Question about Locks & Locksmithing
Sticky deadbolt won't lift pins all the way.
The deadbolt portion of my door's lock system seems "stuck" inside. whether using the key on the outside, OR the knob on the inside, there is resistance. I can barely get the mechanism inside the deadbolt to turn to lift the bolt pins up. They seem to stop about 3/32" before full clearance. This small amount of exposed pins keeps the door from being able to be opened or closed! There is NO trouble with my lock's tumbler portion. This problem is with the deadbolt mechanism only! Can I get the deadbolt portion fixed or can I adjust it myself? Or does this mean the lock is shot? It wasn't cheap (solid brass casing, prettiest one I could find) and is about 10 years old.
5 Suggested Answers
cartersintn
  • 62 Answers
SOURCE: My key is stuck in my Kwikset deadbolt door lock
spray a little bit of oil where you insert the key turn it a couple of time to make sure it is lubricated then turn to correct location to pull out key hold cylinder in with finger key should pull out
Posted on Apr 13, 2009
  • 512 Answers
SOURCE: Key will not turn on deadbolt
The pins are probably frozen. Spray some w/d in lock, then try with key, keep repeating till key turns, this should free up lock. Dirt and moisture gets in lock cyl and gets gummed up. You could also remove handle and have locksmith take apart and clean, they will then use graphite instead of w/d wich attracts dirt.
Posted on Jul 20, 2009
ErusTownsend
  • 592 Answers
SOURCE: Our door lock is a
I have had this with kwikset systems before. When this happens the lock will eventually fail and become none working. The lock is damaged and cost to repair is not worth the time or money becasue these sets are very cheap and can be found at most Ace hardware or local hardware stores. Also some walmart's carry these as well.
The best solution, cheapest and less headache causing is to replace this lock with a new one. I know some peopel liek to buy sets so their deadbolt and knob are the same and kwikset does provide this setup as well. Typical price for a kwikset deadbolt only is about 15-20$USD.
Posted on Jan 20, 2011
  • 9 Answers
SOURCE: double cylinder deadbolt, bolt stuck in jam
You will have to remove cylinders from both sides of door, then stick a phillips screwdriver thru the bolt and push the screwdriver toward the hinge edge of the door.Might take a bit of pressure, depending on how hard its wedged into the jam, and you might break the bolt, but thats about the only way to get it out.try to determine why it got stuck before installing new one.
Posted on Oct 22, 2012
Testimonial: "Thanks, that worked, but the bolt will need replaced now."
How do I fix a Schlage deadbolt. B60 series will not unlock from the inside unless the key is inserted from the outside
With the door open, remove the interior trim (thumb turn) from the door, and using the key, turn the deadbolt to the locked position. Now re-install the thumb turn, in the locked position, and with the key removed see if you are able to unlock the deadbolt. I suspect that the tailpiece (part that sticks out of the lock cylinder and into the thumb turn) is not in the correct position.
May 02, 2014 | Schlage B60 Series Double SecureKey 5-pin...
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
Mar 23, 2013 | Volkswagen Golf Cars & Trucks
I purchased a schlage lock and the deadbolt won't
Check for clearance between the deadbolt and the striker plate in the jamb
Jan 19, 2013 | Locks & Locksmithing
1999 Isuzu Trooper door won't open
those door latches use a very tense spring that engage the closing mechansim. If the handle lifts without any restiction at all,,the sping is missing...if the handle when pulled or lifted offers slight resistance,this means it is very weak and needs replaced. it does not have enough rigidity to release the lock works from the lock pin that is fixed to the inside door facing.
Jun 07, 2012 | 1999 Isuzu Trooper
Deadbolt not retracting properly what to do
If your lock is new and defective, you should have no problem getting a replacement. However, before you do, make sure of three things:
Does the lock cycle properly with the door open but now when closed? If so, you are experiencing a mechanical bind between the door and the door jamb.
Is the lock "handed" properly? There is a jumper located internal of the lock with three pins; the jumper is across two of them. This controls whether the lock is installed for use with a door whose hinges are at the right or left as you face it. ( right-hand or left-hand opening).You may need to move the jumper from across pins 1 & 2 to across pins 2 & 3 or vice versa because it may be "backwards" for the way you have it installed.
Thirdly,I recommend that you go through the installation programming process,beginning with removing & reinstalling the batteries to assure they are installed correctly. You will find it here:
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
If all else fails, you can contact at the number listed at the top of the instruction sheet.
One final note: I have seen far more problems with the Powerbolt listed here than any other electronic lock. Just sayin'. Good luck!
May 03, 2012 | Weiser Lock Powerbolt 1000 Lock
Head won't lift without force. The head lock is in the Unlock position but it doesn't lift up easily. I have to stand behind the unit and use a lot of force to pull it up. It was fine one minute...
Presuming all looks OK near pivot & lock mechinism? can you see the locking hook in rear of mixer head at the hinge area directly behind lock lever, and is it nested in the slot on the base, or is it jamming up outside the stand and scratching it up?
There is a flat-head height adjust screw to control clearance between spatula and bottom of bowl visible from head-back position- leave it alone. There is a headless set screw visible when mixer is upside down to hold the pivot pin secure. This must be loostened with long-shaft flat screwdriver to remove the pivot pin for head removal if necessary ---avoid removing the pin if possible.
Is the hinge stuck with film of sticky sugar, milk-glue residue, ot the like? That is most common cause, distant second is the lock mechinism alignment (very rare)
Its important to keep head from wobbling side-to-side in use, so dont file or sand anything
Can telephone 609 213 2222 if necessary no charge for my talk.
Oct 16, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I bought Rona Collections Electronic Deadbolt. My problem is when my door is locked and when you pressed padlock button without entering your pin code the door will unlock. Any solution to this problem?...
You must ensure the deadbolt is in the locked position when attaching the control mechanism. The control mechanism must also be set to the locked position. Turn the manual knob to the left then attach the mechanism (with the batteries) to the flat pin. You can do all of this with the door open, so you can enter the codes. My initial install created the same issue. It worked properly out of the package, so that meant that I screwed something up. You don't need to return the item. Just do a little fault finding.
Sep 19, 2011 | Deadbolt Electronic Keyless System -...
Weiser powerbolt worked well for several months but now is not reliable anymore. Changing batteries did not help. It sounds like it is locking but sometimes fails to lock...we cannot trust it anymore
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Good lock or good unlock
Feb 05, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
Weiser keypad deadbolt lock deadbolt does not move when motor runs
Dec 30, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Tubular design deadbolt stuck in lock position. Door cannot open.
if you remove the screw from the deadbolt and remove the keyed parts you can see the plunger assembly. you can use a flat head screw driver and turn the plunger in. it will unlock the door and you will be able to replace the deadbolt
Sep 13, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Locks & Locksmithing Logo
169 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
