Question about bearshare.com
How to change country on bearshre
Help me
How do I change the Email on the game Farmville Country escape I put the wrong Email address on the game so please help me change it think you
You can only have one account of FarmVille country escape, uninstall it and then try and link it to faceboo
Sep 29, 2014 | Zynga Farmville
I hit change my country accident how do i get back to USA
you can click on your name in the right top corner and click on my profile and then look for the country setting then you will change it. hope this helps. :)
Sep 01, 2014 | yahoo.com
How do i get my nevi 50lm to change states
When you press "Address"...Your next screen should be the state you are in. If you want to change the state or country go to the bottom of that screen and press "State or Country". Next screen you can select "Spell State or Province". If you want to change Country press the bottom of the screen and proceed to the next screen and enter the country name....example Canada....
Hope this helps
May 29, 2014 | Garmin Nuvi 50Lm - Gps Receiver
Phone won't make calls
I'm sorry about that, I know how you feel cause my cousin had this problem too. I'm not sure if it is the same options for every mobile but what you have to do is to change the options. What I mean. For each country there is this thing +30"32454353". The +30 is on what country you are, +30 = Greece, +** = (Your Country). There is an option in mobiles to change these numbers on what country you are. I'm not sure where the option is but try to find it. Change the numbers in the numbers of your country. If it already does then there is a problem, you should go on a store to fixit or change SIM SAM or whatever you have. I hope helped :) .
Dec 03, 2012 | HTC Inspire 4G Smartphone
Change the country setting for a garmin 1350
Typically, when the unit is turned on, the satellitetechnology is able to pin point the unit's current location and provide mapsbased on the user's position. However, if there is not a clear signal or youare located in a different country than the ending destination you are tryingto program into the unit, you may have to manually change the country. For thatplease follow these steps: 1. Touch anywhere on the display screen to access the mainmenu. 2. Tap or select the "Change Preferences" options. 3. Navigate to your map settings. In a Garmin this will belocated under the "View Maps" and then "Change Maps"settings. 4. Use the "Up" and "Down" arrows toscroll through the list of available countries. Once the country you arelooking for is highlighted, press the "OK" button. You will then beasked to select a state or more specific region in the selected country. Onceselected, press "OK" second time. Hope this will help you. Good Luck.
Aug 16, 2011 | Garmin Nuvi 660 GPS Receiver
We have a samsung sr150m digital DVD recorder with the country code set to austria, and so will not work, how do we change country setting. Hope someone can help. Thanks
If you bought it in a country not in austria, there must be a feature in it that you can change the country code setting. Try to go to the menu or set up on the remote control or the buttons on the unit. Scan for the features using the arrows. If you find 'country code settings', change it to the country you prefer.
Oct 03, 2010 | Samsung Televison & Video
How do i change country
Press Where To, Address, at the top of the screen it will show the country. At the bottom it says change country. Press Change country and type the name of the country you want. Press done.
Aug 01, 2010 | Garmin Nuvi 660 GPS Receiver
Can i take and use my aspire 5050 in india if so what do i need to connect it
Wifif is wifi no matter where you go.
Simply changing countries wont change a thing.
You may not be able to access some India based websites in America, but in the country of origin you will be using that countries ISP, and all Websites available in that country will be accessible to you. Don't forget to change your country code though, that helps identify your laptop or desktops country of origin, though even that usually wont limit access in any way.
Mar 15, 2010 | Acer Aspire 5050-3242 Notebook
bearshare.com Logo
204 people viewed this question
Top bearshare.com Computers & Internet Experts
David Payne
David Payne
Are you a bearshare.com Computer and Internet Expert? Answer questions, earn points and help others
