Question about Tools & Hardware - Others
Ace 700 clipper stapler sticks after stapleng
Unit works ok to set staple but sticks in the closed upward position after each staple is set. I must pull down on the staple carrier to put in proper position each time I use it
  • 2712 Answers
SOURCE: Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Posted on Aug 27, 2008
SOURCE: LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Posted on Dec 07, 2008
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Posted on Mar 15, 2009
SOURCE: Can't get the staples to go in. It's a sears
Pull out the part that loads the staples, turn the gun upside down, put the staples in the bottom of the gun and push the loader back in. It took me awhile to realize that you don't load them on the piece that pulls out of the gun.
Cheers.
Posted on Jul 18, 2009
Jammed Ace Clipper 700 stapler?
It must have a staple jammed in it, remove it as best you can. A small "pocket" screwdriver works to pry them out.
Jan 20, 2017 | Clipper Office Equipment & Supplies
I have a TRE 50 stapler and can't remember how to load it.
look at the back of stapler if their is a tab push in and down than slide the unit out place staples on rail and slide the spring unit in and lock into position or if you have the jaw type one grab bottom of stapler push up and back separating the lock and open like a set of jaws the slide lock will slide back with spring place staples on rail and snap closed
Aug 24, 2016 | Office Equipment & Supplies
How do you load a ace heavy duty clipper stapler model number 82?
I found some information here:
ACE STAPLE Quality Tradition for Over 50 Years
It takes the Clipper Undulated Heavy Duty 3/8" Staples. On the back of the stapler, there is a loading rod. Remove the loading rod and place a set of staples in the chamber, then re-install the loading rod.
Dec 02, 2015 | Heavy Duty Tools & Hardware - Others
Can not find staples for 502 ace liner stapler ,
Hi, I found them on amazon, click here and take a look: Staples Undulated For 07020 Clipper Plier 5000 BX. I hope this was helpful. Cheers
Jan 23, 2013 | Tools & Hardware - Others
I am trying to staple screen on 1.5 inch pine frame with 1/2 staples, but I have to set them with a hammer. Am I expecting to much or is there a way to adjest it to run them in the who way /
I have found that staples will set well only if I use the palm of my hand to hold the front of the stapler down tight against the material as I operate the handle.with my other hand. Without holding it down this way the stapler tends to recoil a bit and the staples don't set all of the way. If that doesn't solve it for you, you could try using 3/8 staples, since the screen material is of negligible thickness. Good luck, Al K
Jun 01, 2011 | Ace Hardware Ace Staple Gun
How do I load the clipper 700 stapler?
At the back of the stapler, there is a piece that you push in and then pull out. You load the staples in there and then replace the piece you pulled out.
Apr 27, 2011 | ACE Hardware Heavy Duty Clipper Stapler
I have an ACE aircraft aluminum stapler... I bought Ace Heavy Duty Staples 3/8" 10mm Narrow Crown Arrow T50 staples but cannot get the arm to load with them on it.
Possibly you are trying to load it from the back with the arm out. This way does not work. With this stapler you must pull the arm out all the way and then drop the staplers in the bottom. Too easy, right? I felt like a dumb a$$ after fighting this one for an hour. By the way, it will take heavy duty staples but you need to match the item codes printed on the side of the stapler with the box at ACE hardware. Hope this helps... Say "yes" to "was this solution helpful?" so I can know that im not the only one who did this wrong :)
Jan 09, 2011 | Ace Hardware Ace Staple Gun
Can't load staples in high capacity stapler
Try breaking off about 15 staples from the strip.
Dec 24, 2009 | Ace Hardware Ace Staple Gun
Got a black and decker electric stapler given to me but no manual so can't find way to load it. It is a cat. no. 9700 stapler
Look at the back of the staple gun just under the electric cord and you will see a 1/2 loop of spring steel sticking up from the chrome base. Push it down lightly and toward the front of the stapler - when it is all the way forward lift the loop it while in the forward position and while up - draw it back and the will come out of the staple gun.
Sep 29, 2009 | Black & Decker Tools & Hardware - Others
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
