Question about Panasonic Health & Beauty
I like to install batteries on shaver e3831 - Panasonic Health & Beauty
How to replace the batteries for a norelco r model 4865xl shaver
Correct batteries for your model can be found at shaveroutlet.com. See link bewlow
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-battery-pack-for-most-norelco-more-p-278.html
Videos for disassembly and installation can be found at links below
http://www.youtube.com/watch?v=rGD84BfKxAE
http://www.youtube.com/watch?v=2oAnLpvdYqQ
Nov 07, 2013 | Norelco Micro Action Shaver 4865XL...
Battery replacement for norelco 5822 SL shaver
You will find batteries for model 5822XL at shaveroutlet.com. See link below. Scroll down the page for helpful installation videos
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Nov 08, 2011 | Norelco Reflex 5822 XL Electric Shaver
Installation of battery for 950 remington
You will find the correct battery at shaveroutlet.com. You will need two. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Open shaver by removing two screws on the back. Then remove back cover to access battery compartment. You will need to 'unsolder' the wires from the ends of the batteries. Once removed, solder the new batteries to the wires.
Aug 23, 2011 | Remington Titanium Microflex R-950...
How do i open the philishave HQ 5812 to replace the battery pack ?
You will find the correct battery type and helpful installation video at shaveroutlet.com. Click on link below and scroll down for video
Aug 09, 2011 | Philips Philishave HQ5812 Electric Shaver
Need to replace the battery on a Braun 7526 shaver?
You will find the correct battery type at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Scroll don the page for installation tip and video showing how to disassemble the shaver
Feb 28, 2011 | Braun Syncro 7526 Electric Shaver
I have a Norelco 5822 XL cordless electric shaver. Suddenly it went dead and wouldn't take a charge. I took it to Batteries plus where the salesman said the batteries were completely dead. He changed the...
If the old batteries were corroded, that may have damaged the circuit board. If the batteries were getting hot before the shaver died, the heat may also have damaged the circuit board. It is also very possible that the salesperson did not do a good job installing them as they are not trained in replacing batteries in shavers.
For expert shaver battery installation, you can contact shaveroutlet.com
May 07, 2010 | Norelco Cool Skin 7775X Electric Shaver
How to open Philips shaver 7110X to replace batery
Remove 2 screws on the back to remove outer cover. Once removed, you will see 3 more screws that must be removed on the inner cover. Remove screws and cover to get to the battery.
When installing the battery, I suggest that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
You will find a battery for your shaver at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Feb 12, 2010 | Philips 7110X Electric Shaver
Health & Beauty Logo
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
