Question about KitchenAid KFIS27CXMS 26.6 cu. ft. French Door Refrigerator 4
Ice maker not working
Ice maker is not working but the fridge temperature is ok
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
It the food in the freezer frozen solid?
Posted on Dec 10, 2012
  • 1891 Answers
SOURCE: the freezer and the fridge are not on but the
flashing light stating that its too warm .. compressor probably is not running / power is ok or lights would not be on . look for a bad relay . somethes you can here clicking in back.. that is the comp trying to start .**** hop this helps you mmm leave feed badk pls .
Posted on Dec 09, 2009
BMT60
  • 126 Answers
SOURCE: replaced ice maker with new won't work
IF IT WILL NOT MAKE ICE YOU NEED A WATER VALVE. IF IT WILL NOT DISPENSE ICE YOU NEED A DOOR. BECAUSE THE WIRES AT THE BOTTOM OF THE DOOR BROKE. ORDER PARTRS HERE.
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 24, 2010
heatman101
  • 43501 Answers
SOURCE: have kitchen aide fridge ice maker stoped working,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hkhjkd
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: The ice maker stopped working.
heatman101
7895dhg
toolkits
  • 1099 Answers
SOURCE: Hi I have fridge model #KSRS27IKSS01
HI,
Take off the back panel in the freezer. 1/4" screws. Use a nut driver or ratchet and socket with an extension.
2. Behind the frost is the evaporator and the defrost heaters. One heater in the middle and one at the bottom. They are glass tubes. If you can see the bottom heater that is great. If not use a hair dryer and defrost only the very bottom to expose the lower heater only.
3. Now in the refrigerator section at the top where the controls are, take off the long plastic piece to expose the timer. The timer should be on the right hand side and have a little circle that is slotted. Get a flat screwdriver and turn that timer slowly clockwise just until it clicks and the refrigerator turns off. This will put it into defrost.
4. Now look at that heater that you exposed and see if it glows and gets hot. If it does, then the timer is bad.
5. If the heater doesn't come on then go ahead and defrost the rest of the evaporator with the hair dryer. This will take a little while. Don't poke at the evaporator!!!
6. Once totally defrosted look at both heaters. They should look like clear glass and see a silver coil running thru them. If they look discolored at all then the heaters are bad. The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator.
7. If the heaters look ok the only way to know for sure if they are bad is to check continuity with a meter on the plug at the end of their wiring harness. If you can check that then you can splice in a new defrost thermostat to solve the problem. However the best thing to do is replace the heaters and defrost thermostat . It is easy to install.
Follow these steps and this will solve your problem.
Posted on Oct 04, 2010
Testimonial: "Thank you for the very helpful advice. You obviously know the product well and now my fridge is working great!"
Ice maker is not producing ice and items in fridge are freezing.
How old is the fridge? Is this the first trouble experienced with this fridge? What is the outside temperature of the air around the fridge? Is the fridge kept in a garage? Please report back.
Jul 21, 2015 | Refrigerators
Ice maker has water but no ice
HI.TERRY.freezer has to work at its optimum.for the ice maker to work. i would try to defrost the freezer completely first and try.good luck.Ali
Jun 28, 2012 | Samsung Refrigerator Ice Maker -...
Maytag Fridge MFI2568AES - Ice maker not filling
Check water line going to fridge and ice maker! Does water come out ok?
Jun 17, 2012 | Maytag Refrigerators
Water dispenser and ice maker are not working, water supply to refrigerator is ok.
Check / replace the filter. Many fridges have a filter readily accessible from the fresh food compartment. The filter should be changed at regular intervals for best performance. A filter that is never changed will reduce and eventually stop water flow through it.
Check the temperature of the fresh food compartment near the filter. It may be "flirting" with the 32 degree mark. If it is this low, water has turned to ice - and will stop water from flowing. Bump the temperature up a tad to see if it solves the problem.
Lastly, the water supply solenoid may have failed. You didn't provide the model fridge - so I can't give specific info about it - but many fridges have one or two solenoids at the rear of the fridge for water supply and ice makers. You should hear a clicking sound from the rear of the fridge on many models when dispensing water or when the ice maker cycles on. If one has failed, you may expect to pay about $15 to $50 for a replacement - depending model.
Typical GE Refrigerator Single Solenoid Water Inlet Valve "WR57X10033"
Solenoid valve replacement is pretty straight forward. Usually all the is needed are some simple hand tools and a rag to pick up spilled water. Make sure the water supply is shut off and unplug the fridge before attempting.
If my answer was helpful - please rate it. Thanks & good luck!
Oct 05, 2011 | GE Refrigerators
Ice-maker does not work. water valve seems to be working.
There are 3 things that can prevent an ice maker from not working.
1- Temperature of freezzer- Temp must be below 6 degrees on most ice makers.
2- Water inlet valve- Depending on how your ice maker cycles it calls for water for 7.2 seconds. If you have ice and water though the door you have a dual valve and the ice maker selinoid ine the inlet may be bad. Also make sure water is getting to valve. Just because water is coming through the door does not mean water is entering fridge. There is a reservoir in fringe that holds around 3 gallons of water that can still make water come out the door without water entering fridge.
3- Faulty Ice maker- over time the winding and other components can get worn out and fail.
First check the temperature in the freezer.
Next check the inlet valve. To do this you need to remove the hose going from the inlet valve to ice maker and switch with the hose leading to door. Push the actuator in the door to call for water and see if water enters the ice maker. If it does inlet is good. Replace Icemaker. If not replace inlet valve. There may be a problem with the icemaker still but wont know until inlet is fixed.
If you have anymore problems or you need further assistance please feel free to contact
Jul 19, 2011 | Kenmore Refrigerators
KITCHEN AID REFRIGERATOR PROBLEM We bought a used Kitchen Aid fridge YKSRS22Q (1993), the ice maker is not working but water does work. What should we check to see why the ice maker doesn't work?
Ice makers work off of temperature. If it's not cold enough in the freezer it won't work. Check the temperature with a thermometer, it should be 0 to +10F
Jan 29, 2011 | Refrigerators
Fridge temperature has suddenly dropped to 15
Check the door gaskets, condenser fan, refrigerator fan and the freezer fan. That should narrow down the problem.
Dec 03, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker on Whirlpool fridge
i know it sounds obvious but check water supply is turned on. another easy check is the inlet valve is ok
May 09, 2007 | Whirlpool GD2SHGX Refrigerator
KitchenAid KFIS27CXMS 26.6 cu. ft. French Door Refrigerator 4 Logo
71 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
