Question about Refrigerators
My frigidaire gallery model glws1233ASI
Has grease/oil getting into the drum on the clothes
  • Refrigerators Master
  • 4,654 Answers
This is a leaking transmission and I believe it will be the right time to replace the washing machine because of the cost of replacement. Thanks Sea Breeze
Posted on Dec 10, 2012
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: What's wrong with my frigidaire gallery, it wont
What is the model number of your unit? Is the compressor running?
Posted on Nov 24, 2012
I have a Frigidaire Gallery dryer model gler341as2 that squeels cer loud at times. what kind of grease do I use on the back shaft and tensioner?
That is a Hi Temp grease. It is sold under a Frigidaire part number
#5303307893. If any of the parts at that back ball assembly are worn, it should be replaced. Don't try buying the parts separately, they sell a complete back bearing kit that sells much cheaper than if you purchased each part. The kit also comes with the HI temp grease inside. Here is the kit # 5303281153. Includes that trailer hitch looking ball and the socket it fits into. Also look at the drum front edge. Should be a plastic bearing strip all the way around the drum opening that just snaps in place. Its in 2 section. If broken or missing replace those also. Thats the front bearing surface..
Apr 06, 2015 | Frigidaire Dryers
Frigidaire Gallery dryer Model FSG447GHSO. Clothes and dryer sheets get caught between the drum and one of the three "bumps" inside the drum, causing burn marks on clothing. I can see the gap where it
There is a gasket that fits around the back side of the tumbler. Sounds like it needs replacing. It's job is to keep clothes inside the tumbler.
Oct 10, 2014 | Dryers
Frigidaire Gallery model Gler341AS2 drum is sagging towards 6 o'clock and causes a gap that snags clothes. What parts need checking to find the cause of this?
seals on front and back, but drum rollers/glides here is a website, Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Apr 17, 2011 | Frigidaire GLER341A Electric Dryer
Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
I get oil/grease spots on my laundry ffrom my
You probably have a bad seal on the back of the drum, as that bearing is the only source of grease near your clothes. Good luck.
Jan 03, 2010 | Frigidaire GLTF1670A Front Load Washer
Rust stains on clothing
Cleaned lint out of the dryer internal air ducts.
Replaced the upper and lower drum seals.
Aug 23, 2009 | Frigidaire Dryers
My clothes are being stained by brown/black marks. I think it is an oil leak into the drum. Is it a seal and is it easy to fix? Frigidaire Gallery Model # FWT647GHSO
Spots on clothing in a washer are usually caused by a reaction between detergent and fabric softeners, but to check and see if these spots are petroleum based (oil), try removing the spots with solvent. If the spots will come out with solvent, but not with soap and water, then it could be transmission oil that is leaking into the tub and this is very bad news. This was a common problem on the older GE and Hotpoint washers. Sorry to hear about the problem that you are having and I hope this helped. Best wishes.
Aug 02, 2009 | Washing Machines
Frigidaire dryer drum liner
yeah, i think there called "drum glides" www.partselect.com type in your model number and you if they have that dryer in the system, then breakdown of the dryer will show, multiple diagrams. And look for the glides that are supposed to go there...hopefully this helps
Jul 31, 2009 | Dryers
Dryer drum has come loose, how do I tighten it?
These machines have a metal ball (like a small trailer hitch ball) mounted on the rear of the drum that rides in a plastic saddle mounted on the rear of the machine,
The parts that you need to replace would be the plastic glides mounted in the front of the drum that run on teflon pads glued to the rim around the door. When they get bad you start to notice dammaged clothing.
The drum is allowed to sag down enough that clothing can get into the gap at the bottom and as the drum turns upward the items get pinched when the gap closes at the top.
All these parts can be replaced but be prepared if you do it yourself, this is a tough machine to work on.
Good Luck
Quentin
Jun 27, 2009 | Frigidaire FEX831CS Top Load Stacked...
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
