Question about Husqvarna 23hp Briggs & Stratton 48-inch Yard Tractor
How to change the crank case gasket briggs 23hp
Can i flip the engine and remove the lower case?
  • Husqvarna Master
  • 2,239 Answers
Yes you need to drain the oil, turn the engine onto its flywheel, remove all the crankcase screws, clean the exposed crank to remove any rust or dirt, now gentlty ease the base off, it should come away with the oil pump gear.
Posted on Dec 11, 2012
I have a husky tractor with 23hp briggs the oil was full of gas in crank case
I have had this problem several times. On the models that have the gas tank mounted behind the dash and gravity allows the gas to drain into the crankcase because the needle valve in the carb don't shut off tight enough.I have had them hydrolock the engine with gasoline in the cylinder.Remove spark plug to clear it out. Be Careful as it will be like a car wash when you turn it over and if it sparks anywhere it can burn it to the ground.Been there done that, good thing it was a metal hood. After cleaning the carb I install a fuel shut off valve and a filter in the gas line. I have noticed a few tanks mounted under the seat when full will drain into the crankcase to about half a tank. Most of the needle valves in the carb have a rubber tip and the rubber gets hard if gasohol or any alcohol is used.
May 09, 2016 | Garden
How to remove piston from 17hp Briggs & Stratton mower engine?
You take the head off, remove the crank case cover, take the bolt off the piston journal on the crank shaft, push the piston out of the top of the engine. To get it back in you are going to need a ring compressor and should use plasti-guage to check clearance on the crank
Oct 13, 2015 | Briggs & Stratton Measuring Tools &...
Briggs and Stratton 24 HP ELS engine common cause of vacuum leaks causing engine to run poor
im not sure on an answer but i do know 200 lbs is way too much compression. go to a good lawn mower shop and talk to service. they should be able to give you a direction on this problem
Jul 25, 2013 | Cub Cadet Garden
Ariens 1640 Zoom Riding Mower with Briggs & Stratton engine smoking
check to see if the oil smells like gas the needle valves go bad in the carb and gas over flows into the crank case also the head gaskets go bad and **** the oil from the crank case
May 08, 2012 | Ariens Garden
Engine smokes on Ariens Zoom 1634 34 inch Zero Turn Riding Lawn mover with Briggs & Stratton engine
check to see if the oil smells like gas the needle valves go bad in the carb and overflows into the crank case also head gaskets go bad and **** oil in from the crank case
May 08, 2012 | Garden
The govenor rod cannot be adjusted. The springs are intact. Motor revs up but will not idle down. It is 23 HP.
Just guessing here, but if there is no control of the throttle and the engine over revs, then more than likely the governor control is broke. Briggs if famous for that problem. Governor is around 25 dollars and a lower crankcase gasket. Requires the engine to be pulled, lower crankcase removed, remove all pieces of old governor and then re assemble with new governor and gasket.////Before doing all this check that both springs are on the governor on the exterior of motor. If you manually hold the governor arm back, counterclockwise, and it still revs, then you need to replace governor. Don't let it rev for long or it with throw a pushrod or worse. good luck
Sep 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
23hp briggs on huskee only runs with full choke>>>??????? any help??
Pull the plugs, reconnect spark wires, and holding plug against engine (to ground the shell) crank engine. Good spark both plugs? Reinstall them, and check the fuel system -- dirty fuel filter, or dirt in carburetor or lines.
Aug 01, 2010 | Garden
23hp briggs won't run when it's hot.
probably ignition coil.common problem
Jun 29, 2010 | Briggs & Stratton Garden
Husqvarna 23hp Briggs & Stratton 48-inch Yard Tractor Logo
126 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
