How do u fix the temperature sensor problem
Bad sensor
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 10, 2012
Temperature gauge does not work. Will replacing temperature sensor fix problem.or Could their be a blown fuse in the circuit
-Most likely the sensor itself. possible not the sensor may be broken wire to the sensor as well.
-Check it out and replace it if it is bad.
Good luck
Mai
Dec 13, 2017 | Cars & Trucks
How to fix codes p195 on 2004 lincoln ls 3.0
Generic OBD Error Code Details for P0195 Engine Oil Temperature Sensor What does this mean? OBD Code P0195refers to
The Engine Oil Temperature (EOT) sensor is a thermistor device in which resistance changes with temperature. The electrical resistance of a thermistor decreases as the temperature increases and the resistance increases as the temperature decreases. The varying resistance affects the voltage drop across the sensor terminals and provides electrical signal to the Powertrain Control Module (PCM) corresponding to temperature. Thermistor-type sensors are considered passive sensor. A passive sensor is connected to a voltage divider network so that varying the resistance of the passive sensor causes a variation in total current flow. Voltage that is dropped across a fixed resistor in a series with the sensor resistor determines the voltage signal at the PCM. This voltage signal is equal to the reference voltage minus the voltage drop across the fixed resistor. The EOT sensor measures the temperature of the engine oil. The sensor is typically threaded into the engine oil lubrication system. The PCM can use the EOT sensor input to determine the following: - On variable cam timing (VCT) applications the EOT input is used to adjust the VCT control gains and logic for camshaft timing. - The PCM can use the EOT sensor input in conjunction with other PCM inputs to determine oil degradation - The PCM can use EOT sensor input to initiate a soft engine shutdown. To prevent engine damage from occurring as a result of high oil temperature, the PCM has the ability to initiate a soft engine shutdown. Whenever engine RPM exceeds a calibrated level for a certain period of time, the PCM will begin reducing power by disabling engine cylinders. Symptoms Possible sumptoms of OBD code P0195
- Engine Light ON (or Service Engine Soon Warning Light) Causes Possible causes of OBD code P0195
- Engine not at operating temperature. - Cooling system problem of stuck thermostat. - EOT circuit failure. - Bad EOT sensor - Damaged PCM.
Nov 15, 2015 | Lincoln Cars & Trucks
P 0118, p 0340 and p 1193 probleme on my chrysler pt cruiser 2000
P0118 Engine Coolant Temperature Sensor Circuit High bad sensor
P0340 camshaft position sensor circuit bank 1sensor 1, bad sensor
P1193 Inlet Air Temperature Sensor Circuit High Condition
Replace ect and can sensor erace codes and car should should be good.
Apr 14, 2015 | Chrysler PT Cruiser Cars & Trucks
I have an open circuit error and would like to fix it.
I would measure the resistance of the temperature sensor behind the grill. If its open, the sensor is bad. If it shows resistance, then you probably have a broken wire somewhere.
Jul 23, 2014 | 2000 Jeep Grand Cherokee Laredo
Sensor keep coming in for code PO128 - insofficient ambient temp was does this mean how can i fix it
DTC P0128: Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
Do you have any issues with heat in the vehicle? If so the thermostat may need replaced If not the engine coolant temperature sensor is most likely reading incorrectly due to a bad sensor or connection to the sensor.
Dec 01, 2010 | 2008 Chevrolet Cobalt
FLASHING f 24 WHEN i TRY AND START THE MACHINE
The F-24 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). This is usually caused by a failed temperature sensor . A wiring failure or a failed electronic control board could also cause this fault code.
If you are able to unplug the washer and safely remove the bottom front service panel, then you can check the resistance of this temperature sensor using a volt/ohm meter. To remove the bottom front service panel, take out the screws at the very bottom of the panel and then pull it out and down to remove it from the washer. With the panel removed, you should be able to pull the wires off of the temperature sensor at the bottom front of the washer tub. Measure the resistance across the leads of the temperature sensor. You should measure about 10K ohms (10,000 ohms) of resistance at room temperature. A reading that is more than 30% off would verify a failure in this component. Replacing the temperature sensor would fix this type of problem.
If the resistance reading of the temperature sensor is okay at room temperature, you could have a wiring failure or a bad control board. There is also a slight possibility that you could still have a bad temperature sensor even though it measures okay at room temperature. A technician would normally be needed to check for this type of failure.
Aug 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hoover oph 714d optima 7kg washing machine fault code e05
Hi
Error code e005 means the temperature sensor has gone bad. To fix this error you'll need to replace the temperature sensor. It might have happened that the temperature sensor wires have been disconnected from the main board. To replace the temperature sensor you'll need to disassemble the washer and inspect the drum's bottom for the temperature sensor. Also check the wires coming to the sensor fro any cut.
Please post back for any further assistance.
Daniel
Aug 01, 2010 | Washing Machines
I have a code f24 on display screen the I have to hit stop start over, what is f24?
The F-24 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). This is usually caused by a failed temperature sensor (Key 24 in the image below). A wiring failure or a failed electronic control board could also cause this fault code.If you are able to unplug the washer and safely remove the bottom front service panel, then you can check the resistance of this temperature sensor using a volt/ohm meter. To remove the bottom front service panel, take out the screws at the very bottom of the panel and then pull it out and down to remove it from the washer. With the panel removed, you should be able to pull the wires off of the temperature sensor at the bottom front of the washer tub. Measure the resistance across the leads of the temperature sensor. You should measure about 10K ohms (10,000 ohms) of resistance at room temperature. A reading that is more than 30% off would verify a failure in this component. Replacing the temperature sensor would fix this type of problem.
Feb 24, 2010 | Kenmore HE2 Plus Front Load Washer
What is an F-24 error code?
f24 is out-of-range reading from temperature sensor, if you take the panel work off you find the sensor, sometimes a wire rattles out of its socket so the sensor cant sense anything, giving you that error.
so you could fix it yourself no parts needed, or a repair man could fix it for about £40 ($65USD)
Jan 01, 2010 | Kenmore HE2 Plus Front Load Washer
GE Oven displaying both F2 and F3 error codes; bad ERC or temp sensor?
F3 is Open oven temperature sensor circuit.
F4 Shorted oven temperature sensor circuit .
F7 Component failure.
To fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
Oct 28, 2008 | GE JRP15 Electric Single Oven
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
