Question about Kenmore 52673 Side by Side Refrigerator
Removal of freezer control panel - Kenmore 52673 Side by Side Refrigerator
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 10, 2012
Front panel, temp control, water, ice etc not working.
Can you explain more about the panel?Email me through this website at "skyethespy@att.net" no quotations
Mar 09, 2014 | GE GSS25IFR Side by Side Refrigerator
Kitchen aid freezer gets ice . freezer on bottom
probably heating element in freezer is broken.
Remove power and defrost. Remove wall panels in back of freezer to Check heater element behind panels With ohm meter should read 20 ohms or less. You could remove it and bring it to a local repair shop and have them test it and if required order you a new one. If this does not work it may be the control board
drain below heater which should go into pan at bottom may be plugged.
Oct 20, 2013 | Refrigerators
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
My frigidaire fght2134kw is not defrosting...
Oct 15, 2013 | Frigidaire FGHT2134KW Top Freezer...
Control Panel show: Refrigeretor temp panel = all ligths OFF Freezer temp panel = all ligths from 1-5 =OFF 6-7 = ON ??? Thanks
You have a problem with the freezer fan motor inside the freezer. It is not circulating cold air up to the refrigerator section. You will need to determine if the fan motor has failed or has frozen due to ice buildup. You will need to remove everything out of the freezer including the drawer assembly and remove the back wall panel to gain access to the freezer fan motor.
Jun 28, 2011 | LG LFC23760ST Side by Side Bottom Freezer...
How do i get the plastic panel on teh back of my frigidaire freezer off--there aer no screws--there is a little round button off center on teh panel. I have used hair dryer adn the whole panel comes...
The panel you are trying to remove im guessing is near the top of the freezer. Do not remove that, as it is ONLY an air tunnel that leads from lower down the back wall. Removing this plastic panel could damage it. That METAL panel is held in place by about 10 screws. also, the temperature control is usually clipped on this back wall, and NEEDS to be removed from the back wall to remove the back wall from the freezer. there is usually a styrofoam cover around this control behind the back wall, keep this in one piece. If there is a problem with your freezer, it will have nothing to do with that upper plastic panel, as again, it is only an air tunnel
Dec 10, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
How do u access the defrost heater of the maytag mbb2256ges bottom freezer? from the rear of the fridge or remove the inner freezer panel?
Good day,
You access it from the front removing the rear panel in the freezer compartment.
Note: the heater may have failed, but has a very low failure rate.
If the machine is not defrosting, the timer and defrost thermostat ( sometimes called a limiter) are just as if not more often the problem.
Nov 04, 2009 | Maytag MBB2256GES Bottom Freezer...
GE Model GSS25TGNB CC died
If you do not see frost on the inside rear wall of the freezer , Poll the refrig out from the wall , and remove the back panel covering the compressor . If the compressor is not running , Remove the 8" X 10 " panel , just above the large panel first removed . Unplug the refrig . Remove the control board , and on the other side of the board ( soldered side ) , look just behind the small black boxes ( located on the other side ) and look for a joint which has become unsoldered . Resolder this spot and reinstall the board . Plug the refrig back in , and see if compressor starts . OR , you can replace the control board pt # WR55X10656 .
Sep 19, 2009 | GE Profile Arctica Stainless Steel Top...
Back wall freezes up on freezer side while fridge side is too warm. fridge temperature stays between 60 to 70 degrees
Is the freezer fan working ? If not , control board probably bad . Pull refrig out from wall and remove power . Remove the 8" X 10" panel and you will see the main control board . Remove the blue plug with 3 larger wires . The sequence is : wire1 , wire2 , space , wire3 . Using a short piece of wire with both ends stripped about 1/4 " , insert the wire into wire2 and wire3 . Plug refrig back in . Look in the freezer at the bottom rear for a red glow ( may take a minute or so ) . If you see a red glow , the main control board is bad ( the board you unplugged the wires from ) . If no red glow , then disconnect power to fridge , remove the jumper , and reinstall the blue plug and the panel .
Remove the food from the freezer section and remove the rear freezer panel inside the freezer . There you will see a round 1 " disk , clipped on top of the coils .Pt # WR60X10068 Defrost thermostat . At the bottom of the coils , you will see a heater . Pt # WR51X10042 Defrost heater . Replace both of these as the heater gets hot , and cuts off by the bimetal . he heater only has a screw on each side attaching it to the coils , and the bimetal just clips on . Easily repairable .
Aug 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 52673 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
