want to use it, how do I start. Thank you for your help.
Check out a video manual on Conair Fabric Steamer
at http://www.handbooklive.com/
Click on Appliances category. The video instructions are for GS4 model but it must be similar.
Hope that helps
Sep 03, 2008 | Conair Compact Garment Steamer Iron
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Conair GS4 Steamer
faa3e02.jpgthis is from conair instructions included with steamer, finally found it, hope it helps some!
Oct 28, 2007 | Conair Gs4 Iron
Irons Logo
77 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
D. E. Hev
Are you a Conair Iron Expert? Answer questions, earn points and help others
