Yamaha v2500 will not power up
Will not power up their is nothing
  • 1 more comment
  • Sfaceat Kiyway
    Sfaceat Kiyway Dec 11, 2012
    I checked the fuse but it ok their is no power from the plug to fuse an it should have about 24 volts I think their something wrong in the power board
  • Sfaceat Kiyway
  • Alan Dec 11, 2012
    I think you are probably right, its not worth the money to get it fixed, they charge about a 70-100$ an hour, I have found great prices on receivers at Amazon.com. Its always good to update, with all the new video connections. If it was a 2$ fuse it would be nothing but after that I dont think its worth while. Good luck. Just in case use a ohm meter to measure the resistance on the fuse, they can probably check it at a radio shack or home depot for you.
    New Friend:
  • 25 Answers
I think your fuse is blown.
Posted on Dec 10, 2012
I need codes for a Yamaha rx-v2500 receiver. The codes listed turn it on but not off. Can you help??
Joseph, codes 0081,0082,0176, 0186, 1176, the attached manual may have more codes.
Yamaha rx-v2500 receiver, try the auto programming feature on your remote to set up universal remote. It is possible the remote may not support your equipment and you will have to replace with compatible remote. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Yamaha RX V2500 Receiver and DVR PVR 5 HELP
Codes for Universal Remotes Codes for Universal Remotes How to Program Universal Remote
Yamaha RX V2500 Owner Manual Setting Remote Control Codes
Aug 08, 2016 | Yamaha Audio Players & Recorders
All digital inputs dead
Main control board fault. Contact the authorized service center. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 30, 2015 | Yamaha RX-V2500 Receiver
Where do I plug rca cables from the cable box into an RX-V2500 Yamaha receiver?
Depending on what type of connections your cable box has available you can do the following:
1) If yo only have the standard VIDEO & L R AUDIO connections you can use the DTV connection on the back of the V2500. If your cable box also has an S-VHS connection this would be the same connection to use.
2) If you have COMPONENT VIDEO connections on your cable box then you would still use the DTV connection. Looking at the back of your V2500 the regular DTV RCA connections are just to the left of center. Farther over to the left are the COMPONENT VIDEO connections. They are labeled Y, Pb, and Pr. These allow for the higher needs of HD TV transmissions. If your cable box has these connections then making use of them would allow for the best quality for your picture.
The following website has your manual available for download in case you need it:
http://www.devicemanuals.com/guide/Audio%20and%20Video/Yamaha/Yamaha-RX-V2500-Owner%27s-Manual-TVRBek9UVT.html
Please let us know if you need any further assistance with your issue.
Mar 12, 2010 | Yamaha RX-V2500 Receiver
Can you tell me please: where do you insert cables from a cable box to a Yamaha RX-V2500 receiver I appreciate any help you can give. OK. The cables that were attached to my cable box were removed when the...
the coaxial cable from outside is connected to in (box), coaxial cable from out to digital in (RX) digital out to TV... (try scrolling through source to cable/ or component if this is HD) (all other devices can be connect to RX also like dvd using Red Yellow White cable or S-video w/red & white)
Just stopped working.Doesn't power up you can smell that burned smell.When you push the power button you can hear a little fizzle noise.
This isn't something we can help you with. Keep a fire extinguisher handy if you want to keep messing around with it. It needs hands- and eyes-on by a pro.
Feb 03, 2010 | Yamaha RX-V2500 Receiver
I HAVE A YAMAHA RX-V663, WAS ROCKING TO PINK FLOYD PRETTY LOUD AN
I had a similar problem. I have RX-V2500. No power to it when plugged it. Unplug then plug in again. Everytime you hit standby you get a click, which happens three timesand then no clicks until you unplug and replug.
I popped the cover off and just inside, where the power cable attaches, there was a white fuse. I think it was a 10A/250V (I'm in Canada), but read what the spec is on your fuse. I replaced this and it worked just dandy. Believe me - I was as surprised as the next guy.
Anyhow - hope that helps.
Obviously make sure it isnot connected to the power supply at all when you remove the cover.
Apr 11, 2009 | Yamaha RX-V995 Receiver
Onkyo HT-R520 Immediatly goes to standby mode when turned on
This Yamaha model has a "Thermal Protection Integrated Circuit", You can check the online manual at www.yamaha-uk/pdf/owner_manuals/rx-v2500.pdf
May 17, 2008 | Yamaha RX-V2500 Receiver
 Grubhead
Grubhead
